06-15-2014, 13:36 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | C6-01 simcard registration failed how i can solve it....anyone help me plzzzzzz? and also tell if hardware problem....... info: card found: S/N ****:**** registered to: gsm city Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia C6-01 Software ver : V 79_sr1_12w18.5 27-07-12 RM-718 (c) Nokia IMEI : 353759047556562 XappVer : 00000776 Ape Ver : 111.040.1511 APE Var : 111.040.1511111.040.1511.10.01111.040.1511.C00.01 APE ADSP: 256 DSP Ver : 92_12w18 APE Test: 0.064 PPM : CNT : Product SN : CYE391869 Product code : 059C3B8 Base Prd.code: 059C012 Module code : 0204365 Long Prod.SN : 0 Hardware info======= HWID : 0600 Retu : 40 Tahvo : 00 Batery: 3957 mV APE BT: HCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 3472. APE HW: 256 Lock info =========== IMEI : 353759047556562 IMEI spNet : 3A 35 57 09 74 55 56 06 IMEI svNet : 33 35 57 09 74 55 56 46 F5 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! |
06-16-2014, 06:12 | #5 (permalink) | |
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | Quote:
Initializing Tests... IMEI : 353759047556562 , Phone : RM-718 Nokia C6-01 Get keys... PASSED | ST_SLEEP_X_LOOP_TEST PASSED | ST_UEM_CBUS_IF_TEST PASSED | ST_EAR_DATA_LOOP_TEST PASSED | ST_SIM_CLK_LOOP_TEST PASSED | ST_SIM_LOCK_TEST PASSED | ST_SECURITY_TEST PASSED | ST_PWR_KEY_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_BACKUP_BATT_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_BTEMP_TEST PASSED | ST_MBUS_RX_TX_LOOP_TEST PASSED | ST_KELVIN_BATVOLTAGE_TEST PASSED | ST_KELVIN_VIBRA_TEST PASSED | ST_KELVIN_CAPACITOR_TEST PASSED | ST_KELVIN_MISC_TEST PASSED | ST_KELVIN_AUDIO_TEST PASSED | ST_KELVIN_XEAR_TEST PASSED | ST_AMB_LIGHT_SENSOR_TEST PASSED | ST_USB_CHARGING_TEST PASSED | ST_DIGIMIC_TEST PASSED | ST_HEADSET_AMPLIFIER_TEST PASSED | ST_LED_CONTROLLER_TEST PASSED | ST_AUDIO_PLL_TEST PASSED | ST_RAM_IF_TEST NOT EXECUTED | ST_CDSP_SLEEPCLOCK_FREQ_TEST NOT EXECUTED | ST_CDSP_RF_BB_IF_TEST NOT EXECUTED | ST_CDSP_STROBE_TEST NOT EXECUTED | ST_CDSP_DIGI_RXTX_IF_TEST NOT EXECUTED | ST_CDSP_RF_SUPPLY_TEST NOT EXECUTED | ST_CDSP_PA_ID_PIN_TEST NOT RUN | ST_CDSP_WCDMA_TX_POWER_TEST SelfTests end | |
06-16-2014, 08:20 | #9 (permalink) |
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | in local mode: result: Initializing Tests... IMEI : 353759047556562 , Phone : RM-718 Nokia C6-01 Get keys... PASSED | ST_SLEEP_X_LOOP_TEST PASSED | ST_UEM_CBUS_IF_TEST PASSED | ST_EAR_DATA_LOOP_TEST PASSED | ST_SIM_CLK_LOOP_TEST PASSED | ST_SIM_LOCK_TEST PASSED | ST_SECURITY_TEST PASSED | ST_PWR_KEY_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_BACKUP_BATT_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_BTEMP_TEST PASSED | ST_MBUS_RX_TX_LOOP_TEST PASSED | ST_KELVIN_BATVOLTAGE_TEST PASSED | ST_KELVIN_VIBRA_TEST PASSED | ST_KELVIN_CAPACITOR_TEST PASSED | ST_KELVIN_MISC_TEST PASSED | ST_KELVIN_AUDIO_TEST PASSED | ST_KELVIN_XEAR_TEST PASSED | ST_AMB_LIGHT_SENSOR_TEST PASSED | ST_USB_CHARGING_TEST PASSED | ST_DIGIMIC_TEST PASSED | ST_HEADSET_AMPLIFIER_TEST PASSED | ST_LED_CONTROLLER_TEST PASSED | ST_AUDIO_PLL_TEST PASSED | ST_RAM_IF_TEST PASSED | ST_CDSP_SLEEPCLOCK_FREQ_TEST PASSED | ST_CDSP_RF_BB_IF_TEST PASSED | ST_CDSP_STROBE_TEST PASSED | ST_CDSP_DIGI_RXTX_IF_TEST PASSED | ST_CDSP_RF_SUPPLY_TEST PASSED | ST_CDSP_PA_ID_PIN_TEST NOT RUN | ST_CDSP_WCDMA_TX_POWER_TEST PASSED | ST_KEYBOARD_STUCK_TEST PASSED | ST_BT_IF_TEST PASSED | ST_CAMERA_IF_TEST PASSED | ST_CAMERA_ACCELERATOR_TEST PASSED | ST_SEC_CAMERA_IF_TEST PASSED | ST_LED_FLASH_TEST PASSED | ST_BT_AUDIO_IF_TEST PASSED | ST_MAIN_LCD_IF_TEST PASSED | ST_TOUCH_TEST PASSED | ST_TOUCH_IF_TEST PASSED | ST_BT_WAKEUP_TEST PASSED | ST_WLAN_TEST PASSED | ST_ACCEL_IF_TEST PASSED | ST_VIBRA_TEST NOT RUN | ST_USB_LOOP_TEST PASSED | ST_MAGNETOMETER_TEST PASSED | ST_USB_CHARGER_IF_TEST PASSED | ST_LED_FLASH_IF_TEST SelfTests end |
06-16-2014, 08:22 | #10 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | It is OK due seltest log. You can try do next : 1. Read PM backup 2. Make SX4 , write other PM file ( it should be in BEST already, so just SX4 ) Make factory sets and try after. |
06-16-2014, 08:38 | #11 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Hi, Phone is barred (blocked) on operators .. Not really the reason your phone should b running on some contract or etc to get blocked .. Many People r fixing chinese based phones with same IMEI all the time resulting a working phone with same IMEi on network getting blocked .,or issues like above Br, |
06-16-2014, 08:58 | #12 (permalink) | |
bundle of thankssssss | |
06-16-2014, 09:00 | #13 (permalink) | |
