Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 07-17-2012, 12:29   #1 (permalink)
vignesharmy55's Avatar
Member: 1531954
Sonork: 100.1619337
c2-03 rm-755 contact service problem
i have one mobile with contact service problem i flash with best but problem same any one advoice ME thx u
here log:
card found: S/N xxxxxxxxxx
registered to: vigneshkumar
Connect phone on selected interface...
Core : v1.47 , FlashEngine : v1.5
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm775__07.32.mcusw
PPM : rm775__07.32.ppm_a
CNT : rm775__07.32.image_a_059H5W8_004
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
--- Insert cable and charger or press phone's power button! ---
Connection opened successfully
Waiting for communication response...
BootRom : 1st boot ok
ASIC ID:       000000030000022600010007600C192102031104
CPU ID :       RAPU v11 , Features : Dead-Test , USBRPL , FullUSB
EM0 ID:        00001051
EM1 ID:        00001060
PUBLIC ID:     14F0010AB09C0344A1B896076B3A3051DE8C53A5
ASIC MODE ID:  00
ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
ROM ID:        E693EF0DAC22615B
Use RAPUv11_2nd.fg  ,  Rev : 3.0  Ver : 12.14.0
Processing RAWLOADER...
2nd boot not accepted... Alive Request not done :(
Boot error... :(
->  Boot fail...
    Flashing failed...
Phone disconected!
MCU : rm702__07.31.mcusw
PPM : rm702__07.31.ppm_sn
CNT : rm702__07.31.image_sn_059L5S5
Check files done...
-> If Windows say "Unrecognized device" - just reinsert battery
-> If flashing freeze - reinsert cable and try again
--- Press phone's power button or insert charger! ---
DBG : F00A1FB300020303010100FF
CPUID : XGOLD 213
2nd boot Ok, 01
2nd ready, AA
Sending Algo
Algo sent Ok
BL : Quantum_Bootloader_10.46_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 358639040841168
IMEI 2 : 358639040841176
PCcode : 059D464
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : c:\InfinityBox\BEST\Backup\Cert\358639040841168_358639040841176_XG213_CRT.rpl
   ===Flashing [MCU]===
File : rm702__07.31.mcusw
Image : rm702__07.31.mcusw_ebl_psi.fls
Cert block found, sending....
Cert sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:05
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01B40000
Erasing, wait ...
Erase done, time : 00:02:33
Write , Start : 0x40280000 , Len : 0x01AC0000
Flashing , wait ...
Region flash done, time : 00:00:41
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
   ===Flashing [PPM]===
File : rm702__07.31.ppm_sn
Image : package_sn.ppm_ebl_psi.fls
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41DC0000 , Len : 0x00700000
Erasing, wait ...
Erase done, time : 00:00:27
Write , Start : 0x41DC0000 , Len : 0x0047A400
Flashing , wait ...
Region flash done, time : 00:00:05
   ===Flashing [CNT]===
File : rm702__07.31.image_sn_059L5S5
Image : package_sn_059L5S5.image.fls
Cert sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x424C0000 , Len : 0x01960000
Erasing, wait ...
Erase done, time : 00:03:00
Write , Start : 0x424C0000 , Len : 0x00AE0000
Flashing , wait ...
Region flash done, time : 00:00:14
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
No write data, skip
Flashing done!
Total flash time : 00:07:17
Reboot phone now...
Reading Phone Info....
Connected phone -   C2-03
Software Info:     V 07.31 12-01-12 RM-702 (c) Nokia
IMEI:  358639040841168
PPM version :   V 07.31 12-01-12 RM-702 (c) Nokia             SN
Product code:  059P4Z7
Checking...
SimLock status : SimLock is Ok
Security status : Security Damaged!!!!! :(
Read Info Done!
Settings After Flash Defaults...
ProductTuneSet...OK!
SwUpgradeSet...OK!
Checking User Certificates...
Total - 42 certs
Data exist, skip certificate repair...
Set phone to Normal mode...
