GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   BB5 Easy Service Tool (BEST) Nokia Dongle (https://forum.gsmhosting.com/vbb/f641/)
-   -   5233 rm-593 security test failed... (https://forum.gsmhosting.com/vbb/f641/5233-rm-593-security-test-failed-1501034/)
Hamidshah07 07-06-2012 09:08
plz help i restore 5233 rm-593 after erase now i m stuck at security test failed..here is logs..
card found: S/N 11*****
registered to: *******
Connect phone on selected interface...
Backup Certificates now...
Dead Mode is Selected
Waiting for USB device...
--- Insert cable and charger or press phone's power button! ---
Connection opened successfully
Waiting for communication response...
BootRom : 1st boot ok
ASIC ID: 000000010000022600010006400C192101051103
CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 05A0000E1092005254944B04881ABB03F7E8B524
ASIC MODE ID: 00
ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
ROM ID: 4B9B75103E691FF8
Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0
Processing RAWLOADER...
FLIC : 004000EC
Req : XSR 1.6
Use URAPIDOv11_XSR17_alg.fg , Rev : 2.0 Ver : 12.8.0
Processing PASUBTOC ...
Processing ALG ...
Boot Done! :)
TIME : Boot time : 00:00:00
CFL: Wait for Loader take control ...
CFL: Check mode
Phone ready, boot Ok
TransReq set Ok
PAPUBkeys : 053CA748F933E7C497F9DD5EF7A999E9B90BA153
CFL : Reading flash certs....
CFL : Reading NPC
IMEI : 358299030145805
CFL : Reading CCC
CFL : Reading HWC
Cert Read done!
CFL: Close_Session
Content: 000300000000050000000500000000
CFL: Reboot
Wait, reconneting...
SLx Simlock Data read ... ok
SL3 Simlock Sign read ... ok
WMDRM read ... ok
CRT308 Backup Created
NPC Certificate saved...
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
RPL saved : c:\InfinityBox\BEST\Backup\Cert\358299030145805_2n d.rpl
All done, Disconnecting
Elapsed: 00:00:14
Phone found!
Series 60 Device detected!
read info... - Ok
Reading Phone Info....
Connected phone - Nokia 5230-1c
Software ver : V ICPR72_10w42.1 23-11-10 RM-593 (c) Nokia
Ape Ver : V 40.8.003
APE Var : V 40.8.003???
APE ADSP: 256
DSP Ver : ICPR72_10w33
APE Test: eno_version
PPM :
CNT :
Product SN : CZB681854
Product code : 0577187
Base Prd.code: 0552692
Long Prod.SN : 0
Hardware info=======
HWID : 1101
Retu : 16
Tahvo : 22
Batery: 3572 mV
APE HW: 256
Lock info ===========
IMEI spNet : 3A 85 92 09 03 41 85 00
IMEI svNet : 33 85 92 09 03 41 85 20 F9
Conf key : 8000000000000000
Provider key : 3023200044773343
Provider : Unknown Provider
Counters : Key 0 [3] , Fbus 0 [10]
Blocks : 2
LOCK STATUS :
BLK : 1
Lock1:Open
BLK : 2
Lock1:Open
LOCKS : All Open
SDD key status : Ok
SimLock status : Ok
Security status : Damaged!!!!!
PA_SL3 phone , SP_CODE_LEN : 15
User code : Crypted
UserDataExLevel : Low [Gallery] , FullFlash method
Done!
Dzirt 07-06-2012 09:18
Hello. Local SX4. after writeback your pm.
Hamidshah07 07-06-2012 09:39
sir facing this problem..
Phone disconected!
Phone found!
read info... - Ok
Local SX4 procedure started...
Check SD : Key is Ok
Phone Imei: 358299030145805
Key file exists, no need to read...
Step 1...
Step 2...
SX4 Auth fail...
- > "Custom Keys" enabled, try again now
- > If SDD original - "Use Server Sx4"
Dzirt 07-06-2012 09:56
Can try as SW ask? Mean just press Sx4 again?
Hamidshah07 07-06-2012 11:47
yes but on both giving error..but i m using fbus cable no usb...if u want plz check on team viewer......
Dzirt 07-06-2012 11:56
Use USB.
Press Repair SDD
Press Local SX4 with CustomKeys checked
Write your PM
That is all.
Hamidshah07 07-06-2012 12:32
ok sir thanks for ur reply ,,let me try .then i report here..
Hamidshah07 07-06-2012 12:56
sir now this problem facing
Upload PM checked
Uploading RF/Battery tune to phone...
RM-593.pm not exist
Select file, please
Using : RM-356.pm
Setting to : 0583430
Operating mode is OK, no need change...
Check ST_SECURITY now...
Security status : ST_SECURITY => DAMAGED :(
- > Try "Restore CCC/HWC" option, after SX4 again
Dzirt 07-06-2012 14:18
Write pm backup after sx4.
Henry14 07-06-2012 14:59
1 Attachment(s)
Hi,
Here is RM-593 PM file.
Best regards
Hamidshah07 07-06-2012 18:27
Thanks all ,but MR mohsin solve my problem by team veiwer...i really appretiated this guy,he help hardly there costomer..and he wish that solved the problem of cutomers..
thanks again mr mohsin...
here is logs..
Phone found!
read info... - Ok
IMEI : 3582990301*****
APE ADSP: 256
PPM :
CNT : v 001_002 03-02-11 vanilla RM593
Product SN : CHJ506413
Product code : 0592823
Base Prd.code: 0585852
Long Prod.SN : 0
HWID : 0530
Retu : 16
Tahvo : 22
Batery: 3968 mV
APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.
APE HW: 256
IMEI : 3582990******
Blocks : 2
LOCK STATUS :
BLK : 1
Lock1:Open
BLK : 2
Lock1:Open
LOCKS : All Open
SDD key status : Ok
SimLock status : Ok
Security status : Ok
User code : Crypted
Done!
Page generated in 0.13140 seconds with 6 queries
