08-20-2014, 14:54 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | Asha 308 RM-838 sim problem.... when try to make a call , popup box shows " call not allowed" when try to select network manual it shows all network but when select any one like home network shows this i make flash with latest firmware Log: Connect phone on selected interface... Core : v1.95 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual File [Ok] : rm838__08.13.mcusw File [Ok] : rm838__08.13.ppm_maa File [Ok] : rm838__08.13.image_maa_059N7V9 Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C2016100040498A28099AAC05F2AA62DA00 ASIC ID_E : 00000C2016100040 PUBLIC ID : 25F8159BBFC95D08498A28099AAC05F2AA62DA00 XGCHIP ID : 25F8159BBFC95D08 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 355496056813489 IMEI [2] : 355496056813497 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355496056813489_XG 213_CRT.rpl PAPUBkeys : FAF910DA218D8536CEFBDCE369A8C034160C6A5F === SW Version Check === - > UPGRADE === SW Version Check === === Flashing MCU === Processing file : rm838__08.13.mcusw Erasing... Writing... Total blocks : 90 Writing RKH CRT [ISSW] Writing RKH CRT [MEMSET] Writing RKH CRT [PRIMAPP] Writing RKH CRT [LOADER] Writing RKH CRT [PASUBTOC] Writing RKH CRT [PAPUBKEYS] [PAKeys : FAF910DA218D8536CEFBDCE369A8C034160C6A5F] Writing RKH CRT [UPDAPP] Writing RKH CRT [MCUSW] File processed Ok, 89 blocks were writen === Flashing PPM === Processing file : rm838__08.13.ppm_maa Erasing... Writing... Total blocks : 13 File processed Ok, 13 blocks were writen === Flashing CNT === Processing file : rm838__08.13.image_maa_059N7V9 Erasing... Writing... Total blocks : 104 File processed Ok, 104 blocks were writen Flashing done , total time : 00:00:54 Reboot phone to service mode... Reading Phone Info.... Connected phone - Nokia 308 Software Info: V 08.13 21-05-13 RM-838 (c) Nokia IMEI: 355496056813489 PPM version : V 08.13 21-05-13 RM-838 (c) Nokia MAA Product code: 059S8L6 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok and also take self test Initializing Tests... IMEI : 355496056813489 , Phone : RM-838 Nokia 308 Get keys... PASSED | ST_SIM_MULTIPLEXER_IF_TEST PASSED | ST_SLEEP_CLOCK_FREQ_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_SECURITY_TEST PASSED | ST_SIM_LOCK_TEST PASSED | ST_SECURITY_FUSE_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_EARP_TEST PASSED | ST_IHF_AMPLIFIER_TEST PASSED | ST_MIC_TEST PASSED | ST_CAMERA_IF_TEST PASSED | ST_DISPLAY_IF_TEST PASSED | ST_KEYB_LINE_TEST PASSED | ST_PWR_KEY_TEST PASSED | ST_KEYBOARD_STUCK_TEST PASSED | ST_TOUCH_IF_TEST PASSED | ST_TOUCH_TEST PASSED | ST_ADC_IF_TEST PASSED | ST_BTEMP_TEST PASSED | ST_MODEM_EM_ASIC_TEST PASSED | ST_VIBRA_TEST PASSED | ST_ACCELEROMETER_TEST PASSED | ST_MEMORY_CARD_IF_TEST PASSED | ST_RAM_IF_TEST PASSED | ST_CDSP_PA_TX_POWER_TEST PASSED | ST_RF_ANTENNA_TEST PASSED | ST_FEM_CURRENT_TEST PASSED | ST_CHARGER_IF_TEST SelfTests end Done! Elapsed: 00:00:15 Set phone in Normal mode... Restarting... Done! Connect phone on selected interface... anyone tell me how i can solve this problem.... |
08-20-2014, 15:13 | #2 (permalink) |
No Life Poster Join Date: Feb 2011 Location: ( United States Of Islam ) Age: 35
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | its hard wear problime not soft tray to rehet felter or pa or chang felter |
The Following User Says Thank You to niaz muhammad For This Useful Post: |
08-20-2014, 15:34 | #3 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Pakistan & Bahrain Age: 37
Member: 617073 Status: Offline Sonork: 100.1611349 Thanks Meter: 316 | hardware problem not software problem open mobile and check pcb |
The Following User Says Thank You to akhtarmughal For This Useful Post: |
08-20-2014, 16:30 | #5 (permalink) | |
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | Quote:
card found: S/N registered to: gsm city Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 308 Software ver : V 08.13 21-05-13 RM-838 (c) Nokia IMEI 1 : 355496056813489 IMEI 2 : 355496056813497 XappVer : 0000079E PPM : V 08.13 21-05-13 RM-838 (c) Nokia MAA CNT : Content: maa_059N7V9 V 08.13 21-05-13 RM-838 (c) Nokia Product SN : 0FC4F9FBH Product code : 059S8L6 Base Prd.code: 059N0P5 Module code : 0205513 Long Prod.SN : 0 Hardware info======= HWID : 1002 Batery: 3841 mV CMT BT: 0101-0.1.7 LCDVer: TPO Lock info =========== IMEI : 355496056813489 IMEI spNet : 3A 55 94 06 65 18 43 08 IMEI svNet : 33 55 94 06 65 18 43 18 F1 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL30 (20 digit) phone detected... User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! | |
08-20-2014, 16:37 | #6 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Phone is NeverLock. Try different sim cards from different operators. After, if on all same - check PA/and rest things before it. |
The Following User Says Thank You to Dzirt For This Useful Post: |