AfterFlash operations done ;D
Done!
Elapsed: 00:08:08
Old 07-17-2012, 13:11   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Sonork: 100.1616907
Hello, do you have ICQ? Or Sonork? Need try some things.
Old 07-17-2012, 14:40   #3 (permalink)
Member: 1531954
Sonork: 100.1619337
i don't have icq,sonork i have only yahoo and gmail
Old 07-17-2012, 14:44   #4 (permalink)
Dzirt's Avatar
Member: 1157320
Sonork: 100.1616907
Ok, read RPL, PM and send all it in archive to sprevive@gmail.com
Old 07-18-2012, 08:23   #5 (permalink)
Member: 1531954
Sonork: 100.1619337
i have no rpl or pm..............
Old 07-18-2012, 11:02   #6 (permalink)
Dzirt's Avatar
Member: 1157320
Sonork: 100.1616907
hehe, just read it!
from this phone, which damaged.
press Read Rpl and insert usb cable into powered off phone. Rpl will be readed. After read PM. Both files send me.
Old 07-19-2012, 16:26   #7 (permalink)
Member: 1531954
Sonork: 100.1619337
here is rpl:
358639040841168_358639040841176_XG213.rpl
here is pm:
http://www.mediafire.com/?m6k5m35fym5iqsr
Old 07-19-2012, 16:31   #8 (permalink)
Dzirt's Avatar
Member: 1157320
Sonork: 100.1616907
Oh...
How is hard...
For read PM need open First tab (Service)
and press Read in PM section (right upper)
It need do, when phone will be in local. It will be in local after read RPL.
The Following User Says Thank You to Dzirt For This Useful Post:
Old 07-20-2012, 07:09   #9 (permalink)
Member: 1531954
Sonork: 100.1619337
Hi Brother Already Upload Can u Please Tell Me Solution ?
Old 07-20-2012, 09:17   #10 (permalink)
Dzirt's Avatar
Member: 1157320
Sonork: 100.1616907
Hello, just got file, need hour to make something for it.
Old 07-20-2012, 09:40   #11 (permalink)
Dzirt's Avatar
Member: 1157320
Sonork: 100.1616907
Repair pack
Get it, write first PM - put phone in local (via Read RPL with XG213 ticked)
After Press Write PM, select this file - 358639040841168_rep.pm
When write done - make factory sets, try check phone. If no luck - put in local again, press Write RPL, select this file - 358639040841168_1176_XG213.rpl
After done - make factory sets, try check phone.
If still no luck - write last file as RPL.
Old 07-20-2012, 10:32   #12 (permalink)
Member: 1531954
Sonork: 100.1619337
Thanks bro my mobile ready:
here is log:
CPUID : XGOLD 213
2nd : Custom
2nd boot Ok, 01
2nd ready, AA
Sending Algo
ALG : Custom
Algo sent Ok
Boot done!
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 35xxxxxxxxxxxxx
IMEI 2 : 35xxxxxxxxxxxxx
PCcode : 05xxxxx
SL3 Simlock read (XGOLD) ... ok
WMDRM Key read ... Ok
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
RPL saved : c:\InfinityBox\BEST\Backup\Cert\3586390408xxxxx_3586390408xxxxx_2nd_XG213.rpl
Phone found!
Series 40 Device detected!
read info...  - Ok
Operating mode is OK, no need change...
