07-22-2016, 13:03 | #1 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Europe
Member: 2075739 Status: Offline Sonork: 100.1640499 Thanks Meter: 237 | BEST 2.23 Confugurator used still error 60 Config is on latest BEST version and configurator.exe used. Tried different ENOs, still same effect, any ideas pls? Log: [WP8x] : Init TesMode [TSTM] : Use File : RM1019_2074.0000.9651.14234.207.692_enosw-wim-signed_803881.secwim Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device catched in BOOT mode! Boot Mode confirmed! Setting Preloder Collect Info... Setting Application Setting Secure Collect Info... === Nokia Flash App info : Protocol Version : 2.34 Protocol Implementation : 2.59 === Phone Initial info : Phone RMxxx ID : RM-1019 Phone Model ID : Nokia.MSM8212.P6134.1.1 Phone Model PC : 059W6V6 Phone IMEI : 356473066132845 === eMMC info : eMMC Vendor : Samsung eMMC CID : 0015 eMMC Size : 3728 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : 6DF7F89E7A01F5B5DCB54754545B30B8B036C6BD === Other info : SD present : False SECWIM : RM1019_2074.0000.9651.14234.207.692_enosw-wim-signed_803881.secwim Sending WIM ... WIM Image sent! Trying init TestMode now... Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Card serial: 38596963 Card type: BEST Dongle Card password: xxx Link to my account: http://user.infinity-best.com Login: 03A7C0755F Connecting to server... Credits: xxx Check SimLock info Conf key : 8000000000000000 Provider key : 2163000000000000 Country : Hungary Operator : T-Mobile H Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= Done! SD Authentification : not done Local SX4 Card Not Found, wil use Server Started Connecting to SX4 server... Connected SX4 enter .. SDAuth Ok! SX4 Disconnected SX4 Done! Done! WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Card serial: 38596963 Card type: BEST Dongle Card password: xxx Link to my account: http://user.infinity-best.com Login: 03A7C0755F Connecting to server... Credits: xxx WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Some ideas please? |
07-23-2016, 07:58 | #5 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | Quote:
07-26-2016, 09:01 | #6 (permalink) | |
Member: 2075739 Status: Offline Sonork: 100.1640499 Thanks Meter: 237 | Quote: I would like the answer from the team. What do you suppose the problem is? Is there any problem with some firmware being unlockable and others not? I would like to know what to look for. | |
07-26-2016, 10:54 | #7 (permalink) |
Product Supporter Join Date: Mar 2005 Age: 44
Member: 128745 Status: Offline Thanks Meter: 16,936 | this is 100% working solution Solution to unlock phones which give error 0060 1) full flash the phone using the firmware FFU : RM974_02040.00021.15235.30008_RETAIL_prod_signed_1 080_02D51C_000-GB.ffu 2) you must have the following tick marked before start flashing a) Change PC and NVI ( very important ) 3) after flashing Unlock the phone 4) TIP : if you can not find the same firmware. download any firmware which DOES NOT have the following product code ( MOST IMPORTANT) 1 059W8Q7 2 059W8V0 3 059W8V6 4 059W913 |
