01-25-2016, 21:01 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: burkina faso
Member: 457765 Status: Offline Thanks Meter: 77 | Big problem with lumia flash ALL LUMIA I FLASH I HAVE ERROR AND RED LCD.WHAT HAPPEN HERE IS Core : v2.14 , WP8x FlashEngine : v9.4 FFU : E1EF1521_RM820_3051.50009.1425.2001_RETAIL_nam_usa _100_01_443332_prd_signed_2.ffu Checking FFU file, wait... FFU Revision ID : 2.0 FFU Model ID : Nokia.MSM8960.P4301_ATT FFU RootKeyHash : 00E9427DF118D9E27D098D13BECB6C6C89CE59F4 FFU Languages : English , French , Korean , Portuguese(Brazil) , sr-latn-rs , Spanish(Mexico) , Chinese(Taiwan) , FFU ChipSectors : 20971520 FFU Header : 0x000C0000 FFU Payload : 0x55280000 FFU FastVerify : Ok Waiting for phone... Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device catched in BOOT mode! Boot Mode confirmed! Setting Preloder Collect Info... Setting Application Setting Secure Collect Info... === Nokia Flash App info : Protocol Version : 1.14 Protocol Implementation : 1.25 === Phone Initial info : Phone RMxxx ID : RM-820 Phone Model ID : Nokia.MSM8960.P4301_ATT.3.2.1 Phone Model PC : 059L848 Phone IMEI : 353680054865664 === eMMC info : eMMC Vendor : Toshiba eMMC CID : 0011 eMMC Size : 29820 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : 00E9427DF118D9E27D098D13BECB6C6C89CE59F4 === Other info : SD present : False Full Check skipped , will be checked by ImageSignature Battery Level : 3% [Info] : Battery level is low, but ignored in settings. Continue at user risk. Battery Level enough to flash FFU : E1EF1521_RM820_3051.50009.1425.2001_RETAIL_nam_usa _100_01_443332_prd_signed_2.ffu Flashing FFU Sending FFU Header CertData Header sent , accepted Perform Data Partition Erase Erase done Sending FFU Payload Data... Finishing flashing Red Light Error during flashing! LastErr : 000017FF0000000000000000 Connect phone on selected interface... Core : v2.14 , WP8x FlashEngine : v9.4 FFU : E1EF1521_RM820_3051.50009.1425.2001_RETAIL_nam_usa _100_01_443332_prd_signed_2.ffu Checking FFU file, wait... FFU Revision ID : 2.0 FFU Model ID : Nokia.MSM8960.P4301_ATT FFU RootKeyHash : 00E9427DF118D9E27D098D13BECB6C6C89CE59F4 FFU Languages : English , French , Korean , Portuguese(Brazil) , sr-latn-rs , Spanish(Mexico) , Chinese(Taiwan) , FFU ChipSectors : 20971520 FFU Header : 0x000C0000 FFU Payload : 0x55280000 FFU FastVerify : Ok Waiting for phone... Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device catched in BOOT mode! Collect Info... === Nokia Flash App info : Protocol Version : 1.18 Protocol Implementation : 2.2 === Phone Initial info : Phone Model ID : Nokia.MSM8960.P4301_ATT.3.2.1 === eMMC info : eMMC Vendor : Toshiba eMMC CID : 0011 eMMC Size : 29820 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : 00E9427DF118D9E27D098D13BECB6C6C89CE59F4 === Other info : SD present : False Full Check skipped , will be checked by ImageSignature Battery Level : 6% [Info] : Battery level is low, but ignored in settings. Continue at user risk. Battery Level enough to flash FFU : E1EF1521_RM820_3051.50009.1425.2001_RETAIL_nam_usa _100_01_443332_prd_signed_2.ffu Flashing FFU Sending FFU Header CertData Header sent , accepted Perform Data Partition Erase Error : 06 : Data Partition Not Found! Seems as damaged Will Fix partitions by flash whole image Sending FFU Header CertData Header sent , accepted Skip Data Partition Erase Sending FFU Payload Data... Finishing flashing Red Light Error during flashing! LastErr : 000017F90000000000000000 Connect phone on selected interface... |
01-27-2016, 14:25 | #6 (permalink) |
Freak Poster Join Date: Apr 2008 Location: A_1st™ Support Age: 38
Member: 758981 Status: Offline Sonork: 100.1592091 Thanks Meter: 232 | i tried also lumia 520-RM-914 lumia 920-RM-820 2 devices give Red Light Error during flashing! LastErr : 000017F90000000000000000 and when i flash with ATF all ok with same firmware not changed i used best 2.17 and there is a mistake on RM-820 firmware firmware is RM-821 Not 820 http://s15.postimg.org/xftutr0tn/Capture.png |
01-27-2016, 14:52 | #7 (permalink) | |
