07-21-2017, 15:27 | #1 (permalink) | |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | NOKIA_105_RM_1133_059W9Z8_IJ_v15.00.11_Urdu_Arabic _Pashto Firmware Quote:
NOKIA_105_RM_1133_059W9Z8_IJ_v15.00.11_Urdu_Arabic _Pashto_Akhtar Ali Jatt | |
The Following 15 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
07-22-2017, 09:47 | #2 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Every 1's heart
Member: 682054 Status: Offline Sonork: 100.1602688 Thanks Meter: 144 | Quote:
The Following 2 Users Say Thank You to killme12 For This Useful Post: |
07-22-2017, 10:21 | #3 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Yes Bro Above File Contain Urdu Farsi And Pashto , Here is New Files With IC Languages Contain Arabic French Portuguese NOKIA_105_RM_1133_059W9Z6_IC_v15.00.11_Arabic _French_Portuguese_Akhtar Ali Jatt |
The Following 6 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
03-15-2019, 14:41 | #4 (permalink) | |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Quote:
I Flash This Ver Mobile Go Contact Service .... Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.09 Open VPLfile : RM-1133_059X000_15.00.11.vpl Description : RM-1133 059X000 IJ 15.00.11 DeviceType : RM-1133 ProductCode : 059X000 SoftwareVer : 15.00.11 PPM LangPack : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.09 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM3) MODE : NOKIA USB SERIAL PORT : 3 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 073DE761EFF5727722A5A1D575CB0429 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : LAGOS61D.10.01.11.p2 BOOT : SWR : 10.01.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : LAGOS61D.10.01.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 15.00.11 [RM-1133] DEV SoftwareVersion : 10.01.11 SWInfo compare result : DEVICE SW ( Minor version ) is LOWER, than in VPL! Load FlashSet : MROM : RM-1133_LAGOS_ROM_eMP_15.00.11 LANG : RM-1133_LAGOS_LANG_PACK_ROM_IJ_eMP_15.00.11 CUST : RM-1133_LAGOS_CUSTPACK_ROM_IJ_eMP_15.00.11 JUMP : RM-1133_LAGOS_JUMP_TABLE_IJ_eMP_15.00.11 VIVA : RM-1133_LAGOS_VIVA_eMP_15.00.11 Prepare FlashSet : DCR : RM-1133_LAGOS_ROM_eMP_15.00.11 DCR : RM-1133_LAGOS_LANG_PACK_ROM_IJ_eMP_15.00.11 DCR : RM-1133_LAGOS_CUSTPACK_ROM_IJ_eMP_15.00.11 DCR : RM-1133_LAGOS_JUMP_TABLE_IJ_eMP_15.00.11 DCR : RM-1133_LAGOS_VIVA_eMP_15.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : RM-1133_LAGOS_ROM_eMP_15.00.11 Write : RM-1133_LAGOS_LANG_PACK_ROM_IJ_eMP_15.00.11 Write : RM-1133_LAGOS_CUSTPACK_ROM_IJ_eMP_15.00.11 Write : RM-1133_LAGOS_JUMP_TABLE_IJ_eMP_15.00.11 Write : RM-1133_LAGOS_VIVA_eMP_15.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1133_LAGOS_ROM_eMP_15.00.11 Verify : RM-1133_LAGOS_LANG_PACK_ROM_IJ_eMP_15.00.11 Verify : RM-1133_LAGOS_CUSTPACK_ROM_IJ_eMP_15.00.11 Verify : RM-1133_LAGOS_JUMP_TABLE_IJ_eMP_15.00.11 Verify : RM-1133_LAGOS_VIVA_eMP_15.00.11 Done! Elapsed: 00:01:34 Reconnect Power/Cable! I Flash This Ver RM-1133_10.01.11 Contact service problem solved Contact Service Problem Solved .... Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.09 Open VPLfile : RM1133_059W9Z6_10.01.11.vpl Description : RM-1133 NDT MEA IC ARABIC JO DeviceType : RM-1133 ProductCode : 059W9Z6 SoftwareVer : 10.01.11 PPM LangPack : [1] : Arabic (Saudi Arabia) [2] : Portuguese (Portugal) [3] : French (France) [4] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.09 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM3) MODE : NOKIA USB SERIAL PORT : 3 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 073DE761EFF5727722A5A1D575CB0429 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : LAGOS61D.15.00.11.p1 BOOT : SWR : 15.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : LAGOS61D.15.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 10.01.11 [RM-1133] DEV SoftwareVersion : 15.00.11 SWInfo compare result : VPL SW ( Minor version ) is LOWER, than in DEVICE! Load FlashSet : MROM : RM-1133_ROM_eMP_10.01.11 LANG : RM-1133_LANG_PACK_ROM_IC_eMP_10.01.11_004 CUST : RM-1133_CUSTPACK_ROM_IC_MEA_JO_eMP_10.01.11_004 JUMP : RM-1133_JUMP_TABLE_IC_MEA_JO_eMP_10.01.11_004 VIVA : RM-1133_VIVA_eMP_10.01.11 Prepare FlashSet : DCR : RM-1133_ROM_eMP_10.01.11 DCR : RM-1133_LANG_PACK_ROM_IC_eMP_10.01.11_004 DCR : RM-1133_CUSTPACK_ROM_IC_MEA_JO_eMP_10.01.11_004 DCR : RM-1133_JUMP_TABLE_IC_MEA_JO_eMP_10.01.11_004 DCR : RM-1133_VIVA_eMP_10.01.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : RM-1133_ROM_eMP_10.01.11 Write : RM-1133_LANG_PACK_ROM_IC_eMP_10.01.11_004 Write : RM-1133_CUSTPACK_ROM_IC_MEA_JO_eMP_10.01.11_004 Write : RM-1133_JUMP_TABLE_IC_MEA_JO_eMP_10.01.11_004 Write : RM-1133_VIVA_eMP_10.01.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1133_ROM_eMP_10.01.11 Verify : RM-1133_LANG_PACK_ROM_IC_eMP_10.01.11_004 Verify : RM-1133_CUSTPACK_ROM_IC_MEA_JO_eMP_10.01.11_004 Verify : RM-1133_JUMP_TABLE_IC_MEA_JO_eMP_10.01.11_004 Verify : RM-1133_VIVA_eMP_10.01.11 Done! Elapsed: 00:01:15 Reconnect Power/Cable! Note Dear Sir I Am Only Report .. Last edited by A.G.Shahid; 03-15-2019 at 14:47. | |
07-12-2019, 16:33 | #6 (permalink) | |
Freak Poster Join Date: Feb 2010 Location: karachi pakistan
Member: 1237819 Status: Offline Sonork: [email protected] Thanks Meter: 148 | Quote:
bro greet work your solution 100% ok tested | |
