11-13-2012, 10:18 | #1 (permalink) |
Freak Poster Join Date: Nov 2011
Member: 1698387 Status: Offline Thanks Meter: 43 | c2-01 simlock damaged I have full flash back up but after write rpl and pm simlock is still damaged. Thanks Will Write RPL keys now... Check RPL file... SimLock Data found! SimLock key found! -> Skip Flash keys Part, for Flash Part use Dead Mode!!!!! Writing SimLock Key... Error! Writing SimLock Data... Error! SDD Key status : SD Data is Ok SimLock status : SimLock Damaged!!!!! Security status : Security is Ok Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Operating mode is OK, no need change... Field 120 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Done! Elapsed: 00:00:00 Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key Not exist SimLock status : SimLock Damaged!!!!! - > Do REPAIR SL if it SL2/SL phone, if SL3 - Help Only Backup Or RPL Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! |
11-15-2012, 15:03 | #4 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | So, if it was ok - why now it is damaged? I see Sim.rpl and pm rpl. Was done recovery from full. |
The Following User Says Thank You to Dzirt For This Useful Post: |
11-15-2012, 18:06 | #8 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | So, if it before was OK and was connected to BEST once - it was made PM backup. Check via search on pc your phone imei. Will be listed all security backups. |
