06-30-2013, 12:54 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Best dongle software ver 1.65 does not connect with xgold mobiles via Loacl mode |
06-30-2013, 14:27 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Problem in bad reading. Few version ago I was added all, what needed for that. Called XG213 forensic. Problem not in BEST, but it can solve it without flashing and can extract code in few seconds. |
06-30-2013, 16:23 | #5 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Read my post again. Few times. Read? Read again few times. Go to Updates and News section. Read near 10 version update log. Try analyze. Read my previous post again. Hope, it will be fully clear now. P.S. good idea hide your sn from me, I still remember all |
06-30-2013, 16:46 | #6 (permalink) |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | I also remember everything but that was past ... I am user of your product...Hiding my serial number..that is not big deal .. you are the main coder..I got no issues with it and since than I always admit i was wrong.. you can ask moulusky... Yes I read all post again.. You said problem in reading... I can assume it is because of drivers issue or conflict..I am not a expert in it ... Atleast point me to anything i should diagnose ... |
06-30-2013, 17:10 | #9 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Not need try. It work. Not matter, stuck phone in local or not. BEST will read full RPL and user code. |
The Following 2 Users Say Thank You to Dzirt For This Useful Post: |
07-05-2013, 17:05 | #10 (permalink) |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Dzirt I faced same problem in nokia x2-02 again... And now I have realized that when mobile in locl mode best software hangs on it... It was tricky for me.. Finally I used UFS selected C2-00 and press check option after detecting it automatically entered into local mode I changed mode manually to test mode at that time it was detected into best software... And I did Ui setting and done... So I don;t know is it a bug or what.. Kindly FIx it ... Note: I used your mention trick read full flash but at that time it enterd into local mode and hang again... Reagrds Zeeshan |
07-06-2013, 10:40 | #11 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | So, THIS TRICK READ ALL , WHAT you can read FROM MOBILE IN LOCAL! That is what I not care about such phones. If you not want such way and want enter it to local - flash mcu, and it will enter in local and not hang. Code: Connect phone on selected interface... Executing FastRead Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd : Custom 2nd boot Ok, 01 2nd ready, AA Sending Algo ALG : Custom Algo sent Ok BL : Quantum_Bootloader_2.5_M1S1 Boot done! ===== USER CODE ===== Executing Code extraction... - > Phone Lock Code : 12345 ===== RPL DATA ===== Executing RPL Data extraction... SL3 Simlock found (XGOLD) ... WMDRM Key found ... CMLA Key found ... IMEI 1 : 354571054192481 IMEI 2 : 354571054192499 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\354571054192481_XG213.rpl Connect phone on selected interface... |
The Following User Says Thank You to Dzirt For This Useful Post: |