Field 4
   Record 1 write - Ok
   Record 3 write - Ok
   Record 4 write - Ok
   Record 5 write - Ok
   Record 6 write - Ok
   Record 9 write - Ok
   Record 18 write - Ok
   Record 19 write - Ok
   Record 26 write - Ok
   Record 28 write - Ok
Field 8
   Record 0 write - Ok
   Record 1 write - Ok
   Record 2 write - Ok
   Record 3 write - Ok
   Record 4 write - Ok
   Record 5 write - Ok
   Record 7 write - Ok
   Record 8 write - Ok
   Record 9 write - Ok
   Record 10 write - Ok
   Record 11 write - Ok
   Record 12 write - Ok
Field 11
   Record 0 write - Ok
   Record 1 write - Ok
   Record 2 write - Ok
   Record 3 write - Ok
   Record 4 write - Ok
Field 13
   Record 0 write - Ok
   Record 1 write - Ok
   Record 2 write - Ok
   Record 3 write - Ok
   Record 4 write - Ok
   Record 5 write - Ok
   Record 6 write - Ok
   Record 7 write - Ok
   Record 8 write - Ok
   Record 9 write - Ok
   Record 13 write - Ok
   Record 14 write - Ok
   Record 15 write - Ok
   Record 16 write - Ok
   Record 17 write - Ok
   Record 20 write - Ok
   Record 21 write - Ok
   Record 22 write - Ok
   Record 23 write - Ok
   Record 24 write - Ok
   Record 25 write - Ok
   Record 27 write - Ok
   Record 29 write - Ok
   Record 30 write - Ok
   Record 31 write - Ok
   Record 32 write - Ok
   Record 33 write - Ok
   Record 34 write - Ok
   Record 35 write - Ok
   Record 36 write - Ok
   Record 37 write - Ok
   Record 38 write - Ok
   Record 39 write - Ok
   Record 40 write - Ok
   Record 41 write - Ok
   Record 42 write - Ok
   Record 43 write - Ok
   Record 44 write - Ok
   Record 45 write - Ok
   Record 46 write - Ok
   Record 47 write - Ok
   Record 48 write - Ok
   Record 49 write - Ok
   Record 50 write - Ok
   Record 51 write - Ok
   Record 52 write - Ok
   Record 53 write - Ok
   Record 54 write - Ok
   Record 55 write - Ok
   Record 56 write - Ok
   Record 57 write - Ok
   Record 58 write - Ok
   Record 59 write - Ok
   Record 60 write - Ok
   Record 61 write - Ok
   Record 62 write - Ok
   Record 63 write - Ok
   Record 64 write - Ok
   Record 65 write - Ok
   Record 66 write - Ok
   Record 67 write - Ok
   Record 68 write - Ok
   Record 69 write - Ok
   Record 70 write - Ok
   Record 71 write - Ok
   Record 72 write - Ok
   Record 73 write - Ok
   Record 74 write - Ok
   Record 75 write - Ok
   Record 76 write - Ok
   Record 77 write - Ok
   Record 78 write - Ok
   Record 79 write - Ok
   Record 80 write - Ok
   Record 81 write - Ok
   Record 82 write - Ok
   Record 83 write - Ok
   Record 84 write - Ok
   Record 85 write - Ok
   Record 86 write - Ok
   Record 87 write - Ok
   Record 88 write - Ok
   Record 89 write - Ok
   Record 90 write - Ok
   Record 91 write - Ok
   Record 92 write - Ok
   Record 93 write - Ok
   Record 94 write - Ok
   Record 95 write - Ok
   Record 96 write - Ok
   Record 97 write - Ok
   Record 98 write - Ok
   Record 99 write - Ok
   Record 100 write - Ok
   Record 101 write - Ok
   Record 102 write - Ok
   Record 103 write - Ok
   Record 104 write - Ok
   Record 105 write - Ok
   Record 106 write - Ok
   Record 107 write - Ok
   Record 108 write - Ok
   Record 109 write - Ok
   Record 110 write - Ok
   Record 111 write - Ok
   Record 112 write - Ok
   Record 113 write - Ok
   Record 114 write - Ok
   Record 115 write - Ok
