11-23-2012, 15:28 | #1 (permalink) |
No Life Poster Join Date: Apr 2010
Member: 1276771 Status: Offline Thanks Meter: 33 | 302 flashing error only vibrate card found: S/N 1178:0118 registered to: javeedpco Connect phone on selected interface... Core : v1.53 , FlashEngine : v1.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm813__14.78.mcusw PPM : rm813__14.78.ppm_d2 CNT : rm813__14.78.image_d2_059L245 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 20420000FFFB3C40141E611C5FD1DE3F0C9CCF8A ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 358629041973375 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\358629041973375_CR T_2nd.rpl ===Flashing [MCU]=== Erase : Processing rm813__14.78.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm813__14.78.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [ISA+EXTDRV] Total writen 274 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ===Flashing [PPM]=== Erase : Processing rm813__14.78.ppm_d2 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm813__14.78.ppm_d2 Total writen 53 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ===Flashing [CNT]=== Erase : Processing rm813__14.78.image_d2_059L245 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing rm813__14.78.image_d2_059L245 Total writen 215 blocks TIME : Write time : 00:00:03 CNT Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ADL: Close_Session Content: 000300000000060000000600000000 ADL: Reboot Flashing done! Total flash time : 00:00:14 Reboot phone now... - > AfterFlash Failed! Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Elapsed: 00:02:41 Connect phone on selected interface... what is the solution plss help me expert???? |
11-23-2012, 15:50 | #2 (permalink) |
Member: 1276771 Status: Offline Thanks Meter: 33 | MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C0843E6E Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000DD76 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: nmwcdnsuc, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) Processing MCU file: rm813__14.78.mcusw [BB5,XSR 1.6] size: 31.87 MB Supported Ids: 0003192103002107, 000C192103002107, 0003192103022107, 000C192103022107, 000C192103032108, 400C192103022107, 4003192103022107, 400C192103032108, 4003192103032108, 400C192103042108, 4003192103042108 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 20420000FFFB3C40141E611C5FD1DE3F0C9CCF8A CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROM ID: 2CAC45E23BC33C8B Loading CMT secondary boot code SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0241 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66F5 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 205713F2 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x1E8 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Rpl(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35862904197337_CE RT.rpl). CMT PAPUBKEYS HASH: 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 49.81 MB CMT FLASH,MuxOneNAND area [00040000-000403FF] CMT FLASH,MuxOneNAND area [000C0000-0013FFFF] CMT FLASH,MuxOneNAND area [00140000-004BFFFF] CMT FLASH,MuxOneNAND area [004C0000-0073FFFF] CMT FLASH,MuxOneNAND area [00740000-0147FFFF] CMT FLASH,MuxOneNAND area [00160000-0017FFFF] CMT FLASH,MuxOneNAND area [03200000-0387FFFF] CMT FLASH,MuxOneNAND area [0F080000-0F67FFFF] CMT FLASH,MuxOneNAND area [01480000-0243FFFF] CMT FLASH,MuxOneNAND area [02440000-025BFFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT PAPUBKEYS: 05BDE0EC [] sent CMT DSP0 block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent CMT ADA block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT RAP3NAND block sent CMT UPDAPP block sent CMT ISA+EXTDRV block sent Programming completed in 9.303 s Processing PPM file: rm813__14.78.ppm_d2 [BB5,XSR 1.6] size: 6.57 MB Supported Ids: 0003192103002107, 000C192103002107, 0003192103022107, 000C192103022107, 000C192103032108, 400C192103022107, 4003192103022107, 400C192103032108, 4003192103032108, 400C192103042108, 4003192103042108 Erase size: 12.25 MB CMT FLASH,MuxOneNAND area [025C0000-031FFFFF] Flash programming ... Programming completed in 1.837 s Processing CNT file: rm813__14.78.image_d2_059L245 [BB5,XSR 1.6] size: 26.85 MB Supported Ids: 0003192103002107, 000C192103002107, 0003192103022107, 000C192103022107, 000C192103032108, 400C192103022107, 4003192103022107, 400C192103032108, 4003192103032108, 400C192103042108, 4003192103042108 Erase size: 184.06 MB CMT FLASH,MuxOneNAND area [03880000-0F07FFFF] Formating partition ... Flash programming ... Programming completed in 6.605 s Total time for flashing process(boot+erase+write) was 31.942 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Phone not found, retrying ... Warning: Phone did not reboot to normal mode. mxkey logs?? |
11-23-2012, 16:06 | #3 (permalink) |
Member: 1276771 Status: Offline Thanks Meter: 33 | mxkey logs MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C0843E6E Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000DD76 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: nmwcdnsuc, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) Processing MCU file: rm813__14.78.mcusw [BB5,XSR 1.6] size: 31.87 MB Supported Ids: 0003192103002107, 000C192103002107, 0003192103022107, 000C192103022107, 000C192103032108, 400C192103022107, 4003192103022107, 400C192103032108, 4003192103032108, 400C192103042108, 4003192103042108 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 20420000FFFB3C40141E611C5FD1DE3F0C9CCF8A CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROM ID: 2CAC45E23BC33C8B Loading CMT secondary boot code SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0241 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66F5 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 205713F2 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x1E8 