05-14-2013, 11:39 | #1 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Poland, Wroclaw Age: 50
Member: 67562 Status: Offline Sonork: none Thanks Meter: 89 | Asha 206 problem than i try to flash it with right files but process stop at 67%... Tryed it with ATF too but it slow from 67% (i think that ATF writing it as blind) Phone is dead. |
05-14-2013, 13:36 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. Please, post a log. Need check it. Also you can try next - Select ppm or cnt as mcu, and mcu as any other - ppm or cnt file and flash it. |
The Following User Says Thank You to Dzirt For This Useful Post: |
05-14-2013, 14:41 | #3 (permalink) |
Member: 67562 Status: Offline Sonork: none Thanks Meter: 89 | Client took the phone and i send him to Nokia Service Center. I can't try more. Here is log. (yesterday) Code: Connect phone on selected interface... Core : v1.64 , BB5XG FlashEngine : v4.2 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm873__03.58.mcusw PPM : rm873__03.58.ppm_e1 CNT : rm873__03.58.image_e1_059Q4B5 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 354126053551110 PCcode : `mißM* NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\354126053551110_2nd_XG213_CRT.rpl ===Flashing [MCU]=== File : rm873__03.58.mcusw Image : rm873__03.58.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:06 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:01:40 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash error Looks like connection lost... Error... -> Check cable, flashfile, try again from this file Connect phone on selected interface... Elapsed: 00:14:43 Connect phone on selected interface... |
05-14-2013, 16:34 | #4 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | I can add even whole erase of chip and full repair, but need few phones for test in such cases. What you made with it for put it in this condition? |
05-14-2013, 18:59 | #5 (permalink) |
Member: 67562 Status: Offline Sonork: none Thanks Meter: 89 | I have flashed it using wrong files only. Nothing else. Phone was readed, than i click flash button, i didn't saw that wrong files were set. My fault. It tells me, that software should show big WARNING window with info "wrong files set, you may kill phone, DO NOT CONTINUE" I wish i could have a phone, but client took it. |
05-14-2013, 19:09 | #6 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Will try play with such phones more after pass my diploma project. Seems, phone was accept certpack and was wait, when all data come. Flash erase should repair it. If all is as I think - after 2 weeks will be some update with support of that feature. |
05-14-2013, 21:10 | #7 (permalink) |
Member: 67562 Status: Offline Sonork: none Thanks Meter: 89 | It would be awesome. I'm sure that are more people such me a bit distracted sometimes... Please add warning window.(in case there are wrong files set or no right files in nokia/phoenix/products directory etc.) Thank you. Will wait for client with this Asha 206,wonder if come back. |