   Record 116 write - Ok
   Record 117 write - Ok
   Record 118 write - Ok
   Record 119 write - Ok
   Record 120 write - Ok
   Record 121 write - Ok
   Record 122 write - Ok
   Record 123 write - Ok
   Record 124 write - Ok
   Record 125 write - Ok
   Record 126 write - Ok
   Record 127 write - Ok
   Record 128 write - Ok
   Record 129 write - Ok
   Record 130 write - Ok
   Record 131 write - Ok
   Record 132 write - Ok
   Record 133 write - Ok
   Record 134 write - Ok
   Record 135 write - Ok
   Record 136 write - Ok
   Record 137 write - Ok
   Record 138 write - Ok
   Record 139 write - Ok
   Record 140 write - Ok
   Record 141 write - Ok
   Record 142 write - Ok
   Record 143 write - Ok
   Record 144 write - Ok
   Record 145 write - Ok
   Record 146 write - Ok
   Record 147 write - Ok
   Record 148 write - Ok
   Record 149 write - Ok
   Record 150 write - Ok
   Record 151 write - Ok
   Record 152 write - Ok
   Record 153 write - Ok
   Record 154 write - Ok
   Record 155 write - Ok
   Record 156 write - Ok
   Record 157 write - Ok
   Record 158 write - Ok
   Record 159 write - Ok
   Record 160 write - Ok
   Record 161 write - Ok
   Record 162 write - Ok
   Record 163 write - Ok
   Record 164 write - Ok
   Record 165 write - Ok
   Record 166 write - Ok
Field 42
   Record 0 write - Ok
   Record 1 write - Ok
   Record 2 write - Ok
   Record 3 write - Ok
   Record 4 write - Ok
   Record 5 write - Ok
   Record 6 write - Ok
   Record 7 write - Ok
   Record 8 write - Ok
   Record 9 write - Ok
Field 54
   Record 0 write - Ok
   Record 2 write - Ok
Field 96
   Record 0 write - Ok
   Record 1 write - Ok
Field 107
   Record 0 write - Ok
   Record 1 write - Ok
   Record 2 write - Ok
   Record 3 write - Ok
Field 116
   Record 0 write - Ok
   Record 1 write - Ok
   Record 2 write - Ok
   Record 3 write - Ok
   Record 4 write - Ok
   Record 5 write - Ok
   Record 6 write - Ok
   Record 7 write - Ok
   Record 8 write - Ok
   Record 9 write - Ok
Field 117
   Record 5 write - Ok
   Record 6 write - Ok
Field 120
   Record 0 write - Ok
   Record 1 write - Ok
   Record 2 write - Ok
   Record 3 write - Ok
Field 153
   Record 0 write - Ok
   Record 1 write - Ok
   Record 2 write - Ok
   Record 3 write - Ok
   Record 4 write - Ok
   Record 5 write - Ok
Field 163
   Record 0 write - Ok
Field 193
   Record 2 write - Ok
   Record 3 write - Ok
   Record 4 write - Ok
   Record 9 write - Ok
Field 217
   Record 0 write - Ok
Field 218
   Record 0 write - Ok
Field 238
   Record 1 write - Ok
Field 239
   Record 0 write - Ok
   Record 1 write - Ok
   Record 2 write - Ok
Field 301
   Record 0 write - Ok
   Record 1 write - Ok
   Record 2 write - Ok
   Record 3 write - Ok
   Record 4 write - Ok
   Record 5 write - Ok
   Record 6 write - Ok
   Record 7 write - Ok
   Record 8 write - Ok
   Record 9 write - Ok
Field 308
   Record 0 write - Ok
   Record 3 write - Ok
   Record 4 write - Ok
   Record 5 write - Ok
   Record 6 write - Ok
   Record 7 write - Ok
   Record 8 write - Ok
   Record 9 write - Ok
Field 322
   Record 0 write - Ok
Field 339
   Record 0 write - Ok
   Record 1 write - Ok
Field 341
   Record 0 write - Ok
   Record 3 write - Ok
   Record 4 write - Ok
Field 354
   Record 0 write - Ok
Field 355
   Record 0 write - Ok
Field 362
