Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 07-22-2012, 14:36   #1 (permalink)
anil.prajapati's Avatar
Member: 1642979
Sonork: 100.1613407
5233 secuerity test fail
Files Set for Flashing :
MCU : A0923FB6_RM-625_51.9.002_prd.core.C00
PPM : RM-625_51.9.002_prd.rofs2.V25
PPM2 : 840FBAE3_RM-625_51.9.002.549.04.rofs3.fpsx
CNT : 07646E4F_RM625_51.9.002_002_U549.uda.fpsx
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
--- Press phone's power button or insert cable & charger! ---
Connection opened successfully
Waiting for communication response...
BootRom : 1st boot ok
ASIC ID: 000000010000022600010006400C192101051105
CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 17A0001775B300522642533D02F5F8A011E2F445
ASIC MODE ID: 00
ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
ROM ID: 4B9B75103E691FF8
PatchRAWLoader: Patched OK
Processing RAWLOADER...
Processing RAP3NAND ...
Processing PASUBTOC ...
Processing PAPUBKEYS...
Processing UPDAPP ...
Boot Done!
TIME : Boot time : 00:00:03
Reopening the connection...
Waiting for response: 30
Waiting for response: 29
ADL -> [2nd] changing...
ADL Server confirm flashmode!
ADL : Auth done...
ADL : ASIC CMT select Ok
===Flashing [MCU]===
Erase : Processing A0923FB6_RM-625_51.9.002_prd.core.C00
Found 5 areas to erase
Erasing area 0x00040000 - 0x00082FFF, NAND, CMT
Result: 0000
Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT
Result: 0000
Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT
Result: 0000
Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT
Result: 0000
Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT
Result: 0000
Erase partition 0x0A
Partition erase Ok
Partitioning : Ok [5]
TIME : Erase time : 00:00:00
Write : Processing A0923FB6_RM-625_51.9.002_prd.core.C00
Total 414 [414/0/0] blocks to write, writing...
CMT : Writing Hash CERT [ADA]
CMT : Writing Hash CERT [KEYS]
CMT : Writing Hash CERT [PRIMAPP]
CMT : Writing Hash CERT [RAP3NAND]
CMT : Writing Hash CERT [PASUBTOC]
CMT : Writing Hash CERT [PAPUBKEYS]
CMT : Writing Hash CERT [SOS*UPDAPP]
CMT : Writing Hash CERT [SOS*ENO]
CMT : Writing Hash CERT [SOS*DSP0]
CMT : Writing Hash CERT [SOS*ISASW]
CMT : Writing Hash CERT [SOS+CORE]
CMT : Writing Hash CERT [SOS+ROFS1]
TIME : Write time : 00:00:27
MCU Write done
===Flashing [PPM]===
Erase : Processing RM-625_51.9.002_prd.rofs2.V25
Found 1 areas to erase
Erasing area 0x06DE0000 - 0x0915FFFF, NAND, CMT
Result: 0000
Write : Processing RM-625_51.9.002_prd.rofs2.V25
Total 109 [109/0/0] blocks to write, writing...
CMT : Writing Hash CERT [SOS+ROFS2]
TIME : Write time : 00:00:08
PPM Write done
===Flashing [PPM2]===
Erase : Processing 840FBAE3_RM-625_51.9.002.549.04.rofs3.fpsx
Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT
Result: 0000
Write : Processing 840FBAE3_RM-625_51.9.002.549.04.rofs3.fpsx
Total 28 [28/0/0] blocks to write, writing...
CMT : Writing Hash CERT [SOS+ROFS3]
TIME : Write time : 00:00:01
PPM Write done
===Flashing [CNT]===
Erase : Processing 07646E4F_RM625_51.9.002_002_U549.uda.fpsx
Erasing area 0x09E60000 - 0x0F47FFFF, NAND, CMT
Result: 0000
Write : Processing 07646E4F_RM625_51.9.002_002_U549.uda.fpsx
Total 93 [93/0/0] blocks to write, writing...
TIME : Write time : 00:00:07
CNT Write done
ADL : End flashing
ADL : Finalize...
Flashing done!
Total flash time : 00:00:46
Reboot phone now...
Reading Phone Info....
Connected phone - Nokia 5233
Software Info: V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia
IMEI: 35
Ape Version: V 51.9.002
Product code: 0594741
Checking...
SimLock status : SimLock is Ok
Security status : Security Damaged!!!!!
