04-29-2016, 18:48 | #1 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2548351 Status: Offline Thanks Meter: 0 | best dongle not take automatic RPL backup need help please I used best dongle to flash Nokia 108 before and its ok this time I used to flash 108 Nokia after that gave me contact service I tried to read RPL after flash and rewrite it but say RPL not match what I can do please please update best dongle software to take automatic RPL backup for flash errors and also how can write a backup flash read by it as a bin file what is mean to backup flash but can't write it again I sent email to rd [at] infinity-box [dot] com and to ios [at] infinity-box [dot] com , no answer until now thanks any way |
04-30-2016, 08:05 | #2 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Quote:
But one very interest thing - BEST NOT DAMAGE RPL DURING FLASHING. I sure in that. So, if it say - wrong RPL and not match with BBID in phone - not try cheat support as it SW fault. Select CORRECT backup, or tell complete story. I know how can such phones die - it will die after flashing with shinese sh*it boxes, which kills those phones completely. Seems as you got blinking keyboard phone, flashed it, it On, but you met CS, then you read RPL, write it back and BEST give error about mobile ID inside RPL differes. | |
04-30-2016, 15:27 | #4 (permalink) | |
Member: 2548351 Status: Offline Thanks Meter: 0 | Quote:
and please tell me how to write complete flash backup as bin file I know rpl write after backup thanks complete story some one bring nokia 108 and say the mobile in sometimes hang up and say need to flash it ok take it and flash it using best dongle and truly not open it before flash and after flash open it and say contact service then I tried to search about this problem they say without rpl backup the phone is dead and I didn't take rpl backup before flash and tried to read rpl after flash and write it again say not match and also after read info say security damaged what I can do thanks and I just need best dongle to take automatic rpl just in case we don't do it thanks again | |
04-30-2016, 19:50 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | 1. Your faults : - Not checked INITITAL mobile state. What if customer bring you some... Lumia phone ( like 950 ) and say " It sometimes stuck , flash it " - you flash it and get in result "stuck on gears" or "airplane mode" bug , which made by user, not you. Then you must paid for a phone. Or repair it by yourself. And it VERY coustly phone. - BAD theory knowledge. You not understand basic and trying collect info by a fact - in result you have just a half of answers/problem explanations, which are not belongs to your one. 2. With that phone : 1. Where is LOGS? I not a extrasense to see them on your HDD. They made exactly for problem cases. 2. Theory. You don't know it well. Back to P1.2 BEST NOT and CAN'T touch RPL during flashing. That is why backup not eanbled during flashing ( it was some time ago, but due some technical reasons it now possible to made only separately. Vendors trying protect phones much, as they can ) |
05-01-2016, 13:04 | #6 (permalink) | |
logs not here because I am in vacation I will brings them later just I want to know if best can do any thing to rpl you reply to me best don't do that (thanks for your reply) please answer me how can write backup full flash (bin file) Thanks for your time | |
05-02-2016, 12:07 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | 1. There is button for RPL read. 2. BEST not write and will not write BIN files. During bin read BEST also make RPL backup. So, if RPL inside that bin damaged already ( seems as it after some chinese tool sh*it ) - bin will change nothing. Anyway - that all is nothing without logs. |
05-03-2016, 18:35 | #8 (permalink) |
Member: 2548351 Status: Offline Thanks Meter: 0 | there is the log Core : v2.21 , MTKx FlashEngine : v9.8 Verify files ... MAUI : RM-944_ROM_eMP_12.06.11 VIVA : RM-944_VIVA_eMP_12.06.11 LANG : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 CUST : RM-944_CUSTPACK_ROM_IC_MEA_SA_eMP_12.06.11 JMPT : RM-944_JUMP_TABLE_IC_MEA_SA_eMP_12.06.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 43 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 0A6CC0E8F7B1E0735B1AED89B3D1C685 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.12.06.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree(dot)fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_12.06.11 SecureDecrypt : RM-944_VIVA_eMP_12.06.11 SecureDecrypt : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 SecureDecrypt : RM-944_CUSTPACK_ROM_IC_MEA_SA_eMP_12.06.11 SecureDecrypt : RM-944_JUMP_TABLE_IC_MEA_SA_eMP_12.06.11 OVRLP : 000069B900000001 PHPID : Bree.12.06.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_ROM_eMP_12.06.11 Write : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 Write : RM-944_CUSTPACK_ROM_IC_MEA_SA_eMP_12.06.11 Write : RM-944_JUMP_TABLE_IC_MEA_SA_eMP_12.06.11 Write : RM-944_VIVA_eMP_12.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_ROM_eMP_12.06.11 [VERIFY] DONE : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_IC_MEA_SA_eMP_12.06.11 [VERIFY] DONE : RM-944_JUMP_TABLE_IC_MEA_SA_eMP_12.06.11 [VERIFY] DONE : RM-944_VIVA_eMP_12.06.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:00 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds there is read info Reading Phone Info.... Software ver : 12.06.11 00-00-00 RM-944 IMEI 1 : 123456789012345 IMEI 2 : 123456789012345 XappVer : 000008A2 Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : IC CNT : Bree.12.06.11.p1 Product SN : 2F62710BH Product code : 059S7R0 Base Prd(dot)code: 059S0R7 Module code : 0205624 Hardware info======= HWID : 1001 LCDVer: TPO Lock info =========== IMEI : 123456789012345 IMEI spNet : 0A 00 00 00 00 00 00 00 Lock info: SimLock status : Ok Security status : Damaged!!!!! Done! Last edited by easd; 05-03-2016 at 18:41. |
05-03-2016, 18:40 | #9 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I have asked about logS, not just a flashing log. Need also "Read RPL" or "Read Flash" log, when you made it first time ( according your words - you made flash read before ) |
05-03-2016, 21:27 | #11 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Check your back sticker IMEI. When you read BIN dump there was already : 359186052173162 If it not as back sticker - that mean someone flashed in that phone other dump already. |
05-04-2016, 16:26 | #12 (permalink) | |
IMEI 1:355755/06/446130/4 IMEI 2:355755/06/446131/2 thanks what can I do? thanks again | |
05-04-2016, 16:36 | #13 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Someone already flashed it with other phone dump before you made backup from it. Right now - it piece of plastic. Probably, there will be some repair stuff, but really can't say any ETA. Next few updates will bring just CS repair ( contact service, security fix and simlock fix ) in case of not damaged by writing whole dump phones. But it not applicable for your case. |