   Record 0 write - Ok
   Record 1 write - Ok
Field 364
   Record 0 write - Ok
   Record 1 write - Ok
   Record 2 write - Ok
   Record 3 write - Ok
   Record 4 write - Ok
   Record 5 write - Ok
   Record 6 write - Ok
   Record 7 write - Ok
   Record 8 write - Ok
   Record 9 write - Ok
Field 365
   Record 0 write - Ok
   Record 1 write - Ok
   Record 2 write - Ok
   Record 3 write - Ok
   Record 4 write - Ok
   Record 5 write - Ok
   Record 6 write - Ok
   Record 7 write - Ok
   Record 8 write - Ok
   Record 9 write - Ok
Field 372
   Record 0 write - Ok
   Record 1 write - Ok
Field 373
   Record 0 write - Ok
Field 374
   Record 0 write - Ok
Field 383
   Record 1 write - Ok
   Record 3 write - Ok
   Record 4 write - Ok
   Record 5 write - Ok
   Record 6 write - Ok
   Record 7 write - Ok
   Record 8 write - Ok
   Record 9 write - Ok
   Record 167 write - Ok
   Record 168 write - Ok
   Record 169 write - Ok
   Record 170 write - Ok
   Record 171 write - Ok
   Record 172 write - Ok
Field 390
   Record 0 write - Ok
   Record 1 write - Ok
   Record 2 write - Ok
   Record 3 write - Ok
   Record 4 write - Ok
   Record 5 write - Ok
   Record 6 write - Ok
   Record 7 write - Ok
   Record 8 write - Ok
   Record 9 write - Ok
   Record 173 write - Ok
   Record 174 write - Ok
   Record 175 write - Ok
   Record 176 write - Ok
   Record 177 write - Ok
   Record 178 write - Ok
   Record 179 write - Ok
   Record 180 write - Ok
   Record 181 write - Ok
   Record 182 write - Ok
   Record 183 write - Ok
   Record 184 write - Ok
   Record 185 write - Ok
   Record 186 write - Ok
   Record 187 write - Ok
   Record 188 write - Ok
   Record 189 write - Ok
   Record 190 write - Ok
   Record 191 write - Ok
   Record 192 write - Ok
   Record 193 write - Ok
   Record 194 write - Ok
   Record 195 write - Ok
   Record 196 write - Ok
   Record 197 write - Ok
   Record 198 write - Ok
   Record 199 write - Ok
   Record 200 write - Ok
   Record 201 write - Ok
   Record 202 write - Ok
   Record 203 write - Ok
   Record 204 write - Ok
   Record 205 write - Ok
   Record 206 write - Ok
   Record 207 write - Ok
   Record 208 write - Ok
   Record 209 write - Ok
   Record 210 write - Ok
   Record 211 write - Ok
   Record 212 write - Ok
   Record 213 write - Ok
   Record 214 write - Ok
   Record 215 write - Ok
   Record 216 write - Ok
   Record 217 write - Ok
   Record 218 write - Ok
   Record 219 write - Ok
   Record 220 write - Ok
   Record 221 write - Ok
   Record 222 write - Ok
   Record 223 write - Ok
   Record 224 write - Ok
   Record 225 write - Ok
   Record 226 write - Ok
   Record 227 write - Ok
   Record 228 write - Ok
   Record 229 write - Ok
   Record 230 write - Ok
   Record 231 write - Ok
   Record 232 write - Ok
   Record 233 write - Ok
   Record 234 write - Ok
   Record 235 write - Ok
   Record 236 write - Ok
   Record 237 write - Ok
   Record 238 write - Ok
   Record 239 write - Ok
   Record 240 write - Ok
   Record 241 write - Ok
   Record 242 write - Ok
   Record 243 write - Ok
   Record 244 write - Ok
   Record 245 write - Ok
   Record 246 write - Ok
   Record 247 write - Ok
   Record 248 write - Ok
   Record 249 write - Ok
   Record 250 write - Ok
   Record 251 write - Ok
   Record 252 write - Ok
   Record 253 write - Ok
   Record 254 write - Ok
