02-19-2011, 09:22 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | C1-02 (RM-643) Flashing/DataBackup/Restore "World First" Today receive c1-02 RM643 for tests, here results Version - BEST v1.16 Data backup Code: BackUp UserData : [PhoneBook] Generation mode : [S40] Cnt Server Info : 82/918/1000 csv file save to C:\BEST_v1.16\RM-643 C1-02_354334041927794.csv 82 phonebook records are found! VCF Records saved to : BEST\Phones_Data\IMEI\ File saved to : C:\BEST_v1.16\RM-643 C1-02_354334041927794.S4pb Read done ;) Done... Backup UserData : [Calendar] Generation mode : [S40] Reading Calendar... Calendar is tottaly clear :( Reading MMC password... password not set :( BackUp UserData : [SMS/MMS] Generation mode : [S40] Scanning FileSystem.. Scan done, processing data... Total - 25 files Reading, wait.... Readed data saved to : BEST/IMEI/SMS.txt Read Done ! Elapsed: 00:00:02 BackUp UserData : [SMS/MMS] Selected package method... Read Package : [SMS Package] Generation mode : [S40] Saved to : C:\BEST_v1.16\RM-643 C1-02_354334041927794.smspkg Read Done ! Elapsed: 00:00:03 Done! BackUp UserData : [Gallery] Generation mode : [S40] Scanning FileSystem.. Scan done, processing data... Total - 77 files Total Readed : 4 Mbyte(s) Read Done ! Elapsed: 00:00:09 Flashing ( as i seen on forum - World First ) Code: Core version : 1.16 , Rev : 2.1 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm643__03.40.mcusw PPM : rm643__03.40.ppm_i CNT : rm643__03.40.image_i_0597677 Flashing phone now... Check files done... -> Check SW version... FlashFile version : 03.40 Phone version : 03.40 09-12-10 RM-643 (c) Nokia -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created... :) Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... Batery valtage : 3724 mV -> Batery voltage less, than 3,8V (3724mV). Continue at user risk Reboot.... Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.37_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! ===Flashing [MCU]=== File : rm643__03.40.mcusw Image : rm643__03.40.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00040000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40080000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40080000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 4/5 Erase , Start : 0x400A0000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x400A0000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 5/5 Erase , Start : 0x40400000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:02:06 Write , Start : 0x40400000 , Len : 0x01780000 Flashing , wait ... Region flash done, time : 00:00:31 ===Flashing [PPM]=== File : rm643__03.40.ppm_i Image : package_i.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:18 Write , Start : 0x41C00000 , Len : 0x003859B0 Flashing , wait ... Region flash done, time : 00:00:04 ===Flashing [CNT]=== File : rm643__03.40.image_i_0597677 Image : package_i_0597677.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42200000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:02:32 Write , Start : 0x42200000 , Len : 0x00B80000 Flashing , wait ... Region flash done, time : 00:00:13 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:04 No write data, skip Flashing done! Total flash time : 00:06:00 Reboot phone now... Reading Phone Info.... Connected phone - C1-02 Software Info: V 03.40 09-12-10 RM-643 (c) Nokia IMEI: 354334041927794 PPM version : V 03.40 09-12-10 RM-643 (c) Nokia I Product code: 0597677 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Resetting LifeTimer Error check LifeTimer Data, break :( Reset It manually, please Checking User Certificates... Total - 39 certs Data exist, skip certificate repair... AfterFlash operations done... Reconnect, wait... Done! Connect phone on selected interface... Elapsed: 00:06:35 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Data Restore Code: Restoring UserData : [PhoneBook] Generation mode : [S40] Check phone mode... Phone in Test mode Seting Local mode... wait... Local mode set Writing Phonebook... 82 phonebook records write ok! Done... Restoring UserData : [SMS Package] Generation mode : [S40] Image : Series 40 Restore Invalid CSkey! Can't write file! Invalid CSkey! Can't write file! SMS Package restored -> Restart phone for accept changes -> Phone can freeze first 5 minutes Done! Set phone in Normal mode... Restarting... Done! Reading Phone Info.... Connected phone - C1-02 Software ver : V 03.40 09-12-10 RM-643 (c) Nokia IMEI : 354334041927794 Ape Ver : APE Var : APE ADSP: DSP Ver : APE Test: PPM : V 03.40 09-12-10 RM-643 (c) Nokia I CNT : Content: i_0597677 V 03.40 09-12-10 RM-643 (c) Nokia Product SN : HSA782651 Product code : 0597677 Base Prd.code: 0591126 Module code : 0204487 Long Prod.SN : 0 Hardware info======= HWID : 1000 Retu : Tahvo : Batery: 3684 mV Camera: CMT BT: 19b5-22012 APE BT: APE HW: LCDVer: AUO RF ic : Lock info =========== IMEI : 354334041927794 IMEI spNet : 3A 45 33 04 14 29 77 09 IMEI svNet : 33 45 33 04 14 29 77 09 F8 Sl Conf : 001-01-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : F57FCF35DB1665C4 Provider : Default Test Operator Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; CRT308 Backup Created... :) User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
The Following 44 Users Say Thank You to Dzirt For This Useful Post: |
02-19-2011, 11:46 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | C1-01 Dead FLASH ok (Dead on another Tool ) C1-01 Dead FLASH ok (Dead on another Tool ) Code: Core version : 1.16 , Rev : 2.1 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm607__03.35.mcusw PPM : rm607__03.35.ppm_m_c CNT : rm607__03.35.image_m_c_0595609 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.37_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! ===Flashing [MCU]=== File : rm607__03.35.mcusw Image : rm607__03.35.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00040000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40080000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40080000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 4/5 Erase , Start : 0x400A0000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x400A0000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 5/5 Erase , Start : 0x40400000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40400000 , Len : 0x01780000 Flashing , wait ... Region flash done, time : 00:00:31 ===Flashing [PPM]=== File : rm607__03.35.ppm_m_c Image : package_m_c.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:15 Write , Start : 0x41C00000 , Len : 0x00319A48 Flashing , wait ... Region flash done, time : 00:00:03 ===Flashing [CNT]=== File : rm607__03.35.image_m_c_0595609 Image : package_m_c_0595609.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42200000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:02:57 Write , Start : 0x42200000 , Len : 0x00B40000 Flashing , wait ... Region flash done, time : 00:00:13 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:05 No write data, skip Flashing done! Total flash time : 00:04:17 Reboot phone now... Reading Phone Info.... Connected phone - C1-01 Software Info: V 03.35 02-12-10 RM-607 (c) Nokia IMEI: 3537990456**** PPM version : V 03.35 02-12-10 RM-607 (c) Nokia M_C Product code: 0596379 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Checking User Certificates... Total - 39 certs Data exist, skip certificate repair... Set phone to Normal mode... AfterFlash operations done... Done! Connect phone on selected interface... |
The Following 7 Users Say Thank You to Mohsin-* For This Useful Post: |
02-19-2011, 11:50 | #7 (permalink) |
No Life Poster Join Date: Mar 2005 Location: UGANDA Age: 50
Member: 126167 Status: Offline Sonork: 100.1591387 Thanks Meter: 5,128 | WOw!!, Great News Keep it Up. Br HASSAN MABROUK-GSM UGANDA |
The Following 2 Users Say Thank You to hassanjinja For This Useful Post: |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
HEX for CLIP to restore Factory Defaults | X-Shadow | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2000 15:59 |
