| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2009 Location: Mass Effect 3 Age: 22
Member: 1157320 Status: Offline Thanks: 3,561
| BB5 Downgrade, ERASE, REPAIR, e.t.c) How-To Here is simple instruction how-to downgrade new SL3 phones via Erase method. Also this will be useful for repair phone - like - full SW rebuild ( Erase ) Platforms : By ONLY USB cable can be done with : RAPU11 - 6700, E52,E72, 5630, C5, N8, C7, C6-01, C3-01, X3-02, C5-03, E7, E6, E5, X7, T7 and others. RAPU21 - X3-02, C3-01, 500, 600, 700, 701 and others ... BCM - C3, 2710, 7020, X2, and same... RAPV4 - X3, 3710, 6303i, 7230 and same ... By FBUS ( RPL BACKUP via JAF box as interface ) + all other via USB can be done with : RAPIDO - 5530,N97,5800,C6,5250,5230,X6,E71,E75 and others FBUS needed only for RPL backup (NPC/CCC/HWC sections). Erase, Flash, Repair - possible by USB cable only. By FBUS can be done with : RAP3G phones - 6303c, 5130 and same ... OLD RAPIDO phones - 5800, N81 and same ... OLD RAPU11 phones - 6700, E52, E72 and same ... Example with RAPU21 phone - Nokia 500 (RM-750) Phone version before : 010.31 Needed version to flash : 010.29 Using USB cable. Actions :
Time for all - less than 5 minutes ![]() Logs : step 1 : Do backups ( RPL, PM, PP ) Code: Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: B83D0000FFFF3C4033D0CE8844612A2C83A4B1FF ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 11.34.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 11.34.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : F4C2F0A6BA76F178E59EBE710A8E1C85F3E122C0 ADL: Reading certificates... Reading NPC certificate... IMEI : 357924040135287 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! ADL: Reading certificates done! :) ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Wait, reconneting... SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok CRT308 Backup Created NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\357924040135287_2nd.rpl All done, Disconnecting Elapsed: 00:00:15 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Operating mode is OK, no need change... Reading PM from field 0 to 400 Field [1] 31 Record(s) Record 0: 10 byte(s) readed - Ok Record 1: 94 byte(s) readed - Ok Record 2: 110 byte(s) readed - Ok Record 4: 10 byte(s) readed - Ok Record 6: 110 byte(s) readed - Ok Record 7: 450 byte(s) readed - Ok Record 8: 10 byte(s) readed - Ok Record 13: 110 byte(s) readed - Ok Record 15: 30 byte(s) readed - Ok Record 16: 30 byte(s) readed - Ok Record 17: 30 byte(s) readed - Ok Record 18: 30 byte(s) readed - Ok Record 19: 30 byte(s) readed - Ok Record 22: 24 byte(s) readed - Ok Record 26: 10 byte(s) readed - Ok Record 27: 36 byte(s) readed - Ok Record 28: 110 byte(s) readed - Ok Record 29: 10 byte(s) readed - Ok Record 30: 36 byte(s) readed - Ok Record 31: 24 byte(s) readed - Ok Record 32: 216 byte(s) readed - Ok Record 33: 36 byte(s) readed - Ok Record 35: 24 byte(s) readed - Ok Record 36: 24 byte(s) readed - Ok Record 38: 216 byte(s) readed - Ok Record 39: 36 byte(s) readed - Ok Record 40: 24 byte(s) readed - Ok Record 41: 216 byte(s) readed - Ok Record 43: 36 byte(s) readed - Ok Record 44: 216 byte(s) readed - Ok Record 45: 216 byte(s) readed - Ok Field [2] 1 Record(s) Record 0: 2808 byte(s) readed - Ok Field [4] 9 Record(s) Record 1: 200 byte(s) readed - Ok Record 3: 10 byte(s) readed - Ok Record 4: 8 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 9: 5 byte(s) readed - Ok Record 18: 80 byte(s) readed - Ok Record 19: 4 byte(s) readed - Ok Record 28: 2 byte(s) readed - Ok Field [8] 7 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 16 byte(s) readed - Ok Record 2: 16 byte(s) readed - Ok Record 3: 128 byte(s) readed - Ok Record 4: 128 byte(s) readed - Ok Record 8: 8 byte(s) readed - Ok Record 10: 32 byte(s) readed - Ok Field [11] 5 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Record 2: 4 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 1061 byte(s) readed - Ok Field [12] 1 Record(s) Record 0: 8 byte(s) readed - Ok Field [26] 2 Record(s) Record 0: 16 byte(s) readed - Ok Record 1: 68 byte(s) readed - Ok Field [31] 1 Record(s) Record 4: 16 byte(s) readed - Ok