10-30-2013, 17:28 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Bulgaria Smolyan
Member: 203747 Status: Offline Thanks Meter: 94 | ASHA 306 flash problem ===Flashing [PPM]=== File : rm767__07.42.ppm_k Image : package_k.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41D40000 , Len : 0x00800000 Erasing, wait ... Erase done, time : 00:00:12 Write , Start : 0x41D40000 , Len : 0x005EAAA8 Flashing , wait ... Region flash done, time : 00:00:07 [B][Minor Error] : CRC returned by phone is wrong! [CHK] : 0100A59F any idea how to fix it |
10-31-2013, 08:07 | #3 (permalink) |
Member: 203747 Status: Offline Thanks Meter: 94 | hi ok here is the full log Connect phone on selected interface... Core : v1.74.5 , BB5XG FlashEngine : v6.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm767__07.42.mcusw PPM : rm767__07.42.ppm_k CNT : rm767__07.42.image_k_059L8R9 Flashing phone now... Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... Data not accepted, check cable, battery -> Boot fail... Flashing failed... Phone disconected! Connect phone on selected interface... Core : v1.74.5 , BB5XG FlashEngine : v6.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm767__07.42.mcusw PPM : rm767__07.42.ppm_k CNT : rm767__07.42.image_k_059L8R9 Flashing phone now... Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.49_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 354576051869973 PCcode : і·?Ю¶. NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\354576051869973_XG 213_CRT.rpl ===Flashing [MCU]=== File : rm767__07.42.mcusw Image : rm767__07.42.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x000C0000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40060000 , Len : 0x000C0000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40120000 , Len : 0x01C20000 Erasing, wait ... Erase done, time : 00:00:57 Write , Start : 0x40120000 , Len : 0x01C04000 Flashing , wait ... Region flash done, time : 00:00:43 Processing Region 5/5 Erase , Start : 0x43EE0000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x908E ===Flashing [PPM]=== File : rm767__07.42.ppm_k Image : package_k.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41D40000 , Len : 0x00800000 Erasing, wait ... Erase done, time : 00:00:12 Write , Start : 0x41D40000 , Len : 0x005EAAA8 Flashing , wait ... Region flash done, time : 00:00:07 [Minor Error] : CRC returned by phone is wrong! [CHK] : 0100A59F ===Flashing [CNT]=== File : rm767__07.42.image_k_059L8R9 Image : package_k_059L8R9.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42540000 , Len : 0x019A0000 Erasing, wait ... Erase done, time : 00:00:54 Write , Start : 0x42540000 , Len : 0x00DE0000 Flashing , wait ... Region flash done, time : 00:00:18 Processing Region 2/2 Erase , Start : 0x43F00000 , Len : 0x00080000 Erasing, wait ... Erase done, time : 00:00:01 No write data, skip CRC check passed , 0x55F9 Flashing done! Total flash time : 00:03:19 Reboot phone now... - > AfterFlash Failed! Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Connect phone on selected interface... Elapsed: 00:05:30 Connect phone on selected interface... as you see its the latest SW v 7.42 the set was dead when customer gave it to me so any suggestions |
