Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #121 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2008 Location: sargodha Age: 26
Member: 765909 Status: Offline Sonork: 100.1608098 Thanks: 577
| c7 downgread problem hi dzirt i try to downgread but now phone stuck on phone start up failed Quote:
| | #124 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2009 Location: Russia , Syberia Age: 23
Member: 1157320 Status: Offline Sonork: 100.1616907 Thanks: 4,099
| not matter in fact eno version. After eno reflash firmware normal. |
| The Following User Says Thank You to Dzirt For This Useful Post: |
| | #125 (permalink) | |
| all done without problem less than 3 min Quote:
| The Following User Says Thank You to delux_gsm For This Useful Post: |
| | #126 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2004 Location: Poland, Wroclaw Age: 39
Member: 67562 Status: Offline Sonork: none Thanks: 161
| Well... tell me what i did wrong couse phone id semi dead... 6700c via USB using Best v1.44 Code: Connect phone on selected interface...
Phone found!
Series 40 Device detected!
read info... - Ok
Reading Phone Info....
Connected phone - Nokia 6700 classic
Software ver : V 13.21 12-01-11 RM-470 (c) Nokia
IMEI : 352696043985596
DSP Ver : ICPR81_10w09
PPM : V 13.21 12-01-11 RM-470 (c) Nokia C
CNT : Content: eplus DE v2 V 13.21 12-01-11 RM-470 (c) Nokia
Product SN : KMK701813
Product code : 0587868
Base Prd.code: 0590482
Module code : 0203926
Long Prod.SN : 0
Hardware info=======
HWID : 1009
Retu : 34
Tahvo : 00
Batery: 4084 mV
CMT BT: 410B-v190
LCDVer: TPO
Lock info ===========
IMEI spNet : 3A 25 96 06 34 89 55 09
IMEI svNet : 33 25 96 06 34 89 55 49 F9
Conf key : 8000000000000002
Provider key : 2440700000000000
Provider : AT&T;U.S.A. (3650)
Counters : Key 0 [3] , Fbus 0 [10]
Blocks : 7
LOCK STATUS :
BLK : 1
Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS : All Open
CRT308 Backup Created
SDD key status : Ok
SimLock status : Ok
Security status : Ok
PA_SL3 phone , SP_CODE_LEN : 15
User Code : 12345
MMC pwd : no any record found
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
Backup Certificates now...
Backup CRT308 data...
SLx Simlock Data read ... ok
SL3 Simlock Sign read ... ok
WMDRM read ... ok
Check communication with phone....
Reboot....
Connection opened successfully
Waiting for communication response...
BootRom : Verify Error :(
Try again...
-> Error answer from BootRom
Looks like ASIC not supported, or HW failure
Supported : RapuYama, RAP3Gv4, BroadComm, RAPIDO
If RAPIDO - use dead mode for read rpl/force local
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
RPL saved : c:\InfinityBox\BEST\Backup\Cert\352696043985596_SIM.rpl
Phone disconected!
Phone found!
read info... - Ok
Read Uniq key data started...
- > Power Off phone, dissconnect it
Dead Mode is Selected
Waiting for USB device...
--- Insert cable and charger or press phone's power button! ---
ASIC ID: 000000030000022600010007600C192102011104
CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB
PUBLIC ID: 1BD00202DF7A0344FBFECB3D128DC89DF898C3F3
ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695
Fetching data, wait...
- > Reinsert cable and battery, press powerOn button again
- > For X7, E7 - just waiting, near 1 minute
- > When BEST start Search Phone - Press PowerOn if needed
BootRom : 1st boot ok
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
ROM ID: 3E273BF637BE26FA
Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.2.0
Processing RAWLOADER...
FLIC : 00400098
Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.2.0
Processing PASUBTOC ...
Processing ALG ...
Boot Done! :)
TIME : Boot time : 00:00:03
Reopening the connection...
Waiting for response: 30
Waiting for response: 29
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6
ADL: Close_Session
Content: 000300000000060000000600000000
ADL: Reboot
Wait, reconneting...
rap= 1BD00202DF7A0344FBFECB3D128DC89DF898C3F3
hash= 25B977A055BE9B5DEC0C38A2A279C695
key= 8C7634B02A3D9F4F1A399BC4CF0B6883FD136E43
Key file updated...
Done!
Phone found!
read info... - Ok
Try Read Camera Configuration to base...
Camera HW : ISL2TI020000093E2F30
Camera configuration exist, skip saving...
Cam 2 configuration not found
Done!
Reading Values...
Bat. voltage: 4047 mV
Currency: 171 mA
Temp: 25 C
Done!
Core : v1.44 , FlashEngine : v1.35
Selected FlashSettings :
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm470__13.10.mcusw
PPM : rm470__13.10.ppm_b
CNT : rm470__13.10_ISM_018.image_b_pl_chrome
Flashing phone now...
