Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 07-16-2018, 08:10   #151 (permalink)
Member: 130995
Thanks Meter: 35,227
Infinity-Box BEST NK2 v1.03
ATTENTION: To use this software you should copy licence file license_xxxxxxxx.dat from /BEST/ folder to /BEST2/ folder
- Nokia 8 line changes
New restore database for latest firmwares ( up to 439x version )
Revised flashing core
Activated ability to mirror FW version to both partition and select one of them to boot
During Identify now shown A/B SW version info
Other repair features, specified for NK8 Line only, activated
- Other
Fixed flashing issues for devices with different FlashIC sizes
Flashing core revised
More info shown during identify ( EDL/FB )
Change FW naming during reading to SW version info ( factory-like format )
Encryption state during identify revert back, since some models have NON-encrypted FileSystem
Repair Security updated
Info:
- Use Nokia Care Emergency drivers ( same as for Lumia/NXP )
- Latest available firmwares with OLD sec upload to support ( Nokia 2, Nokia 8, Nokia 5 )
- Nokia Android 8 (Oreo) changes :
> From January/February security patches EDL cables NOT work anymore on Nokia 5 and Nokia 6 !
> Security workaround, used before For Nokia 2 and Nokia 8 NOT work with new BootLoader versions!
> When new workaround will be finished, there is left for now just TP ( with device disassembly ) or rare OTA bugs to force EDL/Downgrade bootchain
http://forum.gsmhosting.com/vbb/f641...nside-2350650/
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 07-16-2018, 08:10   #152 (permalink)
Member: 130995
Infinity-Box BEST NK2 v1.04 - Nokia MTK standalone support activated
ATTENTION: To run this software you should copy licence file license_xxxxxxxx.dat from /BEST/ folder to /BEST2/ folder
Nokia MTK standalone support activated !
- Main
MTK SP line support activated !
For now the next features are supported:
Nokia 1: FRT : FRONTIER : TA-1047/TA-1060/TA-1056/TA-1079/TA-1066
Flashing ( Factory/BEST NB0 files )
Dead Boot repair
Reset Settings / FileSystem
Reset FRP
Identify
Repair Security
SP Unlock
Nokia 3: NE1 : ESSENTIAL1 : TA-1020/TA-1028/TA-1032/TA-1038
Reset FRP
Identify
Repair Security
SP Unlock
Nokia 3.1: ES2 : ESSENTIAL2 : TA-1049/TA-1057/TA-1063/TA-1070/TA-1074/
Dead Boot repair
Reset FRP
Identify
Repair Security
SP Unlock
- Other
Info:
- MTK devices support is free and standalone
- Firmwares can be found on support area
- Firmware files need only for flashing, rest operations not require them
- Make sure you select correct files for your device! ( Nokia 3 specific for now )
Discussion and download links - https://www.infinity-box.com/support/?r=100037
Old 09-21-2018, 10:52   #153 (permalink)
Member: 1043909
Thanks Meter: 60,926
Infinity-Box [BEST] NK2 v1.05 - Nokia 3310(2G), Nokia 5.1 and other models support activated
Nokia 3310(2G), Nokia 5.1 and other models support activated !
- Nokia MTK Feature line support activated
- Nokia 3310(2G) line support activated !
Next revision of 3310 (2G) are supported:
Nokia 3310 : RETRO : TA-1008/TA-1030
> Firmware flashing ( Factory/BEST firmware packages )
> Firmware reading
> Format FS / Reset Settings
> Identify ( read complete device info & check/verify security area )
Other models support enabled ( supported in BEST v1.xx line ) :
Nokia 108: RM-944, RM-945, RM-1124
Nokia 220: RM-969, RM-970, RM-971, RM-1125
Nokia 225: RM-1011, RM-1012, RM-1043
Nokia 130: RM-1035, RM-1036, RM-1037, RM-1122
Nokia 215: RM-1110, RM-1111, RM-1112
Nokia 105: RM-1133, RM-1134, RM-1135
Nokia 222: RM-1136, RM-1137
Nokia 230: RM-1172, RM-1173
Nokia 216: RM-1187, RM-1188
Nokia 150: RM-1189, RM-1190
> Firmware reading
Changes from v1.xx line:
Complete protocol rebuild - faster, safer, more stable
FW read/make now direct, do not need additional read/convert operations
FW read now more faster
Devices not stuck in flash mode after some operations
- Nokia 5.1 : CO2 : TA-1061/TA-1075/TA-1076/TA-1081/TA-1088
> Reset FRP
> Identify
> Repair Security
> SP Unlock
Support is standalone, no server and/or credits required !
