10-10-2015, 09:52 | #1 (permalink) |
No Life Poster Join Date: Dec 2013 Location: Uzbekistan/Tashkent
Member: 2082192 Status: Offline Sonork: not Thanks Meter: 1,119 | With BEST Dongle CM2 Success Reports: SPD/Spreadtrum Micromax Q324 BOLT SPD CPU : SC7731 Read pattern lock done |
10-10-2015, 10:34 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Thank you very much for good test report ! Please post test reports with CM2 software in these threads: http://forum.gsmhosting.com/vbb/f296...iatek-1862422/ http://forum.gsmhosting.com/vbb/f296...-chip-1999852/ http://forum.gsmhosting.com/vbb/f296...dtrum-1862960/ http://forum.gsmhosting.com/vbb/f296...lsand-1821845/ Thank you ! |
12-08-2015, 11:12 | #3 (permalink) |
Member: 2082192 Status: Offline Sonork: not Thanks Meter: 1,119 | With BEST Dongle CM2 Micromax Q324 BOLT Read info/Read NVM/Read Factory Firmware/Write Flash done SPD CPU : SC7731 Read Info Code: Operation : Check/Read Info [ v1.07 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 10 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : Q324 Model Brand : Micromax Model Device: Q324 AndrVersion : 4.4.3 BaseBand CPU: SP7731GEA CompileDate : 1428140737 Project Ver : MMX_Q324_RUS_SW_1.0.7_HW_4.0.0_20150323 Model Ext : Micromax Q324 ExtraInfo : HWInfo exists!!! This phone have DYNAMIC HW settings!!! ExtraInfo : GSM Phone Elapsed: 00:00:08 Reconnect Power/Cable! Code: Operation : Read NV [ v1.07 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 10 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Read NVM Part #1 Part Ok Read NVM Part #2 Part Ok Saved to : C:\InfinityBox\CM2SPD\phdata\backup\CX_SPDNV.spdnv Elapsed: 00:00:26 Reconnect Power/Cable! Read Factory Flash Code: Operation : Read FullFlash [ v1.07 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 10 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Passed! Phone found! [ 10 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : Q324 Model Brand : Micromax Model Device: Q324 AndrVersion : 4.4.3 BaseBand CPU: SP7731GEA Project Ver : MMX_Q324_RUS_SW_1.0.7_HW_4.0.0_20150323 Model Ext : Micromax Q324 [Read Mode] : HSUSB Enabled! [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731g_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem.bin [Read Ok] : sc7731g_modem_CP2_WCN_14E_W14.50_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x800.bin [Read Ok] : hwinfo.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img Firmware Size : 841 MiB Saved to : C:\InfinityBox\CM2SPD\phdata\backup\SP7731GEA_Q324_4.4.3_MMX_Q324_RUS_SW_1.0.7_HW_4.0.0_20150323\ Done! Elapsed: 00:12:44 Reconnect Power/Cable! Code: Operation : Flash [ v1.07 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 10 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x18 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Write CodeData : sc7731g_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc7731g_modem_CP2_WCN_14E_W14.50_Release.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : logo_480x800.bin Write Data ... Write Data Ok! Write CodeData : hwinfo.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Process : Flush Flush Ok! Write FSImage : userdata.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Erase Block : INTERNALSD Erase block ... Block erase Ok! Elapsed: 00:03:17 Reconnect Power/Cable! Thanks to Pavel bro (JayDi) |
03-09-2017, 08:23 | #5 (permalink) |
Major Poster Join Date: Jun 2012 Location: ujiouoioliop Age: 39
Member: 1778446 Status: Offline Thanks Meter: 34 | |