Check files done...
-> Check SW version...
FlashFile version : 13.10
Phone version : 13.21 12-01-11 RM-470 (c) Nokia
-> Check SW version : Downgrade try
WMDRM read ... ok
ADL req restart
Communication verify done... Preparing...
Gathering phone info...
-> Downgrade attempt detected
-> Downgrade aborted by user
-> Break flashing procedure...
Operating mode is OK, no need change...
Reading PM from field 0 to 400
Field [1] 29 Record(s)
Record 0: 114 byte(s) readed - Ok
Record 2: 10 byte(s) readed - Ok
Record 4: 110 byte(s) readed - Ok
Record 6: 10 byte(s) readed - Ok
Record 7: 214 byte(s) readed - Ok
Record 8: 110 byte(s) readed - Ok
Record 13: 10 byte(s) readed - Ok
Record 16: 208 byte(s) readed - Ok
Record 18: 208 byte(s) readed - Ok
Record 20: 208 byte(s) readed - Ok
Record 22: 16 byte(s) readed - Ok
Record 23: 4 byte(s) readed - Ok
Record 24: 84 byte(s) readed - Ok
Record 26: 110 byte(s) readed - Ok
Record 28: 10 byte(s) readed - Ok
Record 29: 10 byte(s) readed - Ok
Record 31: 208 byte(s) readed - Ok
Record 33: 36 byte(s) readed - Ok
Record 34: 376 byte(s) readed - Ok
Record 35: 16 byte(s) readed - Ok
Record 37: 4 byte(s) readed - Ok
Record 39: 36 byte(s) readed - Ok
Record 40: 16 byte(s) readed - Ok
Record 41: 182 byte(s) readed - Ok
Record 42: 4 byte(s) readed - Ok
Record 43: 36 byte(s) readed - Ok
Record 44: 182 byte(s) readed - Ok
Record 45: 182 byte(s) readed - Ok
Record 46: 64 byte(s) readed - Ok
Field [2] 1 Record(s)
Record 0: 2072 byte(s) readed - Ok
Field [4] 9 Record(s)
Record 1: 800 byte(s) readed - Ok
Record 3: 10 byte(s) readed - Ok
Record 4: 8 byte(s) readed - Ok
Record 5: 8 byte(s) readed - Ok
Record 6: 8 byte(s) readed - Ok
Record 9: 5 byte(s) readed - Ok
Record 18: 80 byte(s) readed - Ok
Record 19: 4 byte(s) readed - Ok
Record 28: 2 byte(s) readed - Ok
Field [6] 1 Record(s)
Record 0: 32 byte(s) readed - Ok
Field [8] 12 Record(s)
Record 0: 2 byte(s) readed - Ok
Record 1: 16 byte(s) readed - Ok
Record 2: 16 byte(s) readed - Ok
Record 3: 128 byte(s) readed - Ok
Record 4: 128 byte(s) readed - Ok
Record 7: 4 byte(s) readed - Ok
Record 8: 8 byte(s) readed - Ok
Record 9: 8 byte(s) readed - Ok
Record 10: 32 byte(s) readed - Ok
Record 11: 4 byte(s) readed - Ok
Record 12: 4 byte(s) readed - Ok
Field [11] 70 Record(s)
Record 0: 4 byte(s) readed - Ok
Record 1: 4 byte(s) readed - Ok
Record 2: 4 byte(s) readed - Ok
Record 3: 4 byte(s) readed - Ok
Record 4: 1 byte(s) readed - Ok
Record 5: 6 byte(s) readed - Ok
Record 6: 2 byte(s) readed - Ok
Record 7: 1 byte(s) readed - Ok
Record 8: 1 byte(s) readed - Ok
Record 9: 1 byte(s) readed - Ok
Record 10: 2 byte(s) readed - Ok
Record 11: 2 byte(s) readed - Ok
Record 12: 2 byte(s) readed - Ok
Record 13: 2 byte(s) readed - Ok
Record 14: 16 byte(s) readed - Ok
Record 15: 32 byte(s) readed - Ok
Record 16: 32 byte(s) readed - Ok
Record 17: 2 byte(s) readed - Ok
Record 18: 2 byte(s) readed - Ok
Record 19: 2 byte(s) readed - Ok
Record 20: 2 byte(s) readed - Ok
Record 21: 2 byte(s) readed - Ok
Record 22: 2 byte(s) readed - Ok
Record 23: 2 byte(s) readed - Ok
Record 24: 2 byte(s) readed - Ok
Record 25: 2 byte(s) readed - Ok
Record 26: 2 byte(s) readed - Ok
Record 27: 2 byte(s) readed - Ok
Record 29: 2 byte(s) readed - Ok
