05-05-2013, 16:04 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | best team needed u r help plz me lost my back up . here is rpl back up http://www.4shared.com/zip/CsfKOtLe/...B0002D150.html than me try to write with best dongle but same after writting here is logs best dongle card found: S/N ????????????22 registered to: sale??????01 Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001060 PUBLIC ID: 14100014E8DD0344157E7FC67790A8723CD31B54 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 ADL: Preparing for write certificates... Erase NPC... Ok Writing NPC... Ok Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot -> No any Flex keys selected, skip flex part Done! Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia N8-00 Software ver : V 79_sr1_12w18.5 27-07-12 RM-596 (c) Nokia IMEI : 12345610654321? Ape Ver : 111.040.1511 APE Var : 111.040.1511111.040.1511.01.01111.040.1511.C00.01 APE ADSP: 256 DSP Ver : 92_12w18 APE Test: 0.162 PPM : CNT : Product SN : 0 Product code : Long Prod.SN : 0 Hardware info======= HWID : Retu : 40 Tahvo : 00 Batery: 3704 mV APE BT: HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. APE HW: 256 Lock info =========== IMEI : 12345610654321? IMEI spNet : 1A 32 54 16 60 45 23 01 IMEI svNet : 13 32 54 16 60 45 23 41 F5 Unable to read Lock table... IMEI DAMAGED!!! CRT308 save skipped... SDD key status : Damaged!!!!! CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! |
05-05-2013, 16:40 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. I can't download from 4shared. I recommend you put all other backups to BEST/Backup/Cert/ And on Write RPL, when need select RPL file - press Cancel, than press Yes. |
