Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Temporary banned !! ![]() ![]() ![]() ![]() ![]() Join Date: May 2007 Location: lahore
Member: 504906 Status: Offline Sonork: 1604032 Thanks: 101
| 5233 rm-593 security test failed... plz help i restore 5233 rm-593 after erase now i m stuck at security test failed..here is logs.. card found: S/N 11***** registered to: ******* Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 05A0000E1092005254944B04881ABB03F7E8B524 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use URAPIDOv11_XSR17_alg.fg , Rev : 2.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! ![]() TIME : Boot time : 00:00:00 CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : 053CA748F933E7C497F9DD5EF7A999E9B90BA153 CFL : Reading flash certs.... CFL : Reading NPC IMEI : 358299030145805 CFL : Reading CCC CFL : Reading HWC Cert Read done! CFL: Close_Session Content: 000300000000050000000500000000 CFL: Reboot Wait, reconneting... SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok CRT308 Backup Created NPC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\358299030145805_2n d.rpl All done, Disconnecting Elapsed: 00:00:14 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 5230-1c Software ver : V ICPR72_10w42.1 23-11-10 RM-593 (c) Nokia IMEI : 358299030145805 Ape Ver : V 40.8.003 APE Var : V 40.8.003??? APE ADSP: 256 DSP Ver : ICPR72_10w33 APE Test: eno_version PPM : CNT : Product SN : CZB681854 Product code : 0577187 Base Prd.code: 0552692 Long Prod.SN : 0 Hardware info======= HWID : 1101 Retu : 16 Tahvo : 22 Batery: 3572 mV APE HW: 256 Lock info =========== IMEI : 358299030145805 IMEI spNet : 3A 85 92 09 03 41 85 00 IMEI svNet : 33 85 92 09 03 41 85 20 F9 Conf key : 8000000000000000 Provider key : 3023200044773343 Provider : Unknown Provider Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Open BLK : 2 Lock1:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Damaged!!!!! PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! |
| | #3 (permalink) |
| sir facing this problem.. Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358299030145805 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" enabled, try again now - > If SDD original - "Use Server Sx4" |
| | #6 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2009 Location: Russia , Syberia Age: 23
Member: 1157320 Status: Online Sonork: 100.1616907 Thanks: 4,098
| Use USB. Press Repair SDD Press Local SX4 with CustomKeys checked Write your PM That is all. |
| | #8 (permalink) |
| sir now this problem facing Upload PM checked Uploading RF/Battery tune to phone... RM-593.pm not exist Select file, please Using : RM-356.pm Setting to : 0583430 Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED ![]() - > Try "Restore CCC/HWC" option, after SX4 again |
| | #11 (permalink) |
| Thanks all ,but MR mohsin solve my problem by team veiwer...i really appretiated this guy,he help hardly there costomer..and he wish that solved the problem of cutomers.. thanks again mr mohsin... here is logs.. Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 5230-1c Software ver : V ICPR72_10w42.1 23-11-10 RM-593 (c) Nokia IMEI : 3582990301***** Ape Ver : V 40.8.003 APE Var : V 40.8.003??? APE ADSP: 256 DSP Ver : ICPR72_10w33 APE Test: eno_version PPM : CNT : v 001_002 03-02-11 vanilla RM593 Product SN : CHJ506413 Product code : 0592823 Base Prd.code: 0585852 Long Prod.SN : 0 Hardware info======= HWID : 0530 Retu : 16 Tahvo : 22 Batery: 3968 mV APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708. APE HW: 256 Lock info =========== IMEI : 3582990****** IMEI spNet : 3A 85 92 09 03 41 85 00 IMEI svNet : 33 85 92 09 03 41 85 20 F9 Conf key : 8000000000000000 Provider key : 3023200044773343 Provider : Unknown Provider Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Open BLK : 2 Lock1:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Security Code | dESiRE! | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 05-13-2011 22:17 |
| 5110 Security Code Help! | cahrisma | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 07-05-2010 09:04 |
| Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 02-28-2000 14:35 |
| SECURITY CODE | AWLABA | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 02-22-2000 22:38 |
| Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 11-22-1999 00:28 |
