Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 03-29-2013, 07:59   #1 (permalink)
chipset experts's Avatar
Member: 1312914
Thanks Meter: 111
Question can nokia 114 cross flash with nokia 110..
@dzirt..
can nokia 114 cross flash with nokia 110.. both have same rm-827
Old 03-29-2013, 13:06   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,160
Yes, can be cross-flashed well.
The Following User Says Thank You to Dzirt For This Useful Post:
Old 04-17-2013, 13:22   #3 (permalink)
Member: 1315734
both 110 nd 114 have the same flash file
Old 05-13-2013, 17:42   #4 (permalink)
Member: 1107485
Thanks Meter: 70
Yes.we know nokia 114 110 is rm-827 but. i have flash this file rm-827 after set is dead..
Old 05-13-2013, 18:53   #5 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,160
Hello. Without logs I can't say anything.
Old 05-14-2013, 10:55   #6 (permalink)
Member: 1107485
Thanks Meter: 70
nokia 114 dead after flash this file rm-827
Number of Image Files: 3
Processing Image File :
rm827__03.04.mcusw
rm827__03.04.ppm_mh1
rm827__03.04.image_mh1_059N0N5
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Intel Electronics Corp.
Flash Boot Successful...
Unique Data: 12600C0D8B162814
Original Product Code: 059Q9H7
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\355221052051805\3552210520518 05_30907.rpl
Data Sections : 04
Current File : rm827__03.04.mcusw
Compile Name: rm827__03.04.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 27266440 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: 43E7
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 7A82
Processing Section 03
FIRMWARE Erase Block: 0x40060000~0x4015FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: 45C5
Processing Section 04
FIRMWARE Erase Block: 0x40280000~0x41BBFFFE
Start Erasing...
Block Erase Done...
Data Size: 25952256 bytes
Data Checksum: DCD4
Processing Section 05
FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE
Start Erasing...
Block Erase Done...
Data Verification Successful...
Data Sections : 01
Current File : rm827__03.04.ppm_mh1
Compile Name: package_mh1.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 3272372 Bytes
PPM Certificate Block Sent Successfully...
PPM Erase Block: 0x41BC0000~0x421BFFFE
Start Erasing...
Block Erase Done...
Data Size: 3269028 bytes
Data Checksum: 76D9
PPM Data Blocks uploaded to phone...
Data Sections : 01
Current File : rm827__03.04.image_mh1_059N0N5
Compile Name: package_mh1_059N0N5.image.fls
Image Type : CONTENT Package
Data Size : 15600912 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x421C0000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 15597568 bytes
Data Checksum: C0F4
CONTENT Data Blocks uploaded to phone...
CONTENT Erase Block: 0x43E60000~0x43F3FFFE
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:05:28
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Old 05-14-2013, 11:16   #7 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,160
So, what you are forget here? Go to ATF section and ask about problem.
Old 05-15-2013, 05:54   #8 (permalink)
fahad ali khan's Avatar
Member: 1771086
Thanks Meter: 2,403
nokia 114 RM-827 after flashing Date Time show then auto off give me solution
Old 05-15-2013, 12:10   #9 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,160
Solution is simple - try repair your phone.
Or start learn how to ask properly.
Old 05-19-2013, 06:19   #10 (permalink)
Member: 1771086
Thanks Meter: 2,403
what do u mean i can not understand ........
my English is not good ...
Old 05-19-2013, 08:46   #11 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,160
So, why not try use translator? They are much now. Try with google translator, for example.
Here is BEST support section, so, ask something without logs of BEST sw - useless.
Old 05-22-2013, 10:16   #12 (permalink)
naushad09's Avatar
Member: 216094
Thanks Meter: 304
FLASHING VERY WELL LIKE MASKA ..................
Useless log text deleted
Old 05-22-2013, 11:03   #13 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,160
My dear very stupid friend! I want say again - here is BEST section. Not ATF. Go to correct section and post your stupid rumors, explores, sucesses and e.t.c.
Old 05-23-2013, 06:18   #14 (permalink)
naushad09's Avatar
Member: 216094
Thanks Meter: 304
hello my Dear frndz ..........just keep ur language on ur mind dont show here understand.
i have both log aft and infinity but by mistakely i copy atf log thzt why nothing els..
I FLASH 114 WITH FILE 110 RM-827
ALL IS WELL THNX INFINITY TEAM
REPORT HERE
registered to: naushad09
Connect phone on selected interface...
Core : v1.63 , BB5XG FlashEngine : v4.1
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm827__03.04.mcusw
PPM : rm827__03.04.ppm_mh1
PPM2 : rm827__03.04.ppm_mh1
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" - just reinsert battery
-> If flashing freeze - reinsert cable and try again
--- Press phone's power button or insert charger! ---
Connection opened successfully
DBG : F00A1FB300020303010100FF
CPUID : XGOLD 213
2nd boot Ok, 01
2nd ready, AA
Sending Algo
Algo sent Ok
BL : Quantum_Bootloader_10.49_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 355221055740024
IMEI 2 : 355221055740032
PCcode : Z%i
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : c:\InfinityBox\BEST\Backup\Cert\355221055740024_XG 213_CRT.rpl
===Flashing [MCU]===
Image : rm827__03.04.mcusw_ebl_psi.fls
Cert block found, sending....
Cert sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:05
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01940000
Erasing, wait ...
Erase done, time : 00:02:21
Write , Start : 0x40280000 , Len : 0x018C0000
Flashing , wait ...
Region flash done, time : 00:00:37
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
===Flashing [PPM]===
Image : package_mh1.ppm_ebl_psi.fls
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41BC0000 , Len : 0x00600000
Erasing, wait ...
Erase done, time : 00:00:17
Write , Start : 0x41BC0000 , Len : 0x0031E1A4
Flashing , wait ...
Region flash done, time : 00:00:03
Flashing done!
Total flash time : 00:03:29
Reboot phone now...
Reading Phone Info....
Connected phone - C2-00
Software Info: V 03.04 20-04-12 RM-704 (c) Nokia
IMEI: 355221055740024
PPM version : V 03.04 20-04-12 RM-827 (c) Nokia MH1
Product code: 059Q9J5
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
ProductTuneSet...OK!
SwUpgradeSet...OK!
Checking User Certificates...
Total - 42 certs
Data exist, skip certificate repair...
AfterFlash operations done ;D
Done!
Elapsed: 00:04:08
Phone found!
Series 40 Device detected!
read info... - Ok
AND IF U CAN DO SO DELETE MY ATF POST
The Following 3 Users Say Thank You to naushad09 For This Useful Post:
Old 05-23-2013, 07:14   #15 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,160
Ok, now all clear for me. Sorry.
Page generated in 0.38566 seconds with 8 queries