Field [44] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [50] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Field [54] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [96] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 20 byte(s) readed - Ok Field [117] 9 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 3 byte(s) readed - Ok Record 2: 6 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 5: 10 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 8: 42 byte(s) readed - Ok Record 13: 3 byte(s) readed - Ok Record 14: 3 byte(s) readed - Ok Field [120] 4 Record(s) Record 0: 944 byte(s) readed - Ok Record 1: 160 byte(s) readed - Ok Record 2: 130 byte(s) readed - Ok Record 3: 112 byte(s) readed - Ok Field [153] 6 Record(s) Record 0: 68 byte(s) readed - Ok Record 1: 68 byte(s) readed - Ok Record 2: 68 byte(s) readed - Ok Record 3: 68 byte(s) readed - Ok Record 4: 68 byte(s) readed - Ok Record 5: 68 byte(s) readed - Ok Field [193] 4 Record(s) Record 2: 8 byte(s) readed - Ok Record 3: 32 byte(s) readed - Ok Record 4: 32 byte(s) readed - Ok Record 9: 64 byte(s) readed - Ok Field [217] 1 Record(s) Record 0: 32 byte(s) readed - Ok Field [239] 5 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 6268 byte(s) readed - Ok Record 2: 6268 byte(s) readed - Ok Record 3: 6268 byte(s) readed - Ok Record 6: 222 byte(s) readed - Ok Field [291] 1 Record(s) Record 0: 92 byte(s) readed - Ok Field [296] 4 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Record 2: 24 byte(s) readed - Ok Record 3: 5 byte(s) readed - Ok Field [308] 7 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 8192 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Field [309] 7 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 12 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 12 byte(s) readed - Ok Record 7: 12 byte(s) readed - Ok Record 17: 12 byte(s) readed - Ok Field [313] 1 Record(s) Record 0: 320 byte(s) readed - Ok Field [322] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [329] 1 Record(s) Record 0: 8392 byte(s) readed - Ok Field [334] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [341] 3 Record(s) Record 0: 1 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 4180 byte(s) readed - Ok Field [354] 1 Record(s) Record 0: 15 byte(s) readed - Ok Field [356] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [360] 2 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Field [369] 1 Record(s) Record 0: 40 byte(s) readed - Ok Field [388] 1 Record(s) Record 0: 4 byte(s) readed - Ok Field [395] 1 Record(s) Record 0: 16 byte(s) readed - Ok Saved as C:\InfinityBox\BEST\Backup\RM-750 Nokia N00_357924040135287_0_400.pm Done! Elapsed: 00:00:00 Operating mode is OK, no need change... Reading Product Profile sets... 0 - 127 1 - 0 4 - 0 7 - 1 9 - 0 34 - 0 35 - 0 56 - 0 61 - 0 65 - 0 66 - 0 69 - 1 70 - 0 71 - 1 78 - 0 79 - 1 100 - 1 130 - 5 131 - 7 135 - 0 138 - 0 145 - 0 146 - 0 147 - 0 157 - 1 158 - 1 164 - 0 165 - 0 166 - 0 168 - 0 177 - 0 183 - 0 192 - 0 202 - 3 205 - 0 206 - 0 211 - 0 212 - 0 214 - 0 217 - 0 219 - 0 220 - 0 228 - 0 SETS 1 Readed 43 element(s) Saved as C:\InfinityBox\BEST\RM-750 Nokia N00_357924040135287.pp Done! Elapsed: 00:00:00 Code: User ACCEPTED FULL ERASE Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: B83D0000FFFF3C4033D0CE8844612A2C83A4B1FF ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 11.34.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 11.34.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : F4C2F0A6BA76F178E59EBE710A8E1C85F3E122C0 ADL: Preparing for erase... Full Erase started... Asic : CMT , Sub : NAND Erase Area 0x00000000-0x1FFFFFFF Erasing Ok , [0F] Erase done , time : 00:00:01 ADL: Erase done ADL: Close_Session Content: 000205000000000000FFFF00000000 ADL: Reboot Phone disconected! Connect phone on selected interface... Code: Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-750_010.029_71i92_prd.core.fpsx PPM : RM-750_010.029_04.01_Russian_71i92_prd.rofs2.fpsx PPM2 : RM-750_010.029_00.01_71i92_prd.rofs3.fpsx CNT : RM-750_v0.005_APEONLY_prd.fpsx APE : RM-750_010.029_U01.01_71i92.