Record 30: 2 byte(s) readed - Ok
Record 31: 2 byte(s) readed - Ok
Record 32: 2 byte(s) readed - Ok
Record 33: 2 byte(s) readed - Ok
Record 34: 2 byte(s) readed - Ok
Record 35: 2 byte(s) readed - Ok
Record 36: 2 byte(s) readed - Ok
Record 37: 2 byte(s) readed - Ok
Record 38: 2 byte(s) readed - Ok
Record 39: 2 byte(s) readed - Ok
Record 40: 2 byte(s) readed - Ok
Record 41: 2 byte(s) readed - Ok
Record 42: 2 byte(s) readed - Ok
Record 43: 2 byte(s) readed - Ok
Record 44: 2 byte(s) readed - Ok
Record 45: 2 byte(s) readed - Ok
Record 46: 2 byte(s) readed - Ok
Record 47: 2 byte(s) readed - Ok
Record 48: 2 byte(s) readed - Ok
Record 49: 2 byte(s) readed - Ok
Record 50: 2 byte(s) readed - Ok
Record 51: 2 byte(s) readed - Ok
Record 52: 2 byte(s) readed - Ok
Record 53: 2 byte(s) readed - Ok
Record 54: 2 byte(s) readed - Ok
Record 55: 2 byte(s) readed - Ok
Record 56: 2 byte(s) readed - Ok
Record 57: 2 byte(s) readed - Ok
Record 58: 2 byte(s) readed - Ok
Record 59: 2 byte(s) readed - Ok
Record 60: 2 byte(s) readed - Ok
Record 61: 2 byte(s) readed - Ok
Record 62: 4 byte(s) readed - Ok
Record 63: 4 byte(s) readed - Ok
Record 64: 4 byte(s) readed - Ok
Record 65: 4 byte(s) readed - Ok
Record 66: 16 byte(s) readed - Ok
Record 67: 4 byte(s) readed - Ok
Record 68: 2 byte(s) readed - Ok
Record 69: 242 byte(s) readed - Ok
Field [12] 1 Record(s)
Record 0: 102 byte(s) readed - Ok
Field [13] 167 Record(s)
Record 0: 1 byte(s) readed - Ok
Record 1: 2 byte(s) readed - Ok
Record 2: 1 byte(s) readed - Ok
Record 3: 2 byte(s) readed - Ok
Record 5: 1 byte(s) readed - Ok
Record 6: 1 byte(s) readed - Ok
Record 8: 2 byte(s) readed - Ok
Record 10: 1 byte(s) readed - Ok
Record 11: 48 byte(s) readed - Ok
Record 13: 1 byte(s) readed - Ok
Record 14: 1 byte(s) readed - Ok
Record 15: 886 byte(s) readed - Ok
Record 16: 2 byte(s) readed - Ok
Record 17: 1 byte(s) readed - Ok
Record 18: 1 byte(s) readed - Ok
Record 19: 8 byte(s) readed - Ok
Record 20: 1 byte(s) readed - Ok
Record 21: 1 byte(s) readed - Ok
Record 22: 1 byte(s) readed - Ok
Record 23: 1 byte(s) readed - Ok
Record 24: 1 byte(s) readed - Ok
Record 26: 1 byte(s) readed - Ok
Record 27: 1 byte(s) readed - Ok
Record 28: 1 byte(s) readed - Ok
Record 29: 1 byte(s) readed - Ok
Record 30: 1 byte(s) readed - Ok
Record 31: 1 byte(s) readed - Ok
Record 32: 1 byte(s) readed - Ok
Record 33: 1 byte(s) readed - Ok
Record 34: 1 byte(s) readed - Ok
Record 35: 1 byte(s) readed - Ok
Record 36: 1 byte(s) readed - Ok
Record 38: 1 byte(s) readed - Ok
Record 39: 1 byte(s) readed - Ok
Record 40: 1 byte(s) readed - Ok
Record 41: 1 byte(s) readed - Ok
Record 43: 4 byte(s) readed - Ok
Record 44: 1 byte(s) readed - Ok
Record 45: 4 byte(s) readed - Ok
Record 46: 4 byte(s) readed - Ok
Record 47: 1 byte(s) readed - Ok
Record 48: 4 byte(s) readed - Ok
Record 49: 1 byte(s) readed - Ok
Record 50: 1 byte(s) readed - Ok
Record 51: 1 byte(s) readed - Ok
Record 53: 4 byte(s) readed - Ok
Record 54: 4 byte(s) readed - Ok
Record 55: 1 byte(s) readed - Ok
Record 56: 1 byte(s) readed - Ok
Record 57: 1 byte(s) readed - Ok
Record 59: 1 byte(s) readed - Ok
Record 60: 4 byte(s) readed - Ok
Record 61: 4 byte(s) readed - Ok
Record 62: 1 byte(s) readed - Ok
Record 65: 1 byte(s) readed - Ok