- Changes/Fixes
> MTK SP line
Fixed BROM mode support
Fixed dead mode flashing
Fixed SP unlock
Improved flashing in MTK mode
Fixed issues with FOTA after flashing
> QLM SP line
Removed legacy servicing methods
Flashing engine updated
- Other
Settings Tab activated
> Setup FeaturePhones DataPackage path
> Setup SmartPhones DataPackage path
> Setup IOS user credentials ( for use server-based operations )
Lot of fixes and global changes at all
- Support
Hundreds of firmwares for Nokia 3310 (2G) are in support area
> Check out for need region packages or language packages on support area first! Or read from any well working device which you have.
Nokia 230: RM-1172, RM-1173 - HMD and MS LEGACY different firmwares are in support area
Nokia 216: RM-1187, RM-1188 - HMD and MS LEGACY different firmwares are in support area
Nokia 150: RM-1189, RM-1190 - HMD and MS LEGACY different firmwares are in support area
Discussion and download links - https://www.infinity-box.com/support/?r=100043
The Following 2 Users Say Thank You to YellowBoss For This Useful Post:
Old 09-26-2018, 09:39   #154 (permalink)
Member: 130995
Infinity-Box [BEST] NK2 v1.06 - FP Forensic and other changes
- Activated Forensic engine for MTK feature line devices
Allow extract phonebook memory from alive/dead/semi-dead devices
Extraction is direct ( from device )
Support unicode
Following models are supported for PhoneBook extraction:
Nokia 3310(2G): TA-1008, TA-1030
- Changes/Fixes
> MTK FP line
Fix/Change: Flash reading on some configurations may fail, fixed
New feature: Activated speed selection setting (see software settings tab) Default value - Normal. Speed TOO MUCH depend on this configuration value !
Fix/Change: Flash engine revised
New feature: Activated complete FlashPackage verification during FWSelect and Flashing
> MTK SP line
Discussion and download links - https://www.infinity-box.com/support/?r=100044
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 10-04-2018, 18:51   #155 (permalink)
Member: 148515
Thanks Meter: 19,534
Infinity-Box [BEST] NK2 v1.07 - Nokia 130 (2017) support and new features
- Nokia 130 (2017) line support activated !
Next revision of Nokia 130 (2017) are supported:
Nokia 130 (2017): KESA : TA-1017/TA-1019
> Firmware reading
- Changes/Fixes
> MTK FP line
Fix/Change: Flash engine revised : Automatic Repair Mode enable, if device semi-dead
Fix/Change: AutoID in case of semi-dead device state may fail, fixed
- Support
Hundreds of firmwares for 130 (2017) have been uploaded to support area
> Check out for required region packages or language packages in support area first! Also you can read from any good working device that you have.
https://www.infinity-box.com/support/?r=100046
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post:
Old 10-15-2018, 13:52   #156 (permalink)
Member: 130995
Infinity-Box [BEST] NK2 v1.08 - Nokia 105 (2017) support and new features
- Nokia 105 (2017) line support activated !
Next revision of Nokia 105 (2017) are supported:
Nokia 105 (2017) : N103 : TA-1010/TA-1034/TA-1037
> Firmware reading
- Changes/Fixes
> MTK FP line
New feature: Firmware Read : Activated extarction of device supported LangPacks during FW read
New feature: "LangPack only change" option for FW flashing activated
Fix/Change: Forensic engine updated
Fix/Change: Flash Read revised
- Support
Hundreds of firmwares for 105 (2017) has been upload to support area
https://www.infinity-box.com/support/?r=100047
Old 11-20-2018, 18:42   #157 (permalink)
Member: 1043909
Infinity-Box [BEST] NK2 v1.09 - FP Forensic and other features
- Forensic engine for MTK feature line devices rebuild from scratch
From now allow extract phonebook from memory dump ( made by external prommer or older BEST versions )
> Press and hold SHIFT key before press "Extract PhoneBook" button for enable File mode
Extraction is direct (from device) and from dump
Support unicode
All existing MTK FP models are supported now for PhoneBook extraction:
Nokia 105(2017) : TA-1010, TA-1034, TA-1037
Nokia 130(2017) : TA-1017, TA-1019
- Changes/Fixes
> MTK FP line
New feature: SW version check during flashing activated. SW will verify data between phone and VPL.
> In case of device dead ( no SW version data available ) - SW will warn about it.