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Rpl(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35862904197337_CE RT.rpl). CMT PAPUBKEYS HASH: 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 49.81 MB CMT FLASH,MuxOneNAND area [00040000-000403FF] CMT FLASH,MuxOneNAND area [000C0000-0013FFFF] CMT FLASH,MuxOneNAND area [00140000-004BFFFF] CMT FLASH,MuxOneNAND area [004C0000-0073FFFF] CMT FLASH,MuxOneNAND area [00740000-0147FFFF] CMT FLASH,MuxOneNAND area [00160000-0017FFFF] CMT FLASH,MuxOneNAND area [03200000-0387FFFF] CMT FLASH,MuxOneNAND area [0F080000-0F67FFFF] CMT FLASH,MuxOneNAND area [01480000-0243FFFF] CMT FLASH,MuxOneNAND area [02440000-025BFFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT PAPUBKEYS: 05BDE0EC [] sent CMT DSP0 block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent CMT ADA block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT RAP3NAND block sent CMT UPDAPP block sent CMT ISA+EXTDRV block sent Programming completed in 9.303 s Processing PPM file: rm813__14.78.ppm_d2 [BB5,XSR 1.6] size: 6.57 MB Supported Ids: 0003192103002107, 000C192103002107, 0003192103022107, 000C192103022107, 000C192103032108, 400C192103022107, 4003192103022107, 400C192103032108, 4003192103032108, 400C192103042108, 4003192103042108 Erase size: 12.25 MB CMT FLASH,MuxOneNAND area [025C0000-031FFFFF] Flash programming ... Programming completed in 1.837 s Processing CNT file: rm813__14.78.image_d2_059L245 [BB5,XSR 1.6] size: 26.85 MB Supported Ids: 0003192103002107, 000C192103002107, 0003192103022107, 000C192103022107, 000C192103032108, 400C192103022107, 4003192103022107, 400C192103032108, 4003192103032108, 400C192103042108, 4003192103042108 Erase size: 184.06 MB CMT FLASH,MuxOneNAND area [03880000-0F07FFFF] Formating partition ... Flash programming ... Programming completed in 6.605 s Total time for flashing process(boot+erase+write) was 31.942 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Phone not found, retrying ... Warning: Phone did not reboot to normal mode. |
11-23-2012, 18:58 | #4 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | No need post here other tools logs. Solution - if you really flash latest version - read fullflash, restore SL from phone, erase it and reflash and repair. |
11-24-2012, 07:08 | #5 (permalink) |
Member: 1276771 Status: Offline Thanks Meter: 33 | card found: S/N 1178:0118 registered to: javeedpco Connect phone on selected interface... Core : v1.53 , FlashEngine : v1.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm813__14.78.mcusw PPM : rm813__14.78.ppm_d1 CNT : rm813__14.78.image_d1_059L189_059N7S6_476_02 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 20420000FFFB3C40141E611C5FD1DE3F0C9CCF8A ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 358629041973375 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\358629041973375_CR T_2nd.rpl ===Flashing [MCU]=== Erase : Processing rm813__14.78.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm813__14.78.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [ISA+EXTDRV] Total writen 274 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ===Flashing [PPM]=== Erase : Processing rm813__14.78.ppm_d1 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm813__14.78.ppm_d1 Total writen 54 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ===Flashing [CNT]=== Erase : Processing rm813__14.78.image_d1_059L189_059N7S6_476_02 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing rm813__14.78.image_d1_059L189_059N7S6_476_02 Total writen 198 blocks TIME : Write time : 00:00:03 CNT Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ADL: Close_Session Content: 000300000000060000000600000000 ADL: Reboot Flashing done! Total flash time : 00:00:13 Reboot phone now... - > AfterFlash Failed! Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Elapsed: 00:02:42 Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 20420000FFFB3C40141E611C5FD1DE3F0C9CCF8A ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E ADL: phone is in flash mode Reading NPC certificate... IMEI : 358629041973375 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\358629041973375_CR T_2nd.rpl Will read flash content now... Flash IC Size : 256 MB Read done , 246 MB was readed FullFlash saved to : 358629041973375_full.bin ADL: Close_Session Content: 000300000000060000000600000000 ADL: Reboot Done!!! Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 20420000FFFB3C40141E611C5FD1DE3F0C9CCF8A ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E ADL: phone is in flash mode Reading NPC certificate... IMEI : 358629041973375 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\358629041973375_CR T_2nd.rpl Trying read spr block , wait ... Get phone data... Get flash data... SPR Read Ok! Spr saved to : 358629041973375.spr ADL: Close_Session Content: 000300000000060000000600000000 ADL: Reboot Processing SimLock extraction.... Checking readed data, wait few seconds ID_INFO : Not Found (Minor) Initial data found, start fun... SimLock RPL saved : c:\InfinityBox\BEST\Backup\Cert\358629041973375_SI M.rpl SimLock PM saved : c:\InfinityBox\BEST\Backup\Cert\358629041973375_SI M.pm Done! Elapsed: 00:00:49 Phone disconected! Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 20420000FFFB3C40141E611C5FD1DE3F0C9CCF8A ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E ADL: Reading certificates... Reading NPC certificate... IMEI : 358629041973375 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! ADL: Reading certificates done! ADL: Close_Session Content: 000300000000060000000600000000 ADL: Reboot Wait, reconneting... - > Phone not found... - > CertRead failed : phone was not bootup - > Connection/SW/HW problem, try bootup manually NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\358629041973375_CR T_2nd.rpl Phone disconected! Connect phone on selected interface... ??? |
