01-22-2014, 15:08 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Asha 500 (Qiming XG223) Flash Done [WF] Thanks to Kihmet for test Code: Connect phone on selected interface... Core : v1.79 , BB5XG FlashEngine : v8.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm934_13.0.6.mcusw.fls PPM : rm934_13.0.6_059V1L1_eu1.rofs.fls CNT : rm934_13.0.6_059V1L1_eu1.image.fls Flashing phone now... Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 223 [XMM2230 QIMING] IF uCHIPID : CAB21009829E89502CC3CB00 IF Resp Data : 194200021C030101 Wait for user action : Insert battery Sending EBL Loader ... EBL Loader Ok EBL Loader ready Sending EBL ... EBL sent Ok EBL : 1_1345.300_MKEYSKEY QIMING EEP config Ok FLASHID : 52F00000 , [ NOR ] Boot conf set, Target Ready Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 35835xxxx IMEI 2 : 35835xxxx NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\BEST\Backup\Cert\xxxxxxxxxxxxxx_CRT_2nd.rpl ===Flashing [MCU]=== Processing file : rm934_13.0.6.mcusw.fls Region count : 2 00 : [ PSI ] : rm934_13.0.6.mcusw.fls.fls 01 : [ Code ] : rm934_13.0.6.mcusw.fls.fls Parse done , flashing now Flash : 00 : rm934_13.0.6.mcusw.fls.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x40000000 , Len : 0x00020000 Erase done Region Start : 0x40000000 , Data Len : 0x00020000 Region Load done Write done rm934_13.0.6.mcusw.fls.fls image flash done Flash : 01 : rm934_13.0.6.mcusw.fls.fls Sending Sec-Pack SecInfo Area : 0x0001 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x40040000 , Len : 0x00020000 Erase done Erase area 0x01 , Start 0x40060000 , Len : 0x00160000 Erase done Erase area 0x02 , Start 0x40340000 , Len : 0x02540000 Erase done Erase area 0x03 , Start 0x47E00000 , Len : 0x00040000 Erase done Region Start : 0x40040000 , Data Len : 0x00020000 Region Load done Write done Region Start : 0x40060000 , Data Len : 0x00160000 Region Load done Write done Region Start : 0x40340000 , Data Len : 0x020482A8 Region Load done Write done rm934_13.0.6.mcusw.fls.fls image flash done ===Flashing [PPM]=== Processing file : rm934_13.0.6_059V1L1_eu1.rofs.fls Region count : 1 00 : [ Cust ] : rofs_ebl_psi.fls Parse done , flashing now Flash : 00 : rofs_ebl_psi.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x42880000 , Len : 0x00F80000 Erase done Region Start : 0x42880000 , Data Len : 0x006F7DB8 Region Load done Write done rofs_ebl_psi.fls image flash done ===Flashing [CNT]=== Processing file : rm934_13.0.6_059V1L1_eu1.image.fls Region count : 1 00 : [ Cust ] : rm934_13.0.6_059V1L1_eu1.image.fls.image.fls Parse done , flashing now Flash : 00 : rm934_13.0.6_059V1L1_eu1.image.fls.image.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x43800000 , Len : 0x04600000 Erase done Erase area 0x01 , Start 0x47E40000 , Len : 0x000E0000 Erase done Region Start : 0x43800000 , Data Len : 0x02360000 Region Load done Write done rm934_13.0.6_059V1L1_eu1.image.fls.image.fls image flash done Flashing done! Total flash time : 00:01:58 Reboot phone now... Reading Phone Info.... Connected phone - 500 Software Info: V 13.0.6 20-11-13 RM-934 (c) Nokia IMEI: xxxxxxxxxx PPM version : 04fb2573ca61c4f39956c960bb4ba56011997f6c Product code: 059T8G3 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Check and Upload User Certificates ... Total - 61 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:02:24 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 6 Users Say Thank You to JayDi For This Useful Post: |