Record 66: 4 byte(s) readed - Ok
Record 68: 1 byte(s) readed - Ok
Record 69: 1 byte(s) readed - Ok
Record 70: 1 byte(s) readed - Ok
Record 71: 4 byte(s) readed - Ok
Record 72: 4 byte(s) readed - Ok
Record 73: 1 byte(s) readed - Ok
Record 74: 4 byte(s) readed - Ok
Record 75: 2 byte(s) readed - Ok
Record 76: 2 byte(s) readed - Ok
Record 77: 2 byte(s) readed - Ok
Record 78: 1 byte(s) readed - Ok
Record 79: 1 byte(s) readed - Ok
Record 80: 1 byte(s) readed - Ok
Record 81: 1 byte(s) readed - Ok
Record 82: 1 byte(s) readed - Ok
Record 83: 2 byte(s) readed - Ok
Record 84: 1 byte(s) readed - Ok
Record 85: 4 byte(s) readed - Ok
Record 86: 4 byte(s) readed - Ok
Record 87: 2 byte(s) readed - Ok
Record 88: 1 byte(s) readed - Ok
Record 89: 4 byte(s) readed - Ok
Record 90: 4 byte(s) readed - Ok
Record 91: 2 byte(s) readed - Ok
Record 92: 1 byte(s) readed - Ok
Record 93: 4 byte(s) readed - Ok
Record 94: 4 byte(s) readed - Ok
Record 95: 2 byte(s) readed - Ok
Record 96: 1 byte(s) readed - Ok
Record 97: 4 byte(s) readed - Ok
Record 98: 4 byte(s) readed - Ok
Record 99: 2 byte(s) readed - Ok
Record 100: 4 byte(s) readed - Ok
Record 101: 2 byte(s) readed - Ok
Record 102: 1 byte(s) readed - Ok
Record 103: 4 byte(s) readed - Ok
Record 104: 4 byte(s) readed - Ok
Record 105: 4 byte(s) readed - Ok
Record 106: 4 byte(s) readed - Ok
Record 107: 4 byte(s) readed - Ok
Record 108: 2 byte(s) readed - Ok
Record 109: 4 byte(s) readed - Ok
Record 110: 4 byte(s) readed - Ok
Record 111: 4 byte(s) readed - Ok
Record 112: 2 byte(s) readed - Ok
Record 113: 4 byte(s) readed - Ok
Record 114: 4 byte(s) readed - Ok
Record 115: 1 byte(s) readed - Ok
Record 116: 1 byte(s) readed - Ok
Record 117: 1 byte(s) readed - Ok
Record 118: 4 byte(s) readed - Ok
Record 119: 4 byte(s) readed - Ok
Record 120: 1 byte(s) readed - Ok
Record 121: 1 byte(s) readed - Ok
Record 122: 1 byte(s) readed - Ok
Record 123: 8 byte(s) readed - Ok
Record 124: 1 byte(s) readed - Ok
Record 125: 1 byte(s) readed - Ok
Record 126: 1 byte(s) readed - Ok
Record 127: 1 byte(s) readed - Ok
Record 128: 1 byte(s) readed - Ok
Record 129: 4 byte(s) readed - Ok
Record 130: 4 byte(s) readed - Ok
Record 131: 1 byte(s) readed - Ok
Record 132: 1 byte(s) readed - Ok
Record 133: 2 byte(s) readed - Ok
Record 134: 1 byte(s) readed - Ok
Record 135: 2 byte(s) readed - Ok
Record 136: 1 byte(s) readed - Ok
Record 137: 1 byte(s) readed - Ok
Record 138: 4 byte(s) readed - Ok
Record 139: 4 byte(s) readed - Ok
Record 140: 1 byte(s) readed - Ok
Record 141: 1 byte(s) readed - Ok
Record 142: 1 byte(s) readed - Ok
Record 143: 1 byte(s) readed - Ok
Record 144: 4 byte(s) readed - Ok
Record 145: 8 byte(s) readed - Ok
Record 146: 4 byte(s) readed - Ok
Record 147: 4 byte(s) readed - Ok
Record 148: 1 byte(s) readed - Ok
Record 149: 1 byte(s) readed - Ok
Record 150: 1 byte(s) readed - Ok
Record 151: 1 byte(s) readed - Ok
Record 152: 1 byte(s) readed - Ok
Record 153: 1 byte(s) readed - Ok
Record 154: 1 byte(s) readed - Ok
Record 155: 1 byte(s) readed - Ok
Record 156: 1 byte(s) readed - Ok
Record 157: 1 byte(s) readed - Ok
Record 158: 1 byte(s) readed - Ok
Record 159: 2 byte(s) readed - Ok
Record 160: 2 byte(s) readed - Ok
Record 161: 1 byte(s) readed - Ok
