02-04-2014, 07:42 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | AshaOs [501,502] Re-brand and flashing different ProductCode :) BEST will say wich version inside and with new tab in NaviManager - you can select correct ppm or choose other PPM with different languages. Example of wrong PPM, with which phone will die Code: Connect phone on selected interface... Core : v1.81 , BB5XG FlashEngine : v9.5 Selected FlashSettings : Manual File [Ok] : rm902_11.1.1.mcusw.fpsx File [Ok] : rm902_11.1.1_059R6T1_ea1.rofs.fpsx File [Ok] : rm902_11.1.1_059R6T1_ea1.image.fpsx Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C201610004049B22209A24848D4F1125900 ASIC ID_E : 00000C2016100040 PUBLIC ID : A4BD03AD6F50665749B22209A24848D4F1125900 XGCHIP ID : A4BD03AD6F506657 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 357898057737203 IMEI [2] : 357898057737211 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357898057737203_2nd_XG223_CRT.rpl PAPUBkeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E ID : 402 , Product : RM-902 , SWver : 11.1.1 , ProductCode : 059T1W8 , Region : s2_246 === PPM_ID Check === - > PPM_ID LOWER, THAN IN PHONE!!! - > Find other ID version and try again! - > Stop killing phone, break flashing! === PPM_ID Check === Error During flashing Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Our ID info from BEST : ID : 402 , Product : RM-902 , SWver : 11.1.1 , ProductCode : 059T1W8 , Region : s2_246 Our ID is 402 , so, we can flash 402, 403, 404.... e.t.c. How download correct FW :
Flash phone. You can flash only one PPM as well. Flash other Language Pack [ID 403] Code: Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core : v1.81 , BB5XG FlashEngine : v9.5 Selected FlashSettings : Manual Backup CRT308 data... CRT308 Backup Created SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok CMLA Key read ... Ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... Reboot.... File [Ok] : D3D46043_rm902_11.1.2_059R3Q4_s2_249_02_346884.rofs.fpsx 1st Boot Done, processing booting now ASIC ID_F : 00000C201610004049B22209A24848D4F1125900 ASIC ID_E : 00000C2016100040 PUBLIC ID : 0000000000000000000000000000000000000000 XGCHIP ID : 0000000000000000 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 357898057737203 IMEI [2] : 357898057737211 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357898057737203_XG223.rpl PAPUBkeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E === Flashing PPM === Processing file : D3D46043_rm902_11.1.2_059R3Q4_s2_249_02_346884.rofs.fpsx Erasing... Writing... Total blocks : 25 Writing RKH CRT [PPM] File processed Ok, 25 blocks were writen Flashing done , total time : 00:00:13 Reboot phone to service mode... Reading Phone Info.... Connected phone - 501 Software Info: V 11.1.1 23-10-13 RM-902 (c) Nokia IMEI: 357898057737203 PPM version : e8f64c8f395a281b36bb21f02e7b947cc3d20c24 Product code: 059T2T7 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Check and Upload User Certificates ... Total - 61 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Connect phone on selected interface... Code: Phone found! Series 40 Device detected! read info... - Ok Core : v1.81 , BB5XG FlashEngine : v9.5 Selected FlashSettings : Manual Backup CRT308 data... CRT308 Backup Created SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok CMLA Key read ... Ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... Reboot.... File [Ok] : CFD40EC5_rm902_11.1.1_059R6T6_m3_406_01_346903.rofs.fpsx 1st Boot Done, processing booting now ASIC ID_F : 00000C201610004049B22209A24848D4F1125900 ASIC ID_E : 00000C2016100040 PUBLIC ID : 0000000000000000000000000000000000000000 XGCHIP ID : 0000000000000000 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 357898057737203 IMEI [2] : 357898057737211 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357898057737203_2nd_XG223.rpl PAPUBkeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E === Flashing PPM === Processing file : CFD40EC5_rm902_11.1.1_059R6T6_m3_406_01_346903.rofs.fpsx Erasing... Writing... Total blocks : 16 Writing RKH CRT [PPM] File processed Ok, 16 blocks were writen Flashing done , total time : 00:00:12 Reboot phone to service mode... Reading Phone Info.... Connected phone - 501 Software Info: V 11.1.1 23-10-13 RM-902 (c) Nokia IMEI: 357898057737203 PPM version : cf807229ead462ad19cb0cfec17582bdf3082126 Product code: 059T2T7 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Check and Upload User Certificates ... Total - 61 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Connect phone on selected interface... |
The Following 6 Users Say Thank You to JayDi For This Useful Post: |
02-04-2014, 08:50 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | No, only for AshaOS series. WP7,WP8 mostly can be upgraded/downgraded without any problems. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
02-06-2014, 16:18 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Update : Asha OS based on XG221 (probably - on XG618 too) NOT AFFECTED by PPM/PC/REGION check , so, you can easy debrand them without any problems. Phones : Asha 500 , Asha 503 and their modifications. |
08-04-2014, 19:05 | #5 (permalink) |
Insane Poster Join Date: May 2009
Member: 1040508 Status: Offline Thanks Meter: 4 | Nokia 501, RM-902, flashed with diffrent soft without reading this post on the top :-( , only logo Nokia shows up, end black screen. If plug in to charger it vibrate one time for some seconds regullary and screen is black. Do you have solution? Product code: 059T1S5. the mobile is dead... |
05-01-2016, 12:00 | #7 (permalink) | |
Freak Poster Join Date: Dec 2015
Member: 2495033 Status: Offline Thanks Meter: 21 | Quote:
Sir In my infinity best there is (select product code/ variant) is unavailable How to open this option to download firmware of asha 501 | |
07-14-2016, 09:34 | #9 (permalink) |
Crazy Poster Join Date: May 2010 Location: NAIROBI KENYA EAST AFRICA
Member: 1294898 Status: Offline Thanks Meter: 5 | i aslo have nokia asha 501 ,iflashed it with v 14.06 now displays nokia log only ,then black lcd please help me what can i do to ravive it prod code is 059t398 pls help me |
04-05-2018, 09:59 | #13 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Noise City
Member: 889564 Status: Offline Thanks Meter: 336 | Mates, I have flashed one Asha 501 with firmware 14.0.6. PPM of this ver. is 14.0.8, but I need to downgrade it to 14.0.5. because in the higher version there's no bulgarian language. Only in this lower 14.0.5 vers. What are my options now, mates? I know that I can't downgrade PPM just like that, but I have to bring back the language or the phone is usefull... If I erase the set and then flash with this 14.0.5? Will it work? Can this set be safely erased and revive again? Any other safely options, mates? I can't find bulgarian EU2 langauge/package in higher versions. |