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: B83D0000FFFF3C4033D0CE8844612A2C83A4B1FF ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 11.34.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 11.34.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : blank (Erased or HW failure) ADL: phone is in flash mode ===Flashing [MCU]=== Erase : Processing RM-750_010.029_71i92_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-750_010.029_71i92_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [SOS+DECOMP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 513 blocks TIME : Write time : 00:00:17 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-750_010.029_04.01_Russian_71i92_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-750_010.029_04.01_Russian_71i92_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 202 blocks TIME : Write time : 00:00:07 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-750_010.029_00.01_71i92_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-750_010.029_00.01_71i92_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 2 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing RM-750_v0.005_APEONLY_prd.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-750_v0.005_APEONLY_prd.fpsx CMT: Writing Hash CERT [SOS*ENO] Total writen 17 blocks TIME : Write time : 00:00:00 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [APE]=== Erase : Processing RM-750_010.029_U01.01_71i92.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-750_010.029_U01.01_71i92.uda.fpsx Total writen 369 blocks TIME : Write time : 00:00:14 APE Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:42 Reboot phone now... Reading Phone Info.... Connected phone - Nokia N00 Software Info: V 79u_sr1_11w32.1 19-08-11 RM-750 (c) Nokia IMEI: 12345610654321? Ape Version: 010.029 Product code: Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done ;D Done! Elapsed: 00:01:01 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Code: Seek file for this phone.... ----------------------------- - > RPL file found for this phone! - > NPC Found in : 357924040135287.rpl Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! WMDRM key found! ----------------------------- Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: B83D0000FFFF3C4033D0CE8844612A2C83A4B1FF ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 11.34.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 11.34.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : F4C2F0A6BA76F178E59EBE710A8E1C85F3E122C0 ADL: Preparing for write certificates... Erase NPC... Ok Writing NPC... Ok Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! :) ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Wait, reconneting... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Writing SimLock Key... Ok! Writing SimLock Data... Ok! SDD Key status : SDData Damaged!!!!! :( - > Do REPAIR SDD , Local SX4 if needed SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone detected , SP_CODE_LEN : 15 WMDRM_PD key sent... Ok Done! Code: Phone found! Series 60 Device detected! read info... - Ok Repair SD procedure started... Phone Imei: 357924040135287 Key file exists, no need to read... Operating mode is OK, no need change... Writing Super Dongle Key... Ok! Done! Local SX4 procedure started... Phone Imei: 357924040135287 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-750.pm Operating mode is OK, no need change... Field 1 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 4 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 13 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 22 write - Ok Record 26 write - Ok Record 27 write - Ok Record 28 write - Ok Record 29 write - Ok Record 30 write - Ok Record 31 write - Ok Record 32 write - Ok Record 33 write - Ok Record 35 write - Ok Record 36 write - Ok Record 38 write - Ok Record 39 write - Ok Record 40 write - Ok Record 41 write - Ok Record 43 write - Ok Record 44 write - Ok Record 45 write - Ok Field 2 Record 0 write - Ok Field 4 Record 1 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 9 write - Ok Record 28 write - Ok Field 309 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 7 write - Ok Record 17 write - Ok Check ST_SECURITY now... Security status : ST_SECURITY => OK Done! Elapsed: 00:00:01 Upload done Code: Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone detected , SP_CODE_LEN : 15 Done! Resetting selected items... Check phone mode... Phone already in Test mode, skip change... Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:01 Warranty IMEI restore Ok Writing product data... Changing Manufacturing date to : 09/2011 Ok ProductCode change to 059G733 Ok Setting HWID to 2000 Ok Setting Warranty IMEI to 357924040135287 Ok Write done Set phone in Normal mode... Restarting... Done! Connect phone on selected interface... Code: Reading Phone Info.... Connected phone - Nokia N00 Software ver : V 79u_sr1_11w32.1 19-08-11 RM-750 (c) Nokia IMEI : 357924040135287 Ape Ver : 010.029 APE Var : 010.029010.029.04.01010.029.00.01 APE ADSP: 256 DSP Ver : 79u_sr1_11w32 APE Test: RM-750_010.025v0.005 PPM : CNT : Product SN : 2C1FB18AA Product code : 059G733 Base Prd.code: 059F2J8 Module code : 0204861 Long Prod.SN : 0 Hardware info======= HWID : 2000 Retu : 35 Tahvo : 00 Batery: 4144 mV Camera: CMT BT: APE BT: HCI Version 4 (rev. 192). LMP Version 4 (rev. 16651). Manufacturer 15. APE HW: 256 LCDVer: RF ic : Lock info =========== IMEI : 357924040135287 IMEI spNet : 3A 75 29 04 04 31 25 08 IMEI svNet : 33 75 29 04 04 31 25 08 F1 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created User code : Crypted UserDataExLevel : Low [Gallery] Done! For BACKUP RPL from DEAD phones can be used this way :
| The Following 60 Users Say Thank You to Dzirt For This Useful Post: | aashir, adnan_taeki, aldman, aleem26, Applemobile66, atasalmi007, beoption, bilal642005, blue53, bossing0476, charan orissa, cheong966, coolshahul, delchoni, dsd, emilTECH, farid_bbr, fira_23, giriponsel, habib1, halim-gsm, hooshi, houssam19, HrM.MOB!LE, I am Back, Jani-Jan, Jesslin, kenawih, khanjee2, labean8, m3p, manju, mansour_bos, misterG, mnaouar, morton1984, mr.6630, mugbud2002, nasirns, nongmobile, pishtaz, pmdniaz786, rapm3tal, redouane2007, rewaaj, Rhyan777, rizkypratama999, saleem5001, sathvik71052, shadigsm, shahzad_786, singletch, smarty3399, TECNICELL2007, Teleserwis, the sorrow, varun_73, wajid735, zeshan shah, ^Suwit^ |
| | #2 (permalink) |
| Video : Nokia 500 ( RM-750 ) Downgrade ( With Erase/Repair ) NK500 Downgrade P.s. little later video will be uploaded to our support server in /Manual/ section. |
| The Following 8 Users Say Thank You to Dzirt For This Useful Post: |
| | #3 (permalink) |
When we will have NPC and Simlock (or full PM, or only PM120) backups - we can forget about RPL buy and do on SW whatever we want. |
| | #6 (permalink) |
| rewaaj, procedure same - but need use JAF or UFS as interface for this phones for Backup RPL. For 5800 -after RPL backup - it can be flashed/erased/repaired via USB only. For 2700c, 5130, 2690 - will be need use FBUS for Backup, Erase, Repair. As I said upper - after we done RPL backup - which include NPC+Simlock - we can do anything, what we want. |
| The Following 4 Users Say Thank You to Dzirt For This Useful Post: |
| | #7 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2010 Location: pakistan
Member: 1197620 Status: Online Sonork: 100.1602278 Thanks: 164
| Quote:
100.1602278 n8 dowgrde methadvia fenix | |
| The Following User Says Thank You to saleem5001 For This Useful Post: |
| | #8 (permalink) |
| saleem5001, With BEST and video from 2nd post in this Thread - you can do it for 4-5 minutes and without problems. |
| The Following User Says Thank You to Dzirt For This Useful Post: |
| | #12 (permalink) |
| Tomorrow will be more instructions about how-to do most of operations with BEST. We change old instructions on server to new one. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 16 | 03-21-2012 09:38 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| How can I do a Welcome note for my 6110 a dosn't have any one ? | Viper | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 12-10-2011 06:56 |
| How to add a language in 51xx/61xx | tati | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 12-03-2010 06:02 |
| Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 06-10-1999 22:36 |
