Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 07-03-2016, 20:26   #1 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Can I use my own SX4 card when unlocking Lumia phones ?
Hi I got my own SX4 unlimited card, Can I use it when unlocking Lumia phones with bb5best ?
I see some time your sx4 server got problem with autorization and if I will use my own card this problem should not egsist ?
Old 07-03-2016, 22:18   #2 (permalink)
Member: 128745
Thanks Meter: 16,936
run config software update settings. then unlock again
all will be fine
Old 07-04-2016, 10:00   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
If local SX4 card inserted in PC - SW will use it. Also you can make separate SX4 auth before unlock - SW will use your card.
The Following User Says Thank You to JayDi For This Useful Post:
Old 02-18-2017, 12:32   #4 (permalink)
jodge's Avatar
Member: 61389
Thanks Meter: 193
can i use my sx4 card for BB5 operations too? Bcose the local SX4 Auth button is disabled
Old 02-18-2017, 16:29   #5 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
local sx4 is a patch that kill orginal data from phone then when you got own card this future is not important becouse more damage then help.
The Following User Says Thank You to wgmmmx1 For This Useful Post:
Old 02-19-2017, 12:36   #6 (permalink)
JayDi's Avatar
Member: 462970
What it damage? Nothing. It just write OWN SD keys, which NOT require FACTORY keys.
Old 02-20-2017, 21:06   #7 (permalink)
jodge's Avatar
Member: 61389
Thanks Meter: 193
need the whole fps20+sx4+phoenix combo to recognise the Best? Or a special driver or other reader just bcose the best don't see when the card is in a common alcor reader
thx
Old 02-21-2017, 16:06   #8 (permalink)
JayDi's Avatar
Member: 462970
Hello.
I had tested it with PKEY readers ( old jaf and rockey keys )
But in theory, it should work with alcor as well.
Card poling work only on separate SX4 ( not in unlock flow )
Old 02-21-2017, 17:54   #9 (permalink)
jodge's Avatar
Member: 61389
Thanks Meter: 193
Not found, it seems it's not looking at all just bcose the sx4 reader led not flashing and the error message appearing extremely fast (like any other ATR operation )
i'v tried both sx4 auth button
The only reason why i'm forcing this is your SX4 server is sometimes overloaded or unavailable. And of course that time arriving an impatitant xxxx customer.
I hope you understand
thx
Old 02-21-2017, 18:23   #10 (permalink)
JayDi's Avatar
Member: 462970
If there is a chance to try with one of tested readers - that would be great. I have no alcor reader and can't say any eta, when can get it for a test.
BTW we have 2 servers, one can be tuned up with configurator SW ( on support, main dir ) and one is default. You can switch it by a seconds, if current load or offline.
Old 02-21-2017, 20:18   #11 (permalink)
jodge's Avatar
Member: 61389
Thanks Meter: 193
I found a PKEY reader, but the problem is same as before. The error is very quick and w/o any led blinking.
BTW when will be the pin ask? Under the operation or i have to put in the settings file?
Unfortunately i have experienced some freezing and connection error under lumia unlock (sx4 phase). Like the topic starter
Old 02-22-2017, 04:53   #12 (permalink)
JayDi's Avatar
Member: 462970
I not seen cards with enabled PIN at all. Normally SW check all free readers, connect to them and ask for access. If it granted - it verify about SX4 applet exists and use it.
If card has enabled pin - it will not allow access.
Page generated in 0.16701 seconds with 8 queries
