07-28-2012, 11:15 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: India Age: 37
Member: 1750704 Status: Offline Thanks Meter: 12,171 | Imei crupt of c5 after flash and not write again gaving error registered to: harish gulati Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia C5-00 Software ver : V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia IMEI : 12345610654321? Ape Ver : 071.005 APE Var : 071.005071.005.21.01071.005.C00.01 APE ADSP: 256 DSP Ver : ICPR82_11w16 APE Test: 10wk48v0.001_APEONLY PPM : CNT : Product SN : 241A0C7AA Product code : 0593436 Base Prd.code: 0596394 Module code : 0204492 Long Prod.SN : 0 Hardware info======= HWID : 6502 Retu : 35 Tahvo : 00 Batery: 3694 mV APE HW: 256 Lock info =========== IMEI : 12345610654321? IMEI spNet : 1A 32 54 16 60 45 23 01 IMEI svNet : 13 32 54 16 60 45 23 11 F5 Unable to read Lock table... IMEI DAMAGED!!! CRT308 save skipped... SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) -> Skip Flash keys Part, for Flash Part use Dead Mode or Fbus Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia C5-00 Software ver : V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia IMEI : 12345610654321? Ape Ver : 071.005 APE Var : 071.005071.005.21.01071.005.C00.01 APE ADSP: 256 DSP Ver : ICPR82_11w16 APE Test: 10wk48v0.001_APEONLY PPM : CNT : Product SN : 241A0C7AA Product code : 0593436 Base Prd.code: 0596394 Module code : 0204492 Long Prod.SN : 0 Hardware info======= HWID : 6502 Retu : 35 Tahvo : 00 Batery: 3692 mV APE HW: 256 Lock info =========== IMEI : 12345610654321? IMEI spNet : 1A 32 54 16 60 45 23 01 IMEI svNet : 13 32 54 16 60 45 23 11 F5 Unable to read Lock table... IMEI DAMAGED!!! CRT308 save skipped... SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Phone disconected! Connect phone on selected interface... Last edited by Mohsin-*; 07-28-2012 at 21:54. |
07-28-2012, 11:26 | #2 (permalink) |
Member: 1750704 Status: Offline Thanks Meter: 12,171 | AND AFTER DO THIS STEP MY SET GONE DEAD http://forum.gsmhosting.com/vbb/f641...maged-1511678/ PZ PROVIDE SOL SIR W8ING FOR UR REP |
07-28-2012, 11:30 | #3 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 449069 Status: Offline Thanks Meter: 61 | Upload flashing logs Upload Backup(PM & RPL) for checkup too. PS: Use normal font colour. Edit: Easiest way if you have backup then full erase, Full flash & Restore backups(RPL & PM) |
07-28-2012, 11:42 | #4 (permalink) |
Member: 1750704 Status: Offline Thanks Meter: 12,171 | Take this i found only this back up nothing else i have whn i flash set set is in on condition but now dead and whn it comes in local mode and i try to write bck up then set goes dead again |
07-30-2012, 06:51 | #10 (permalink) |
No Life Poster Join Date: Oct 2009 Location: srilanka Age: 39
Member: 1133072 Status: Offline Thanks Meter: 505 | |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