   Record 255 write - Ok
   Record 256 write - Ok
   Record 257 write - Ok
   Record 258 write - Ok
   Record 259 write - Ok
   Record 260 write - Ok
   Record 261 write - Ok
   Record 262 write - Ok
   Record 263 write - Ok
   Record 264 write - Ok
   Record 265 write - Ok
   Record 266 write - Ok
   Record 267 write - Ok
   Record 268 write - Ok
   Record 269 write - Ok
   Record 270 write - Ok
   Record 271 write - Ok
   Record 272 write - Ok
   Record 273 write - Ok
   Record 274 write - Ok
   Record 275 write - Ok
   Record 276 write - Ok
   Record 277 write - Ok
   Record 278 write - Ok
   Record 279 write - Ok
   Record 280 write - Ok
   Record 281 write - Ok
   Record 282 write - Ok
   Record 283 write - Ok
   Record 284 write - Ok
   Record 285 write - Ok
   Record 286 write - Ok
   Record 287 write - Ok
   Record 288 write - Ok
   Record 289 write - Ok
   Record 290 write - Ok
   Record 291 write - Ok
   Record 292 write - Ok
   Record 293 write - Ok
   Record 294 write - Ok
   Record 295 write - Ok
   Record 296 write - Ok
   Record 297 write - Ok
   Record 298 write - Ok
   Record 299 write - Ok
   Record 300 write - Ok
   Record 301 write - Ok
   Record 302 write - Ok
   Record 303 write - Ok
   Record 304 write - Ok
   Record 305 write - Ok
   Record 306 write - Ok
   Record 307 write - Ok
   Record 308 write - Ok
   Record 309 write - Ok
   Record 310 write - Ok
   Record 311 write - Ok
   Record 312 write - Ok
   Record 313 write - Ok
   Record 314 write - Ok
   Record 315 write - Ok
   Record 316 write - Ok
   Record 317 write - Ok
   Record 318 write - Ok
   Record 319 write - Ok
   Record 320 write - Ok
   Record 321 write - Ok
   Record 322 write - Ok
   Record 323 write - Ok
   Record 324 write - Ok
   Record 325 write - Ok
   Record 326 write - Ok
   Record 327 write - Ok
   Record 328 write - Ok
   Record 329 write - Ok
   Record 330 write - Ok
   Record 331 write - Ok
   Record 332 write - Ok
   Record 333 write - Ok
   Record 334 write - Ok
   Record 335 write - Ok
   Record 336 write - Ok
   Record 337 write - Ok
   Record 338 write - Ok
   Record 339 write - Ok
   Record 340 write - Ok
   Record 341 write - Ok
   Record 342 write - Ok
   Record 343 write - Ok
   Record 344 write - Ok
   Record 345 write - Ok
   Record 346 write - Ok
   Record 347 write - Ok
   Record 348 write - Ok
   Record 349 write - Ok
   Record 350 write - Ok
   Record 351 write - Ok
   Record 352 write - Ok
   Record 353 write - Ok
   Record 354 write - Ok
   Record 355 write - Ok
   Record 356 write - Ok
   Record 357 write - Ok
   Record 358 write - Ok
   Record 359 write - Ok
   Record 360 write - Ok
   Record 361 write - Ok
   Record 362 write - Ok
   Record 363 write - Ok
   Record 364 write - Ok
   Record 365 write - Ok
   Record 366 write - Ok
   Record 367 write - Ok
   Record 368 write - Ok
   Record 369 write - Ok
   Record 370 write - Ok
   Record 371 write - Ok
   Record 372 write - Ok
   Record 373 write - Ok
   Record 374 write - Ok
   Record 375 write - Ok
   Record 376 write - Ok
   Record 377 write - Ok
   Record 378 write - Ok
   Record 379 write - Ok
   Record 380 write - Ok
   Record 381 write - Ok
   Record 382 write - Ok
   Record 383 write - Ok
   Record 384 write - Ok
   Record 385 write - Ok
