05-19-2020, 06:37 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | best2 not opening My best2 is not opening.but best is working fine.OS is windows 8.1 Also disabled the avast is same Only best2 logo then off. Fault.bin fault Pls give me any solution as soon as possible Tx |
05-19-2020, 21:40 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, There is a software conflict with this application: \program files\avast software\avast\aswidsagent.exe Disable AVAST, delete fault.bn file and run Infinity software. Team is working to fix this compatibility issue. |
05-23-2020, 11:26 | #4 (permalink) | |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Quote:
Solution is Just add infinity folder in the exception List in the setting manu.Also need to disable the AVAST. Tx | |