New feature: Complete language info during FlashFile selection ( will show all existing languages without need of manual flashing and verify )
> MTK SP line
Fix/Change : Flash engine revised
Fix/Change : Repartition may fail during NK1 flashing, fixed
https://www.infinity-box.com/support/?r=100055
The Following 3 Users Say Thank You to YellowBoss For This Useful Post:
Old 03-17-2019, 22:25   #158 (permalink)
Member: 148515
Infinity-Box [BEST] NK2 v1.10 - Nokia 3310 3G support and new features
- Nokia SPRD tab activated
Nokia 3G SS [TA-1006] supported
Nokia 3G SS [TA-1022] supported
Nokia 3G DS [TA-1036] supported
- Identify
- Reset Settings / Format FS
- Firmware Flashing ( cross, nvm update, lang change )
Info: Device security paired, store all NV backups to emergency case !
Info: Crossflashing can be done and not touch security ( require enable NV update )
- Nokia SP tab changes
Identify now read BOTH part info for A/B devices
Flash Engine updated
"UserData preserve" mode updated
Format FS / Reset FRP revised
Nokia 5.1+ ( Nokia X5 ) supported ( TA-1102, TA-1105, TA-1108, TA-1109, TA-1112, TA-1120 )
Nokia 3.1+ supported ( TA-1104, TA-1113, TA-1115, TA-1117, TA-1118, TA-1125 )
- Identify
- Reset Settings / Format FS / Reset FRP
- Firmware Flashing
- Nokia FP tab changes
PhoneBook extraction engine updated
Extract "from file" revised
https://www.infinity-box.com/support/?r=100065
The Following 5 Users Say Thank You to InfinityHelp For This Useful Post:
Old 03-25-2019, 06:45   #159 (permalink)
Member: 1043909
Infinity-Box [BEST] NK2 v1.11 - More MTK and SPRD features activated
- Nokia SPRD tab
Activated Flash Dump feature
Support another signed base driver ( can be found on support for both x86 and x64 systems )
FlashEngine updated
- Nokia MTK SP tab changes
MT6755 line has been broken in previous release, fixed
- Nokia MTK FP tab changes
Backup security feature released, allow store device security
Restore security feature released, allow restore device security backups
Backup now also made during "Identify"
During backup security RPL will be cleaned and prepared ( all counters reset and default mtk settings/options set )
- Other
Minor bugfixes and changes
- Additional info
SPRD flash backups can be sent for processing via IOS FileUploader for adding new LangPacks on support.
ETA of processing - 48 hours, then files can be found on support. All other ways will be ignored.
https://www.infinity-box.com/support/?r=100066
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 04-01-2019, 09:39   #160 (permalink)
Member: 148515
Infinity-Box [BEST] NK2 v1.12 - Nokia 106 (2019) line support activated
Next revision of Nokia 106 (2019) are supported:
Nokia 106 (2019) : NEMO : TA-1114
> Firmware reading
> Backup security
> Restore security
> Repair security ( via SWP )
> SP unlock ( via SWP )
> Complete repair ( via SWP )
*SWP feature allowed due to Nokia security flaw, made in Nokia 106 and affect this model only for now.
- Base
Loader database updated
Bugfixes and minor changes
- Support
Some firmwares for Nokia 106 can be found on support now
https://www.infinity-box.com/support/?r=100068
Old 04-09-2019, 09:59   #161 (permalink)
Member: 148515
Infinity-Box [BEST] NK2 v1.13 - Universal Flasher/Unbricker, more Forensic and other stuff !
MTK SP tab
- Flasher engine updated
Allow unbrick/repair almost all SW-related issues during flashing from now ( specially A/B devices )
Fixed memory partitioning issues on fresh devices
- Reset Settings/Format FS updated
- Safe UserData flashing feature updated
- Pre-Erase option can be activated/de-activated depend on user need
MTK FP tab
- Dead mode flashing revised ( incorrect identification during flashing semi-dead device )
- Firmware reader engine updated
- LangPack info extractor updated
- Forensic engine updated
Nokia 106 PhoneBook extraction activated/de-activated
Universal Gallery extractor activated
*Allow extract : Photos ( if device have camera ) , Audio records , Browser BookMarks and History ( Built-in MTK and Opera Mini supported )
*Support all existing MTK Feature devices, made by Microsoft and HMD Nokia
*Support Direct (from phone) and Dump (from file) mode
Phonebook extraction updated
SPRD FP tab
- FullFlash reading optimized
Unfortunately, all dumps, made by v112 are not usable. Please, repeat reading with new version, if you need get LangPacks.
- Flash Engine updated
- NVRAM verify and check revised
Other
- Some bugfixes and changes
Support
- All latest firmwares can be found on support!
https://www.infinity-box.com/support/?r=100069
Old 04-15-2019, 09:19   #162 (permalink)
Member: 130995
Infinity-Box [BEST] NK2 v1.14 - Nokia 210 (2019) Full support activated
Next revision of Nokia 210 (2019) are supported:
Nokia 210 (2019) : TA-1139
> Firmware reading
> Backup security
> Restore security
> Forensic ( Gallery/Browser History/Browser BookMarks )
*SWP feature allowed due to Nokia security flaw, made in Nokia 210 and affect this model only for now.