Record 162: 1 byte(s) readed - Ok
Record 163: 1 byte(s) readed - Ok
Record 164: 1 byte(s) readed - Ok
Record 165: 1 byte(s) readed - Ok
Record 166: 1 byte(s) readed - Ok
Field [26] 2 Record(s)
Record 0: 16 byte(s) readed - Ok
Record 1: 68 byte(s) readed - Ok
Field [31] 1 Record(s)
Record 4: 14 byte(s) readed - Ok
Field [42] 27 Record(s)
Record 1: 12 byte(s) readed - Ok
Record 2: 36 byte(s) readed - Ok
Record 3: 36 byte(s) readed - Ok
Record 4: 36 byte(s) readed - Ok
Record 5: 36 byte(s) readed - Ok
Record 6: 36 byte(s) readed - Ok
Record 7: 40 byte(s) readed - Ok
Record 8: 40 byte(s) readed - Ok
Record 9: 40 byte(s) readed - Ok
Record 10: 40 byte(s) readed - Ok
Record 11: 40 byte(s) readed - Ok
Record 12: 40 byte(s) readed - Ok
Record 13: 40 byte(s) readed - Ok
Record 14: 40 byte(s) readed - Ok
Record 15: 40 byte(s) readed - Ok
Record 16: 40 byte(s) readed - Ok
Record 17: 40 byte(s) readed - Ok
Record 18: 40 byte(s) readed - Ok
Record 19: 40 byte(s) readed - Ok
Record 20: 40 byte(s) readed - Ok
Record 21: 40 byte(s) readed - Ok
Record 22: 40 byte(s) readed - Ok
Record 23: 40 byte(s) readed - Ok
Record 24: 40 byte(s) readed - Ok
Record 25: 40 byte(s) readed - Ok
Record 26: 40 byte(s) readed - Ok
Field [44] 1 Record(s)
Field [50] 1 Record(s)
Field [54] 2 Record(s)
Record 2: 24 byte(s) readed - Ok
Field [88] 1 Record(s)
Record 0: 36 byte(s) readed - Ok
Field [96] 2 Record(s)
Record 1: 20 byte(s) readed - Ok
Field [107] 7 Record(s)
Record 0: 21 byte(s) readed - Ok
Record 1: 89 byte(s) readed - Ok
Record 2: 69 byte(s) readed - Ok
Record 3: 70 byte(s) readed - Ok
Record 24: 88 byte(s) readed - Ok
Record 25: 136 byte(s) readed - Ok
Record 26: 12 byte(s) readed - Ok
Field [116] 17 Record(s)
Field [117] 11 Record(s)
Record 1: 3 byte(s) readed - Ok
Record 2: 6 byte(s) readed - Ok
Record 3: 1 byte(s) readed - Ok
Record 4: 9 byte(s) readed - Ok
Record 5: 10 byte(s) readed - Ok
Record 8: 44 byte(s) readed - Ok
Record 13: 3 byte(s) readed - Ok
Record 14: 3 byte(s) readed - Ok
Field [120] 4 Record(s)
Record 0: 944 byte(s) readed - Ok
Record 1: 160 byte(s) readed - Ok
Record 2: 130 byte(s) readed - Ok
Record 3: 112 byte(s) readed - Ok
Field [153] 6 Record(s)
Record 0: 68 byte(s) readed - Ok
Record 2: 68 byte(s) readed - Ok
Record 3: 68 byte(s) readed - Ok
Record 4: 68 byte(s) readed - Ok
Record 5: 68 byte(s) readed - Ok
Field [163] 1 Record(s)
Record 0: 8 byte(s) readed - Ok
Field [193] 4 Record(s)
Record 2: 8 byte(s) readed - Ok
Record 3: 32 byte(s) readed - Ok
Record 4: 32 byte(s) readed - Ok
Record 9: 64 byte(s) readed - Ok
Field [217] 1 Record(s)
Field [218] 1 Record(s)
Field [232] 3 Record(s)
Record 0: 20 byte(s) readed - Ok
Field [238] 1 Record(s)
Record 1: 1 byte(s) readed - Ok
Field [239] 3 Record(s)
Record 1: 3176 byte(s) readed - Ok
Record 2: 3176 byte(s) readed - Ok
Field [250] 4 Record(s)
Record 1: 2416 byte(s) readed - Ok
Record 2: 128 byte(s) readed - Ok
Record 3: 804 byte(s) readed - Ok
Record 4: 40 byte(s) readed - Ok
Field [291] 1 Record(s)
Record 0: 92 byte(s) readed - Ok
Field [301] 17 Record(s)
Field [308] 9 Record(s)
Record 1: 8192 byte(s) readed - Ok
Field [309] 8 Record(s)
Record 2: 12 byte(s) readed - Ok
Record 4: 12 byte(s) readed - Ok
Record 5: 12 byte(s) readed - Ok
