05-31-2014, 11:23 | #1 (permalink) |
Freak Poster Join Date: Aug 2010 Location: pakistan lalamusa
Member: 1378080 Status: Offline Sonork: 100.1621571 Thanks Meter: 172 | C5 after flash Dead? I already checked by 2time flashed but same problem how can recover my phone? i flahed that version 071.005 |
05-31-2014, 11:35 | #2 (permalink) | |
No Life Poster Join Date: Feb 2006
Member: 237256 Status: Offline Thanks Meter: 91 | Quote:
1. Select MCU file 2. Select PPM Language file(say MEA) 3. Select ENO File (3rd position) 4. Select UDA File (last position) Do not mine how Best dongle arranges it for you on the software interface but follow the above procedure and flash and you problem is solved. You can send me an email ([email protected]) if this does not solve your problem. | |
The Following User Says Thank You to pastor good For This Useful Post: |
05-31-2014, 11:59 | #3 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | 1. Need check it RM-xxx version. 2. If you sure in RM - make Restore SL. Erase and reflash it. Repair rest things. |
The Following User Says Thank You to Dzirt For This Useful Post: |
05-31-2014, 13:56 | #4 (permalink) | |
Insane Poster Join Date: Jul 2011
Member: 1619960 Status: Offline Sonork: 100.1613623 Thanks Meter: 68 | follow these steps step by step you phone will alive again Quote:
bro follow these steps step by step first ** check the rm-645 or rm-745 if you flashed phone with wrong firmware then re-flash phone with correct firmware it will be alive second ** if the version of firmware before you flashed phone was "032.010_10.01" sometimes you must back to the previous firmware (make downgrade) third ** if you was flashed phone with correct firmware then it dead then backup IMEI & simlock then erase phone and re flash it again and restore backup and do all repaier SDD& Security >>>> it will be working again _________________ note: to backup imei & simlock go to repair tab in best infinity interface then click on restore SL then connect phone via usb when finished go to backup file and check it is correct or not if backup file OK then erase phone and continue try and post the result Last edited by Progman; 05-31-2014 at 14:02. | |
The Following User Says Thank You to Progman For This Useful Post: |
05-31-2014, 15:36 | #5 (permalink) |
Member: 1378080 Status: Offline Sonork: 100.1621571 Thanks Meter: 172 | My Half Problem is solved. BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Damaged!!!!! CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! How to recover SDD key status : Damaged!!!!! ??? I HAVE REAd full rpl and i restore Sl Before flash? i dont understand that what i do? |
05-31-2014, 15:41 | #6 (permalink) |
Member: 1378080 Status: Offline Sonork: 100.1621571 Thanks Meter: 172 | Thanx Infinity team i Recover my set Here is logs. Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 356989043128606 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-645.pm Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => OK Done! Elapsed: 00:00:01 Upload done Reading Phone Info.... Connected phone - Nokia C5-00 Software ver : V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia IMEI : 356989043128606 XappVer : 0000073A Ape Ver : 071.005 APE Var : 071.005071.005.12.01071.005.C00.01 APE ADSP: 256 DSP Ver : ICPR82_11w16 APE Test: 10wk48v0.001_APEONLY PPM : CNT : Product SN : 0 Product code : Long Prod.SN : 0 Hardware info======= HWID : Retu : 35 Tahvo : 00 Batery: 4037 mV APE HW: 256 Lock info =========== IMEI : 356989043128606 IMEI spNet : 3A 65 89 09 34 21 68 00 IMEI svNet : 33 65 89 09 34 21 68 10 F5 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! |
05-31-2014, 16:02 | #7 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Glad to see your problem solved. This error (dead phone) happen due Nokia bug exactly on C5 latest 7xx.xx FW , and this way always help recover phone. |
06-01-2014, 13:44 | #8 (permalink) |
Junior Member Join Date: May 2014 Location: in the world of communication
Member: 2179104 Status: Offline Thanks Meter: 0 | Did, you make back up of rpl and pm file ? , secondly firstly switch on your mobile without insert sim card if its on then , switch on this mobile with insert sim card . i face same problem 2 days ago and its resolved . |