Read Info Done!
Settings After Flash Defaults...
ProductTuneSet...OK!
SwUpgradeSet...OK!
Battery voltage is enough for start
Set phone to Normal mode...
AfterFlash operations done ;D
Done!
Elapsed: 00:01:16
Connect phone on selected interface...
Read Uniq key data started...
--- Insert cable and charger or press phone's power button! ---
Fetching data, wait...
- > Reinsert cable and battery, press powerOn button again
- > For X7, E7 - just waiting, near 1 minute
- > When BEST start Search Phone - Press PowerOn if needed
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0
FLIC : 004000EC
Req : XSR 1.5
Use URAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 12.8.0
Processing ALG ...
Boot Done!
TIME : Boot time : 00:00:00
CFL: Wait for Loader take control ...
CFL: Check mode
Phone ready, boot Ok
TransReq set Ok
PAPUBkeys : 7DC72D3FDC552426A4479BC820097D304CFB6C15
CFL: Close_Session
Content: 000300000000020000000200000000
CFL: Reboot
Wait, reconneting...
rap= 17A0001775B300522642533D02F5F8A011E2F445
hash= B8C3ADECFC997FCD8081D3DEAF870B8C
key= 64B7E83174EAC31B95CA1128F8D25526699552E4
Key file updated...
Done!
Phone found!
Series 60 Device detected!
read info... - Ok
Local SX4 procedure started...
Check SD : Key is Ok
Phone Imei: 357
Key file exists, no need to read...
Step 1...
Step 2...
SX4 Auth fail...
- > "Custom Keys" enabled, try again now
- > If SDD original - "Use Server Sx4"
Phone Imei: 35
Use custom key...
Step 1...
Step 2...
SX4 Auth fail...
- > "Custom Keys" disabled, try again now
Phone Imei: 35
Step 1...
Step 2...
SX4 Auth fail...
Uploading RF/Battery tune to phone...
RM-625.pm not exist
Select file, please
No any file selected, break operation
Upload failed
Checking StartUp data ...
SDD Key status : SDData is Ok
- > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual )
PA_SimLock Version :
PA_SL3 phone , SP_CODE_LEN : 15
Done!
Processing Server SX4 Auth
Checking SDD key...
Operating mode is OK, no need change...
Connecting to server...
Connection error #1
Server not found...
SX4 Auth error
Old 07-22-2012, 14:46   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Sonork: 100.1616907
Server is online. Try again Server SX4.
For proceed Local SX4 - Press Repair SDD and after - Local SX4 with "custom keys" checked
Old 07-22-2012, 14:49   #3 (permalink)
Member: 1642979
Sonork: 100.1613407
Checking SDD key...
Connect to server Ok, checking
SX4 Server : Online, ver:1.04 , Infinity Team (c) 2011
SX4, processing Step #1
SX4, processing Step #2
SX4, processing Step #3
SX4 Result : Ok
Upload PM checked
RM-625.pm not exist
Select file, please
Upload failed
Upload done
Done!
Old 07-22-2012, 15:50   #4 (permalink)
Member: 1642979
Sonork: 100.1613407
problem solved after local sx4
The Following User Says Thank You to anil.prajapati For This Useful Post:
Old 07-22-2012, 15:54   #5 (permalink)
atif ikram's Avatar
Member: 1644460
Is this pm ok bec I have also this problem , I shall try this pm
Old 07-22-2012, 16:04   #6 (permalink)
Member: 1642979
Sonork: 100.1613407
yes 100% ok
write with local sx4
Old 07-22-2012, 16:15   #7 (permalink)
Dzirt's Avatar
Member: 1157320
Sonork: 100.1616907
Yes, sometimes need use different PM files, when one from BEST base not helps.
I will add this file to base.
Old 07-30-2012, 05:01   #8 (permalink)
silicon brj's Avatar
Member: 622060
solved security test failed
Thanx anil ji yes 100% working by writting this pm file thanx again
only Test zfrank Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 12-29-2000 20:43
Has someome tested this software Nokia New Series Tool? Genata Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-20-2000 16:39
I have that soft if smb need ask for testing.. Nec Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-01-2000 22:47
Nokia 5110 v. 5.24 Unlock Failed! Cybertooth Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 02-28-2000 14:35
Mti init failed dogbreak Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-22-1999 00:28
Page generated in 0.65832 seconds with 12 queries