Record 7: 12 byte(s) readed - Ok
Record 17: 12 byte(s) readed - Ok
Field [319] 8 Record(s)
Record 0: 148 byte(s) readed - Ok
Record 1: 148 byte(s) readed - Ok
Record 2: 148 byte(s) readed - Ok
Record 3: 148 byte(s) readed - Ok
Record 4: 148 byte(s) readed - Ok
Record 5: 148 byte(s) readed - Ok
Record 6: 148 byte(s) readed - Ok
Record 7: 148 byte(s) readed - Ok
Field [320] 39 Record(s)
Record 8: 148 byte(s) readed - Ok
Record 9: 148 byte(s) readed - Ok
Record 10: 148 byte(s) readed - Ok
Record 11: 148 byte(s) readed - Ok
Record 12: 148 byte(s) readed - Ok
Record 13: 148 byte(s) readed - Ok
Record 14: 148 byte(s) readed - Ok
Record 15: 148 byte(s) readed - Ok
Record 16: 148 byte(s) readed - Ok
Record 17: 148 byte(s) readed - Ok
Record 18: 148 byte(s) readed - Ok
Record 19: 148 byte(s) readed - Ok
Record 20: 148 byte(s) readed - Ok
Record 21: 148 byte(s) readed - Ok
Record 22: 148 byte(s) readed - Ok
Record 23: 148 byte(s) readed - Ok
Record 24: 148 byte(s) readed - Ok
Record 25: 148 byte(s) readed - Ok
Record 26: 148 byte(s) readed - Ok
Record 27: 148 byte(s) readed - Ok
Record 28: 148 byte(s) readed - Ok
Record 29: 148 byte(s) readed - Ok
Record 30: 148 byte(s) readed - Ok
Record 31: 148 byte(s) readed - Ok
Record 32: 148 byte(s) readed - Ok
Record 33: 148 byte(s) readed - Ok
Record 34: 148 byte(s) readed - Ok
Record 35: 148 byte(s) readed - Ok
Record 36: 148 byte(s) readed - Ok
Record 37: 148 byte(s) readed - Ok
Record 38: 148 byte(s) readed - Ok
Field [322] 1 Record(s)
Field [329] 1 Record(s)
Record 0: 8392 byte(s) readed - Ok
Field [334] 1 Record(s)
Field [339] 2 Record(s)
Record 0: 511 byte(s) readed - Ok
Record 1: 511 byte(s) readed - Ok
Field [341] 3 Record(s)
Record 4: 4392 byte(s) readed - Ok
Field [354] 1 Record(s)
Record 0: 3 byte(s) readed - Ok
Field [355] 1 Record(s)
Record 0: 11514 byte(s) readed - Ok
Field [356] 2 Record(s)
Record 1: 8 byte(s) readed - Ok
Field [362] 2 Record(s)
Record 1: 120 byte(s) readed - Ok
Field [364] 27 Record(s)
Field [365] 17 Record(s)
Field [369] 1 Record(s)
Record 0: 40 byte(s) readed - Ok
Saved as C:\InfinityBox\BEST\Backup\6700\RM-470 Nokia 6700 classic_352696043985596_0_400.pm
Done!
Elapsed: 00:00:04
Reading Product Profile sets...
0 - 127
1 - 1
4 - 0
7 - 1
9 - 0
34 - 0
35 - 0
41 - 1
48 - 1
56 - 0
58 - 0
61 - 0
65 - 0
66 - 0
69 - 1
70 - 1
71 - 1
73 - 2
78 - 0
79 - 1
100 - 1
130 - 5
131 - 7
135 - 0
138 - 0
139 - 1
141 - 1
143 - 1
145 - 0
146 - 0
147 - 0
156 - 0
157 - 1
158 - 1
164 - 1
165 - 0
166 - 0
168 - 0
177 - 0
183 - 0
184 - 2
185 - 0
192 - 0
193 - 0
202 - 3
205 - 0
206 - 0
211 - 0
212 - 0
214 - 0
217 - 0
219 - 1
220 - 0
228 - 0
SETS 1
Readed 54 element(s)
Saved as C:\InfinityBox\BEST\Backup\6700\RM-470 Nokia 6700 classic_352696043985596.pp
Done!
Elapsed: 00:00:00
Reading LifeTimer data...
LifeTime is: 235700 seconds
Phone works: 65 Hours; 28 minutes; 20 seconds
Done
Reading Product code...
Done!
Phone disconected!
Phone found!
read info... - Ok
User ACCEPTED FULL ERASE
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
ADL: Check mode
Select ASIC [C900]
Reading NPC certificate...
Reading CCC certificate...
Reading HWC certificate...
Reading R&D certificate...
Reading VARIANT certificate...
