04-13-2014, 03:48 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: indonesia Age: 40
Member: 447517 Status: Offline Thanks Meter: 22 | Any solution for nokia 108 after break other tool? firts.. i flash with best.. flashing ok succesfully.. (i use 12.06.11 file version) after succesfully flashing.. phone come nokia logo than off.. than i try flashing and formating with chinese tool box.. and now.. phone can flashing with best again.. like this --- Insert USB cable now! --- Wait for phone... Phone found! [ 238 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : B9D519297E5CBBAB4495F02B6B36065B BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E [BL_ERROR] : Error while receiving Project ID info! BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 [ERROR] : DA_FAT_NOT_EXIST FAT_RANGE : 0x00000000-0xFFFFFFFF , LEN : 0x00000000 SecureDecrypt : RM-944_ROM_eMP_12.06.11 SecureDecrypt : RM-944_VIVA_eMP_12.06.11 SecureDecrypt : RM-944_LANG_PACK_ROM_ME_eMP_12.06.11 SecureDecrypt : RM-944_CUSTPACK_ROM_ME_APAC_ID_eMP_12.06.11 SecureDecrypt : RM-944_JUMP_TABLE_ME_APAC_ID_eMP_12.06.11 [ERROR] : [ERROR] : DA_S_FLASH_INFO_NOT_EXIST SDS info wrong, seems as damaged. RPL backup impossible OVRLP : 00004DF900000001 [ERROR] : DA_CBR_NOT_FOUND DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 [ERROR] : Error While erase area!!! Flashing failed! Connect phone on selected interface... i have full backup file from this phone (i use best to backup first time) i have rpl backup now.. can i rebuild this phone with best or not sir?? thank you very much for your answer before ... |
04-13-2014, 03:53 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. Use "Repair MAUI" option. Files on support /flashfiles/108 After repair MAUI - restore RPL back. Read Flash after again to check whole security status. Show me logs. Next time not use chinese tools for Nokia phones. |
The Following User Says Thank You to Dzirt For This Useful Post: |
04-13-2014, 04:22 | #3 (permalink) |
Member: 447517 Status: Offline Thanks Meter: 22 | error sir.. --- Insert USB cable now! --- Wait for phone... Phone found! [ 238 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : B9D519297E5CBBAB4495F02B6B36065B BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E [BL_ERROR] : Error while receiving Project ID info! BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent corrupted or damaged! Connect phone on selected interface... |
04-13-2014, 04:34 | #4 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Strange, it should select bree as default. I will check it. You can try repair MAUI with BEST 1.83 or 1.84, it will work. |
04-13-2014, 10:53 | #5 (permalink) |
Member: 447517 Status: Offline Thanks Meter: 22 | sir dzirt.. after repair maui and restore back rpl now set in first condition... keypad ligth only i try flashing with latest firmware.. (12.06.11) phone show nokia logo than off... and then i try flashing with version 10.04.11 set stuck logo nokia.. no restart.. i try flashing with version 11.01.11 phone condition same like i flash with 12.06.11 version firmware... after flashing iam always do formating/ factory setting.. sir... its hardware problem or still software or security problem?? at this time.. can i repair this phone or not? very very thank you for your attention... |
04-13-2014, 10:54 | #6 (permalink) |
Member: 447517 Status: Offline Thanks Meter: 22 | this log last i try flashing.. --- Insert USB cable now! --- Wait for phone... Phone found! [ 240 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : B9D519297E5CBBAB4495F02B6B36065B BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.12.06.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_11.01.11 SecureDecrypt : RM-944_VIVA_eMP_11.01.11 SecureDecrypt : RM-944_LANG_PACK_ROM_ME_eMP_11.01.11 SecureDecrypt : RM-944_CUSTPACK_ROM_ME_APAC_ID_eMP_11.01.11 SecureDecrypt : RM-944_JUMP_TABLE_ME_APAC_ID_eMP_11.01.11 OVRLP : 000069B900000001 PHPID : Bree.12.06.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x0001B000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_ROM_eMP_11.01.11 Write : RM-944_LANG_PACK_ROM_ME_eMP_11.01.11 Write : RM-944_CUSTPACK_ROM_ME_APAC_ID_eMP_11.01.11 Write : RM-944_JUMP_TABLE_ME_APAC_ID_eMP_11.01.11 Write : RM-944_VIVA_eMP_11.01.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_ROM_eMP_11.01.11 [VERIFY] DONE : RM-944_LANG_PACK_ROM_ME_eMP_11.01.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_ME_APAC_ID_eMP_11.01.11 [VERIFY] DONE : RM-944_JUMP_TABLE_ME_APAC_ID_eMP_11.01.11 [VERIFY] DONE : RM-944_VIVA_eMP_11.01.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:56 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds - > AfterFlash Not Done! Reason : Driver/Connection fault or HW Error Re-insert battery and PowerUp phone manualy Phone disconected! Connect phone on selected interface... Connect phone on selected interface... - > AfterFlash Not Done! Reason : Driver/Connection fault or HW Error Re-insert battery and PowerUp phone manualy Connect phone on selected interface... |
04-14-2014, 00:17 | #8 (permalink) |
Member: 447517 Status: Offline Thanks Meter: 22 | Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or boot from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 240 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : B9D519297E5CBBAB4495F02B6B36065B BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL failed! (CMD not accepted, 0xAA) Check Power / Cable! BootLoader Init Failed (HW/Connection Error) Connect phone on selected interface... Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or boot from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 240 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : B9D519297E5CBBAB4495F02B6B36065B BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.11.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 Read done PHB BBSN : B9D519297E5CBBAB4495F02B6B36065B [CBR] : Code 0xFF : MOBILE_ID check failed, not found MOBILE_ID info in CBR! Seems as area is Encrypted, need repair File Saved to : 000000000000000_MTK.bin Security [RPL] Saved to : 000000000000000.mtsec Read Done! Connect phone on selected interface... |
04-14-2014, 00:24 | #9 (permalink) |
Member: 447517 Status: Offline Thanks Meter: 22 | rpl restore... --- Insert USB cable now! --- Wait for phone... Phone found! [ 240 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : B9D519297E5CBBAB4495F02B6B36065B BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.11.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 Boot Ok Get settings... SDS OFF : 0x003F4000 SDS LEN : 0x0000C000 [INFO] : Plain RPL [RPL VERIFY] : Code 0x10 : MOBILE_ID match with MOBILE_ID info in RPL! Write : 358971054526645.mtsec Encrypt Done, Now Re-connect power/cable! Wait for phone... Phone found! [ 240 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : B9D519297E5CBBAB4495F02B6B36065B BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.11.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 Boot Ok Get settings... Write : 358971054526645_enc.mtsec Security restored All done! Connect phone on selected interface... |
04-14-2014, 00:26 | #10 (permalink) |
Member: 447517 Status: Offline Thanks Meter: 22 | read flash after rpl restore.. --- Insert USB cable now! --- Wait for phone... Phone found! [ 240 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : B9D519297E5CBBAB4495F02B6B36065B BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.11.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 Read done IMEI : 358971054526645 CBR BBSN : B9D519297E5CBBAB4495F02B6B36065B PHB BBSN : B9D519297E5CBBAB4495F02B6B36065B [CBR] : CBR is Ok, match with BB SN. Phone Security is Alive File Saved to : 358971054526645_MTK.bin Security [RPL] Saved to : 358971054526645.mtsec Read Done! Connect phone on selected interface... |
04-14-2014, 04:01 | #12 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Finally security is Ok. Take other working battery. Make factory rest. If no luck - open phone and resolder soc. |