   Record 386 write - Ok
   Record 387 write - Ok
   Record 388 write - Ok
   Record 389 write - Ok
   Record 390 write - Ok
   Record 391 write - Ok
   Record 392 write - Ok
   Record 393 write - Ok
   Record 394 write - Ok
   Record 395 write - Ok
   Record 396 write - Ok
   Record 397 write - Ok
   Record 398 write - Ok
   Record 399 write - Ok
   Record 400 write - Ok
   Record 401 write - Ok
   Record 402 write - Ok
   Record 403 write - Ok
   Record 404 write - Ok
   Record 405 write - Ok
   Record 406 write - Ok
   Record 407 write - Ok
   Record 408 write - Ok
   Record 409 write - Ok
   Record 410 write - Ok
   Record 411 write - Ok
   Record 412 write - Ok
   Record 413 write - Ok
   Record 414 write - Ok
   Record 415 write - Ok
   Record 416 write - Ok
   Record 417 write - Ok
   Record 418 write - Ok
   Record 419 write - Ok
   Record 420 write - Ok
   Record 421 write - Ok
   Record 422 write - Ok
   Record 423 write - Ok
   Record 424 write - Ok
   Record 425 write - Ok
   Record 426 write - Ok
   Record 427 write - Ok
   Record 428 write - Ok
   Record 429 write - Ok
   Record 430 write - Ok
   Record 431 write - Ok
   Record 432 write - Ok
   Record 433 write - Ok
   Record 434 write - Ok
   Record 435 write - Ok
   Record 436 write - Ok
   Record 437 write - Ok
   Record 438 write - Ok
   Record 439 write - Ok
   Record 440 write - Ok
   Record 441 write - Ok
   Record 442 write - Ok
   Record 443 write - Ok
   Record 444 write - Ok
   Record 445 write - Ok
   Record 446 write - Ok
   Record 447 write - Ok
   Record 448 write - Ok
   Record 449 write - Ok
   Record 450 write - Ok
   Record 451 write - Ok
   Record 452 write - Ok
   Record 453 write - Ok
   Record 454 write - Ok
   Record 455 write - Ok
   Record 456 write - Ok
   Record 457 write - Ok
   Record 458 write - Ok
   Record 459 write - Ok
   Record 460 write - Ok
   Record 461 write - Ok
   Record 462 write - Ok
   Record 463 write - Ok
   Record 464 write - Ok
   Record 465 write - Ok
   Record 466 write - Ok
   Record 467 write - Ok
   Record 468 write - Ok
   Record 469 write - Ok
   Record 470 write - Ok
   Record 471 write - Ok
   Record 472 write - Ok
   Record 473 write - Ok
   Record 474 write - Ok
   Record 475 write - Ok
   Record 476 write - Ok
   Record 477 write - Ok
   Record 478 write - Ok
   Record 479 write - Ok
   Record 480 write - Ok
   Record 481 write - Ok
   Record 482 write - Ok
   Record 483 write - Ok
   Record 484 write - Ok
   Record 485 write - Ok
   Record 486 write - Ok
   Record 487 write - Ok
   Record 488 write - Ok
   Record 489 write - Ok
   Record 490 write - Ok
   Record 491 write - Ok
   Record 492 write - Ok
   Record 493 write - Ok
   Record 494 write - Ok
   Record 495 write - Ok
   Record 496 write - Ok
   Record 497 write - Ok
   Record 498 write - Ok
   Record 499 write - Ok
   Record 500 write - Ok
   Record 501 write - Ok
   Record 502 write - Ok
   Record 503 write - Ok
   Record 504 write - Ok
   Record 505 write - Ok
   Record 506 write - Ok
   Record 507 write - Ok
   Record 508 write - Ok
   Record 509 write - Ok
   Record 510 write - Ok
   Record 511 write - Ok
   Record 512 write - Ok
   Record 513 write - Ok
   Record 514 write - Ok
   Record 515 write - Ok
   Record 516 write - Ok