Reading PARTNERC certificate...
Reading MDM_KEYS certificate...
Cert Read done!
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : c:\InfinityBox\BEST\Backup\Cert\352696043985596_CRT.rpl
ADL: Preparing for erase...
Full Erase started...
Asic : CMT , Sub : NAND
Erase Area 0x00000000-0x0FFFFFFF
Erasing Ok , [0F]
Erase done , time : 00:00:04
ADL: Erase done
ADL: Close_Session
Content: 000205000000000000FFFF00000000
ADL: Reboot
Phone disconected!
Check files done...
-> SWversion check skipped : Dead mode selected
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : blank (Erased or HW failure)
ADL: phone is in flash mode
Backup enabled, will read all certificates...
- > No any CRT data (MCU damaged/CERT erased), skip saving
===Flashing [MCU]===
Erase : Processing rm470__13.10.mcusw
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:05
Write : Processing rm470__13.10.mcusw
CMT: Writing Hash CERT [ADA]
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [RAP3NAND]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [UPDAPP]
CMT: Writing Hash CERT [DSP0]
CMT: Writing Hash CERT [LDSP]
CMT: Writing Hash CERT [MCUSW]
CMT: Writing Hash CERT [ISA+DYNSW]
Total writen 218 blocks
TIME : Write time : 00:00:09
MCU Write done
ADL: Request programm status
NAND status : 00000006 / 00000006 / 00000000
===Flashing [PPM]===
Erase : Processing rm470__13.10.ppm_b
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:00
Write : Processing rm470__13.10.ppm_b
Total writen 47 blocks
TIME : Write time : 00:00:02
PPM Write done
===Flashing [CNT]===
Erase : Processing rm470__13.10_ISM_018.image_b_pl_chrome
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:07
Write : Processing rm470__13.10_ISM_018.image_b_pl_chrome
Total writen 205 blocks
CNT Write done
ADL: Close_Session
ADL: Reboot
Flashing done!
Total flash time : 00:00:34
Reboot phone now...
Will Write CCC/HWC keys now...
No any file selected, break operation
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
Seek file for this phone....
- > RPL file found for this phone!
- > NPC Found in : 352696043985596_CRT.rpl
Check RPL file...
NPC Data found! (CMT)
CCC Data found! (CMT)
HWC Data found! (CMT)
ADL: Check mode
Select ASIC [C900]
ADL: Preparing for write certificates...
ADL: Writing Flash certs done! :)
ADL: Close_Session
Content: 00060E4E5043000000000000000000
ADL: Reboot
-> No any Flex keys selected or found, skip flex part
Done!
Will Write RPL keys now...
Check RPL file...
SimLock Data found!
SimLock key found!
WMDRM key found!
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
ADL: Check mode
Select ASIC [C900]
ADL: Close_Session
ADL: Reboot
Phone not found... :(
CertWrite failed : phone was not bootup
Connection/SW/HW problem, try bootup manually
If phone bootup Ok - write only flex keys
Phone disconected!
Check RPL file...
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
TIME : Boot time : 00:00:02
ADL: Check mode
Select ASIC [C900]
ADL: Close_Session
ADL: Reboot
-> No any Flex keys selected, skip flex part
Done!
Phone disconected!
- > AfterFlash Failed! :( Reason : Downgrade try or HW Error
Anyway - try reinsert battery and PowerUp phone manualy
Done!
Elapsed: 00:01:01
Check RPL file...
SimLock Data found!
SimLock key found!
WMDRM key found!
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
ADL: Check mode
Select ASIC [C900]
ADL: Close_Session
ADL: Reboot
Failed init Test mode... :(
Phone disconected!
Using : 352696043985596_CRT.rpl
CCC Data found!
HWC Data found!
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
ADL: Check mode
Select ASIC [C900]
ADL: Close_Session
Content: 00060E434343000000000000000000
ADL: Reboot
All done, disconneting...
Done!
Elapsed: 00:00:33
Using : 352696043985596_SIM.rpl
- > File damaged, break operation
Check RPL file...
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
ADL: Check mode
Select ASIC [C900]
ADL: Close_Session
ADL: Reboot
Done!
Phone disconected!
Check RPL file...
SimLock Data found!
SimLock key found!
WMDRM key found!
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
ADL: Check mode
Select ASIC [C900]
ADL: Close_Session
ADL: Reboot
Phone disconected!
Check RPL file...
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
ADL: Check mode
Select ASIC [C900]
ADL: Close_Session
ADL: Reboot
Done!
Phone disconected!
Connect phone on selected interface... |
| | #127 (permalink) |
| Whats wrong with forum? How it is possible to get empty post? I have try to downgrade 6700c via USB using Best v1.44... Phone is semi dead. What i did wrong? LOG: Code: Connect phone on selected interface...
