02-13-2015, 15:08 | #1 (permalink) |
Freak Poster Join Date: Dec 2013 Location: DINGIGUL, TAMILNADU, INDIA Age: 39
Member: 2088434 Status: Offline Sonork: 100.1659449 Thanks Meter: 52 | c2-03 flash done Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm702__07.65.mcusw PPM : rm702__07.65.ppm_a CNT : rm702__07.65.image_a_059K071 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> Check SW version... FlashFile version : 07.65 Phone version : 07.48 23-02-12 RM-702 (c) Nokia -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok Reboot.... -> If Phone start charge - just reinsert battery fast Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 354137729 IMEI 2 : 3541637737 PCcode : 059N5B2 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\354129_XG213.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm702__07.65.mcusw Image : rm702__07.65.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01B40000 Erasing, wait ... Erase done, time : 00:02:29 Write , Start : 0x40280000 , Len : 0x01AC0000 Flashing , wait ... Region flash done, time : 00:00:32 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x26E7 ===Flashing [PPM]=== File : rm702__07.65.ppm_a Image : package_a.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41DC0000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:32 Write , Start : 0x41DC0000 , Len : 0x0042D898 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0x41C2 ===Flashing [CNT]=== File : rm702__07.65.image_a_059K071 Image : package_a_059K071.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x424C0000 , Len : 0x01960000 Erasing, wait ... Erase done, time : 00:03:01 Write , Start : 0x424C0000 , Len : 0x00CA0000 Flashing , wait ... Region flash done, time : 00:00:14 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:06 No write data, skip CRC check passed , 0x1559 Flashing done! Total flash time : 00:07:11 Reboot phone now... Reading Phone Info.... Connected phone - C2-03 Software Info: V 07.65 19-09-12 RM-702 (c) Nokia IMEI: PPM version : V 07.65 19-09-12 RM-702 (c) Nokia A Product code: 059N5B2 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Check and Upload User Certificates ... Total - 42 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... |
The Following User Says Thank You to suninfotec1 For This Useful Post: |
