06-06-2012, 17:20 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: for sl3 phones Infinity best Age: 40
Member: 104393 Status: Offline Thanks Meter: 13 | sasafully reapred Nokia 5530 thanks Best team Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 5530 XpressMusic Software ver : V ICPR72_09w20.10 25-08-09 RM-504 (c) Nokia IMEI : 358253031204558 Ape Ver : V 11.0.054 APE Var : V 11.0.054V 11.0.054 V 11.0.054 APE ADSP: 256 DSP Ver : ICPR72_09w19_1 APE Test: rm504_ENO_x_09wk19v0.080 PPM : CNT : Product SN : CCJ493823 Product code : 0577619 Base Prd.code: 0573512 Long Prod.SN : 0 Hardware info======= HWID : 0802 Retu : 16 Tahvo : 22 Batery: 3711 mV APE HW: 256 Lock info =========== IMEI : 358253031204558 IMEI spNet : 3A 85 52 03 13 02 54 05 IMEI svNet : 33 85 52 03 13 02 54 05 F6 Unable to read Lock table... CRT308 Backup Created SDD key status : Ok SimLock status : Damaged!!!!! Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Checking, wait ... Get phone info data from flash... IMEI : 358253031204558 NPC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\358253031204558_CR T_2nd.rpl Get secure data... ID_INFO : Not Found (Minor) Initial data found, sending for check... RPL saved : c:\InfinityBox\BEST\Backup\Cert\358253031204558_SI M.rpl Done! Will Write RPL keys now... Check RPL file... SimLock Data found! SimLock key found! -> Skip Flash keys Part, for Flash Part use Dead Mode or Fbus Writing SimLock Key... Ok! Writing SimLock Data... Ok! SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security is Ok Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 5530 XpressMusic Software ver : V ICPR72_09w20.10 25-08-09 RM-504 (c) Nokia IMEI : 358253031204558 Ape Ver : V 11.0.054 APE Var : V 11.0.054V 11.0.054 V 11.0.054 APE ADSP: 256 DSP Ver : ICPR72_09w19_1 APE Test: rm504_ENO_x_09wk19v0.080 PPM : CNT : Product SN : CCJ493823 Product code : 0577619 Base Prd.code: 0573512 Long Prod.SN : 0 Hardware info======= HWID : 0802 Retu : 16 Tahvo : 22 Batery: 3691 mV APE HW: 256 Lock info =========== IMEI : 358253031204558 IMEI spNet : 3A 85 52 03 13 02 54 05 IMEI svNet : 33 85 52 03 13 02 54 05 F6 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Reading Phone Info.... Connected phone - Nokia 5530 XpressMusic Software ver : V ICPR72_09w20.10 25-08-09 RM-504 (c) Nokia IMEI : 358253031204558 Ape Ver : V 11.0.054 APE Var : V 11.0.054V 11.0.054 V 11.0.054 APE ADSP: 256 DSP Ver : ICPR72_09w19_1 APE Test: rm504_ENO_x_09wk19v0.080 PPM : CNT : Product SN : CCJ493823 Product code : 0577619 Base Prd.code: 0573512 Long Prod.SN : 0 Hardware info======= HWID : 0802 Retu : 16 Tahvo : 22 Batery: 3702 mV APE HW: 256 Lock info =========== IMEI : 358253031204558 IMEI spNet : 3A 85 52 03 13 02 54 05 IMEI svNet : 33 85 52 03 13 02 54 05 F6 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:06 Reading Phone Info.... Connected phone - Nokia 5530 XpressMusic Software ver : V ICPR72_09w20.10 25-08-09 RM-504 (c) Nokia IMEI : 358253031204558 Ape Ver : V 11.0.054 APE Var : V 11.0.054V 11.0.054 V 11.0.054 APE ADSP: 256 DSP Ver : ICPR72_09w19_1 APE Test: rm504_ENO_x_09wk19v0.080 PPM : CNT : Product SN : CCJ493823 Product code : 0577619 Base Prd.code: 0573512 Long Prod.SN : 0 Hardware info======= HWID : 0802 Retu : 16 Tahvo : 22 Batery: 3691 mV APE HW: 256 Lock info =========== IMEI : 358253031204558 IMEI spNet : 3A 85 52 03 13 02 54 05 IMEI svNet : 33 85 52 03 13 02 54 05 F6 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Phone disconected! Connect phone on selected interface... |
The Following 2 Users Say Thank You to Nesirliler For This Useful Post: |