Phone found!
read info... - Ok
Long Prod.SN : 0
HWID : 1009
Retu : 34
Tahvo : 00
Batery: 4084 mV
CMT BT: 410B-v190
LCDVer: TPO
Blocks : 7
LOCK STATUS :
BLK : 1
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS : All Open
SDD key status : Ok
SimLock status : Ok
User Code : 12345
Done!
WMDRM read ... ok
Reboot....
Try again...
Phone disconected!
Phone found!
read info... - Ok
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
ADL: Check mode
Select ASIC [C900]
ADL: Close_Session
ADL: Reboot
Key file updated...
Done!
Phone found!
read info... - Ok
Done!
Reading Values...
Currency: 171 mA
Temp: 25 C
Done!
Check files done...
WMDRM read ... ok
ADL req restart
Done!
Elapsed: 00:00:04
0 - 127
1 - 1
4 - 0
7 - 1
9 - 0
34 - 0
35 - 0
41 - 1
48 - 1
56 - 0
58 - 0
61 - 0
65 - 0
66 - 0
69 - 1
70 - 1
71 - 1
73 - 2
78 - 0
79 - 1
100 - 1
130 - 5
131 - 7
135 - 0
138 - 0
139 - 1
141 - 1
143 - 1
145 - 0
146 - 0
147 - 0
156 - 0
157 - 1
158 - 1
164 - 1
165 - 0
166 - 0
168 - 0
177 - 0
183 - 0
184 - 2
185 - 0
192 - 0
193 - 0
202 - 3
205 - 0
206 - 0
211 - 0
212 - 0
214 - 0
217 - 0
219 - 1
220 - 0
228 - 0
SETS 1
Done!
Elapsed: 00:00:00
Done
Done!
Phone disconected!
Phone found!
read info... - Ok
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
ADL: Check mode
Select ASIC [C900]
Cert Read done!
Erasing Ok , [0F]
ADL: Erase done
ADL: Close_Session
ADL: Reboot
Phone disconected!
Check files done...
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
ADL: Check mode
Select ASIC [C900]
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
MCU Write done
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
PPM Write done
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
CNT Write done
ADL: Close_Session
ADL: Reboot
Flashing done!
Reboot phone now...
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
Check RPL file...
ADL: Check mode
Select ASIC [C900]
ADL: Close_Session
ADL: Reboot
Done!
Check RPL file...
SimLock Data found!
SimLock key found!
WMDRM key found!
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
ADL: Check mode
Select ASIC [C900]
ADL: Close_Session
ADL: Reboot
Phone disconected!
Check RPL file...
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
ADL: Check mode
Select ASIC [C900]
ADL: Close_Session
ADL: Reboot
Done!
Phone disconected!
Done!
Elapsed: 00:01:01
Check RPL file...
SimLock Data found!
SimLock key found!
WMDRM key found!
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
ADL: Check mode
Select ASIC [C900]
ADL: Close_Session
ADL: Reboot
Phone disconected!
CCC Data found!
HWC Data found!
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
ADL: Check mode
Select ASIC [C900]
ADL: Close_Session
ADL: Reboot
Done!
Elapsed: 00:00:33
Check RPL file...
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
ADL: Check mode
Select ASIC [C900]
ADL: Close_Session
ADL: Reboot
Done!
Phone disconected!
Check RPL file...
SimLock Data found!
SimLock key found!
WMDRM key found!
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
ADL: Check mode
Select ASIC [C900]
ADL: Close_Session
ADL: Reboot
Phone disconected!
Check RPL file...
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done! :)
ADL: Check mode
Select ASIC [C900]
ADL: Close_Session
ADL: Reboot
Done!
Phone disconected!
| | #128 (permalink) |
| Very funny.My last posts are empty and now i know how to do it ![]() Back to my problems; Should i unmark "Safe Rapido" during Full Erase flash? I still need to downgrade 6700c. |
| | #130 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2011
Member: 1645194 Status: Offline Thanks: 219
| The working ENO file for c7 rm675 firmware version 14.2 rm675_ENO_v_0.0491_APEONLY.fpsx that's file not exit on navifirm and this file solved my problem about star-up failed regards |
| | #135 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2004 Age: 27
Member: 55800 Status: Offline Thanks: 1
| i not sure if this help if possible, can always make it sticky , i tried a few time if phones doesn't goes into local mode at however method . but you are very sure that your phone is in working condition ( before you flash it ) . Check whether your memory card is insert . take it out. it's always works for me and it used to torture me until i find out this solution . |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to add a language in 51xx/61xx | tati | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 8 | 05-21-2013 19:20 |
| How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 28 | 08-30-2012 03:40 |
| How can I do a Welcome note for my 6110 a dosn't have any one ? | Viper | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 07-18-2012 07:57 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 06-10-1999 22:36 |