   Record 517 write - Ok
   Record 518 write - Ok
   Record 519 write - Ok
   Record 520 write - Ok
   Record 521 write - Ok
   Record 522 write - Ok
   Record 523 write - Ok
   Record 524 write - Ok
   Record 525 write - Ok
   Record 526 write - Ok
   Record 527 write - Ok
   Record 528 write - Ok
   Record 529 write - Ok
   Record 530 write - Ok
   Record 531 write - Ok
   Record 532 write - Ok
   Record 533 write - Ok
   Record 534 write - Ok
   Record 535 write - Ok
   Record 536 write - Ok
   Record 537 write - Ok
   Record 538 write - Ok
   Record 539 write - Ok
   Record 540 write - Ok
   Record 541 write - Ok
   Record 542 write - Ok
   Record 543 write - Ok
   Record 544 write - Ok
   Record 545 write - Ok
   Record 546 write - Ok
   Record 547 write - Ok
   Record 548 write - Ok
   Record 549 write - Ok
   Record 550 write - Ok
   Record 551 write - Ok
   Record 552 write - Ok
   Record 553 write - Ok
   Record 554 write - Ok
   Record 555 write - Ok
   Record 556 write - Ok
Field 391
   Record 0 write - Ok
   Record 2 write - Ok
   Record 3 write - Ok
   Record 4 write - Ok
   Record 5 write - Ok
   Record 6 write - Ok
   Record 7 write - Ok
   Record 8 write - Ok
   Record 9 write - Ok
Done!
Elapsed: 00:00:03
Resetting selected items...
Check phone mode...
Phone in Local mode
Seting Test mode... wait...
Test mode set
Settings Full Factory Defaults...
Set OK!
Elapsed: 00:00:11
Software ver : V 07.31 12-01-12 RM-702 (c) Nokia
PPM     :      V 07.31 12-01-12 RM-702 (c) Nokia             SN
CNT     :      Content: sn_059L5S5 V 07.31 12-01-12 RM-702 (c) Nokia
Product SN   :     36B48DFAH
Product code :     05xxxxx
Base Prd.code:     059D007
Module code  :     0204579
Long Prod.SN :     0
Hardware info=======
HWID  : 1000
Batery: 3413 mV
CMT BT: 19b5-22012
LCDVer: TPO
Lock info ===========
IMEI       : 35xxxxxxxxxxxxx
IMEI spNet : 3A 85 36 09 04 48 11 06
IMEI svNet : 33 85 36 09 04 48 11 16 F1
Sl Conf  : 001-01-00000000000
Sl Prof  : 800000000003000-B
Sl Aux   : 000B0000
Hw Sig   : DB65E2F365EE89AF
Provider : Default Test Operator
Lock info:
Block 1
L1:Open;  L2:Open;  L3:Open;  L4:Open;  L5:Open;
Block 2
Block 3
Block 4
Block 5
Block 6
Block 7
CRT308 Backup Created
INFINEON : SuperDongle not exist (It is Ok)
SimLock status : Ok
Security status : Ok
PA_SL3 phone ,  SP_CODE_LEN : 15
User Code : 12345
MMC pwd  : no any record found
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
Old 07-20-2012, 10:40   #13 (permalink)
Dzirt's Avatar
Member: 1157320
Sonork: 100.1616907
Hehe, we seems, world first solve XG213 SECURITY failed test
The Following 3 Users Say Thank You to Dzirt For This Useful Post:
Old 07-30-2012, 17:14   #14 (permalink)
Marscel_Jr's Avatar
Member: 1121495
??????????? pls share....
Old 07-30-2012, 19:26   #15 (permalink)
Dzirt's Avatar
Member: 1157320
Sonork: 100.1616907
Share what? If you have BEST - you can fix it.
Service Provider Lock 1-4 ? StompSC Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 06-27-2012 11:00
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-16-1999 00:44
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 andrew bennett Main Sales Section 0 07-09-1999 10:41
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-16-1999 08:41
Page generated in 0.64891 seconds with 11 queries