*CROSS-SWP between affected models not allowed for now!
- Base
- Support
Some firmwares for Nokia 210 can be found on support now
https://www.infinity-box.com/support/?r=100070
Old 04-21-2019, 07:16   #163 (permalink)
Member: 1043909
Infinity-Box [BEST] NK2 v1.15 - Nokia 1 Plus support
Nokia 1+ (ANTMAN) supported ( TA-1111, TA-1123, TA-1127, TA-1130 )
- Identify
- Firmware Flashing
Other
- FlashLoader datbase updated
https://www.infinity-box.com/support/?r=100071
Old 05-06-2019, 09:28   #164 (permalink)
Member: 1043909
Infinity-Box [BEST] NK2 v1.16 - Android 9 firmwares support, model finder
- MTK flash engine updated ( Feature Line )
- MTK flash engine updated ( SmartPhone Line )
- Android 9P firmwares can not be flashed in Nokia 5.1/3.1/3.1+ , fixed
- Model selector over TA/RM identifier activated. Double click on model to open required tab
- Base
- Support
New firmwares can be found on support for all supported lines
https://www.infinity-box.com/support/?r=100074
Old 07-25-2019, 09:52   #165 (permalink)
Member: 1043909
Infinity-Box [BEST] NK2 v1.17 - All New and Old HMD support activated
HMD N 1 **
TA-1060, TA-1056, TA-1047, TA-1079, TA-1066
HMD N 1 Plus **
TA-1130, TA-1123, TA-1111, TA-1127
HMD N 2 *
TA-1035, A-1029, TA-1023, TA-1011, TA-1007
HMD N 2.1 *
TA-1086, TA-1084, TA-1092, TA-1093, TA-1080
HMD N 2.2 **
TA-1183, TA-1184, TA-1188
HMD N 3 **
TA-1028, TA-1038, TA-1032, TA-1020
HMD N 3.1 **
TA-1074, A-1070, TA-1063, TA-1057, TA-1049
HMD N 3.1 Plus **
TA-1125, TA-1124, TA-1118, TA-1117, TA-1115, TA-1113, TA-1104
HMD N 3.2 *
TA-1154, TA-1156, TA-1159, TA-1161, TA-1164
HMD N 4.2 *
TA-1133, TA-1149, TA-1150, TA-1152, TA-1157
HMD N 5 *
TA-1044, TA-1027, TA-1024, TA-1053
HMD N 5.1 **
TA-1088, TA-1081, TA-1075, TA-1061
HMD N 5.1 Plus **
TA-1120, TA-1112, TA-1108, TA-1105, TA-1102
HMD N 6 *
TA-1033, TA-1039, TA-1025, TA-1021, TA-1000, TA-1003
HMD N 6.1 *
TA-1043, TA-1016, TA-1045, TA-1050, TA-1054, TA-1068, TA-1089
HMD N 6.1 Plus *
TA-1116, TA-1103, TA-1083
HMD N 7 *
TA-1041
HMD N 7.1 *
TA-1100, TA-1096, TA-1095, TA-1085
HMD N 7 Plus *
TA-1062, TA-1062, TA-1055, TA-1046
HMD N 8 *
TA-1012, TA-1004, TA-1052
HMD N 8.1 *
TA-1128, TA-1121, TA-1119
HMD N 8 Sirocco *
TA-1042, TA-1005
HMD N 9 PureView *
TA-1094, TA-1087, TA-1082
HMD N X71 *
TA-1172
> Firmware flashing ( Factory / BEST firmware packages )
> Reset FRP
> Identify
Info marks:
* - Device require Remote Authentification Server ( credit cost - 0 for now )
** - Device supported / supported already STANDALONE
- Base
Support for old HMD line over RAS for QCOM models
Support for new HMD line - WT/HQ activated - 2.2, 3.2, 4.2 ( over RAS for QCOM models )
ModelFinder updated
FileSystem toolkit updated, changed FormatFS for all SP lines
SW/HW/Cross-avoid check activated for BL update mode
- MTK SP
Updated loader database
Boot log now show also ARB state and other service info
Automatic backup for critical partitions activated
- MTK FP
SWVersion check revised
FlashEngine updated
FileSystem (Forensic) engine updated
- SPD FP
Backup / Restore security activated
FlashEngine revised
- Support
Some firmwares for wide range of QCOM/MTK HMD Smartphones can be found on support area
https://www.infinity-box.com/support/?r=100081
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 19:18
Page generated in 0.30073 seconds with 9 queries
