10-11-2013, 15:47 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: on forum
Member: 566122 Status: Offline Thanks Meter: 322 | All latest version of best cant flash infenion perfectly plz tell me is there any bugs in INFENION type flashing ? or something has change before flashing ? Plz note all other BB5 phones r flashing very nicely ,,,only my complain is for INFENION type of NOKIA phone ,,,believe me since 1.7 series of version has lounge ,,,i am totaly fail to enjoy it ,,,, onemore thing if i UNINSTALL latest version ,,,then install again 1.69 ,,,believe me works very very fine and never have such complain ,, if kind supporters of BEST can clear this problem ,,,will be realy appreciated., Waiting for ur kind replies. |
The Following 3 Users Say Thank You to aminnovelty For This Useful Post: |
10-12-2013, 06:40 | #3 (permalink) |
Member: 566122 Status: Offline Thanks Meter: 322 | Ok ,,,, if u think i just jocking ,,,,will show you screen shoot here soon ,,,enable to understand you my problem ,,,, I never confused if 1.59 shouldnt work on same phone,,,,,,,whease i never have anyproblem on 1.69 although if i have BB5 or INFENION,,,, |
The Following 2 Users Say Thank You to aminnovelty For This Useful Post: |
10-12-2013, 09:04 | #4 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | All is easy - you can see message, which explain all in log - if phone freeze - try again. It helps. Anyway, I will check it again. |
The Following User Says Thank You to Dzirt For This Useful Post: |
10-12-2013, 13:43 | #5 (permalink) |
Member: 566122 Status: Offline Thanks Meter: 322 | Thanks for your kind reply ,,,here is a screen shoot which i just flashed ,,,but as usual incomplete,,,,just look it ,,, 111.JPG i will realy apreciated if u will find any solution for this ,,,thanks again. |
10-12-2013, 18:52 | #7 (permalink) |
Member: 566122 Status: Offline Thanks Meter: 322 | sir it was on older firmware and i put latest firmware with arabic supported ,,, itried to flash on 1.73 but failed as same position ,,,same step as it always ,,,then i remove 1.73 and installed old version 1.69 and result FULLY SUCESSFULL FLASH.,,,,thats i strange to see all of this,,,next time i will put two parelel screen shoot ,,,one of 1,73 and another of 1.69,,,just enable to understand u all of this.I am in karachi ,,,andd some of my other freinds was also same somplaining to me ,,but couldnt desribe here ,,,, I realy love my BEST device ,,,i dont wanna to see any complain in it ,,,thats all. hope u will look into this matter and if findout any thing wrong ,,,will fix it in next update,,,,thanks alot. |
10-12-2013, 19:01 | #8 (permalink) |
Member: 566122 Status: Offline Thanks Meter: 322 | Yes i flash exactly same phone with same file on older version 1.69 and completed sucessfully without any error,,,next time i will show u the two different screen shoot of same model ,,, |
10-12-2013, 19:20 | #9 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | aminnovelty He Is Write I Have Same Problem c2-03 206 205 Always Stop During Image File OR ppm File But Same Phones Same Firmware Success With Other Box. WBR. Arsalan gsm2000. |
10-14-2013, 06:43 | #11 (permalink) |
Member: 566122 Status: Offline Thanks Meter: 322 | In early morinig i got asha 200 RM-761 for flashing and having same issue ,,,then complete on old version ,,,,, 222.JPG Error showing on new version 333.JPG and the same file with same version succesfully done with old version means 1.69,,,, I am sure there is 10000000% bux in all new version with started from 1.70,,,,need to see with cool mind. know all upto product supporter that how they fix this bug into coming version. |
10-14-2013, 08:01 | #13 (permalink) |
Member: 566122 Status: Offline Thanks Meter: 322 | Ok bro if u think i makes fun by writing post since day before yesterday,, and showing my problems,,,then ok ,,,know i cant say anything ,,,, if this kind of support will get continue ,,then enough to stop showing problems,,,, |
10-14-2013, 08:12 | #14 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Hi Dzirt, yes really funny flash done 200(RM-761) using Latest ver(1.73) Code: card found: S/N xxxx:xxxx registered to: Syed Tuqeer Ali Connect phone on selected interface... Core : v1.73 , BB5XG FlashEngine : v5.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm761__11.81.mcusw PPM : rm761__11.81.ppm_ma2 CNT : rm761__11.81.image_ma2_059J5K0 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 3593450412xxxxx IMEI 2 : 3593450412xxxxx PCcode : 059J4L0 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\359345041xxxxx_XG213_CRT.rpl ===Flashing [MCU]=== File : rm761__11.81.mcusw Image : rm761__11.81.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:06 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:01:47 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:36 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip ===Flashing [PPM]=== File : rm761__11.81.ppm_ma2 Image : package_ma2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00740000 Erasing, wait ... Erase done, time : 00:00:24 Write , Start : 0x41A80000 , Len : 0x00510068 Flashing , wait ... Region flash done, time : 00:00:06 ===Flashing [CNT]=== File : rm761__11.81.image_ma2_059J5K0 Image : package_ma2_059J5K0.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:02:56 Write , Start : 0x421C0000 , Len : 0x00AE0000 Flashing , wait ... Region flash done, time : 00:00:13 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:06 No write data, skip Flashing done! Total flash time : 00:06:21 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 200 Software Info: V 11.81 20-08-12 RM-761 (c) Nokia IMEI: 3593450412xxxxx PPM version : V 11.81 20-08-12 RM-761 (c) Nokia MA2 Product code: 059J4L0 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 43 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:08:04 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Try(may b its help) Uninstall/Delete best software/drivers restart pc, Install latest ver 1.73 update nokia drivers download flash files again Post result.... |
10-14-2013, 08:49 | #15 (permalink) |
Member: 566122 Status: Offline Thanks Meter: 322 | Yes sure brother ,,,i will do as i get guideline from you ,,, and whatever will be reply ,,,will post here ,,,not to get FUNNY POST from dezart ,,,but to improveme myself with your kind guidence ,,,,, can u tell me which skin u r using ,,,realy very nice one , |
