Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 02-13-2013, 11:30   #1 (permalink)
Member: 1698387
Thanks Meter: 43
Cant flash E60 rm-49
PLease help i cant flash this phone.
What can be the problem?
Phone found!
Series 60 Device detected!
read info... - Ok
Reading Phone Info....
Connected phone - Nokia Mars 3G
Software ver : V 05w09ssi 17-03-05 RM-49 (c) Nokia.
IMEI : 004400431674686
DSP Ver : 05w07v2
PPM :
CNT :
Product SN : SYB018406
Product code : 0519047
Base Prd.code: 0518971
Hardware info=======
HWID : 0511
Retu : 32
Tahvo : 41
Batery: 4482 mV
RF ic : 150a160e
Lock info ===========
IMEI spNet :
IMEI svNet :
Unable to read Lock table...
User code : Crypted
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
Core : v1.60 , BB5XG FlashEngine : v3.9
Selected FlashSettings : FullFlash
Files Set for Flashing :
MCU : rm49_m128_h20_km_prod_306330904_c00_combined.bin
PPM : rm49_m128_h20_km_prod_306330904_v06_variant.bin
CNT : RM49_0519047_3.0633.09.04_001_signature.bin
Checking BUS...
Switch jaf to FlashMode...
FlashMode set Ok
Booting phone...
BOOT 1ST : C0
APE part info :
APE ASICID : 17100701
APE MODE ID : 00
APE PUB ID : F48DED9E45FCD4712B984761E5D19CA4C24D49FE
APE R_HASH : 2C05369F57CC3C4CF9E783E83D9B512B
APE ROM ID : AB5E4ADB27A06946
CMT part info :
CMT ASICID : 000000010000022600010006000C192101002100
CMT EM0 ID : 00000232
CMT EM1 ID : 00000341
CMT PUB ID : 0950000F1C7D4F579DA1293B7DBAEE3D41CE1262
CMT MODE ID : 00
CMT R_HASH : E9EFF4BFAA5393217CA6B17755FC3E14
CMT ROM ID : F28A211FAC901AEE
CMT : Sending 2nd loader...
Use : RAP3Gv2_2nd.fg , Rev : 0.0 Ver : 1.21.0
CMT Loader sent, Boot Ok
MCU configuration
CMT Flash ID : 22FA00EC < SAMSUNG [SEC] => K8S6415ETA
FLASHID : 22FA00EC , CMT , NOR
FLCNT : 00000000000000000000000000000000000000
CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok
FLASHID : 0000FFFF , CMT , MMC , EXT
TransmissionReq : 16 bit, Single
TransmissionReq : Accepted, 16 bit, Single
Sending ALGO....
Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0
CMT Algo sent!
TransmissionReq : 32 bit, Dual
TransmissionReq : Accepted, 32 bit, Dual
PAPUBKeys : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78DC1
APE : Sending 2nd loader...
Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0
APE Loader sent, Boot Ok
MCU configuration
APE Flash ID : 003600EC < SAMSUNG [SEC] => K5E1212ACM [NAND]
FLASHID : 003600EC , APE , NAND
ReqAlgo : APE , OMAP1710 UNISTORE-II-1.2.1 ALG
FLCNT : 01010000020000000600000000000000000000
Sending ALGO....
Use : h3_sam_nand_xsr.fg , Rev : 0.0 Ver : 1.47.0
APE Algo sent!
Boot done!
Partitioning....
Partitioning error : 020000099D
Partitioning failed!
Error...
Connect phone on selected interface...
Switch jaf to FBUS...
FbusMode set Ok
Phone found!
read info... - Ok
Old 02-13-2013, 16:03   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Hello , for start - check files.
Also, seems, something not work correctly with this phone.
I will try check it tomorrow.
The Following User Says Thank You to Dzirt For This Useful Post:
Old 02-15-2013, 14:54   #3 (permalink)
Member: 1698387
Thanks Meter: 43
Hello
My *******r said this phone is prototype. Do you think is true?
Old 02-15-2013, 15:10   #4 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Sad. Was ask user test E60 - all done without problems.
Try with hwk, if exist.
Old 02-15-2013, 15:35   #5 (permalink)
Member: 1698387
Thanks Meter: 43
I don't have hwk only jaf box.
When i read info it say sl damaged. after i repair sl it say sdd damaged.
Old 02-15-2013, 16:06   #6 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Info logs? Need check them. Interest.
Old 02-15-2013, 18:13   #7 (permalink)
Member: 1698387
Thanks Meter: 43
Here is the progress i made whit this phone.
1, read info
2, repair tab ,check sl/sd/security/cmla
3, repair SDD
4, repair tab check sl/sd/security/cmla
5, read info
6, repair tab ,repair sl
7, read info ,everything is looks ok by now but after disconect fbus and reconnect it same problem appairs.
What can be the problem? Please help thank you
Opening Connection...
Device Location: 00000022
Connect Ok!
Initializing Connection...
JAF Firmware: 01.B5
JAF S/N ODUQR8XZ boot - Ok
FbusMode set Ok
Phone found!
read info... - Ok
DSP Ver : 05w07v2
PPM :
CNT :
HWID : 0511
Retu : 32
Tahvo : 41
Batery: 4344 mV
RF ic : 150a160e
IMEI spNet :
IMEI svNet :
User code : Crypted
Done!
Checking StartUp data ...
SDD Key status : SDData Damaged!!!!!
- > Do REPAIR SDD , Local SX4 if needed
CMLA Key status : CMLA key Not exist
SimLock status : SimLock is Ok
Security status : Security is Ok
PA_SimLock Version :
PA_SL phone detected
Done!
Repair SD procedure started...
Phone Imei: 004400431674686
Key file exists, no need to read...
Operating mode is OK, no need change...
Writing Super Dongle Key... Ok
Done!
Phone found!
read info... - Ok
SDD Key status : SDData is Ok
Done!
DSP Ver : 05w07v2
PPM :
CNT :
HWID : 0511
Retu : 32
Tahvo : 41
Batery: 4578 mV
RF ic : 150a160e
IMEI spNet :
IMEI svNet :
Conf key : FFFFFFFFFFFFFFFF
Provider key : FFFFFFFFFFFFFFFF
= > SL Error detected
= > SP Data Corrupted!!! Use Repair SL for Unlock/Repair phone!!!
Country : Unknown
Operator : Unknown
Counters : Key 0 [3] , Fbus 0 [10]
Blocks : 1
LOCK STATUS :
BLK : 1
Lock1:Close
LOCKS : Closed
User code : Crypted
Done!
Repair SL procedure started...
Writing SimLock Data... Ok
Writing SimLock Key... Ok
Done!
DSP Ver : 05w07v2
PPM :
CNT :
HWID : 0511
Retu : 32
Tahvo : 41
Batery: 4581 mV
RF ic : 150a160e
IMEI spNet :
IMEI svNet :
Conf key : 0000000000000000
Provider key : 2440700000000000
Country : Finland
Operator : NOKIA (Open)
Blocks : 7
LOCK STATUS :
BLK : 1
Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS : All Open
User code : Crypted
Done!
AFTER RECONNECT!
DSP Ver : 05w07v2
PPM :
CNT :
HWID : 0511
Retu : 32
Tahvo : 41
Batery: 4595 mV
RF ic : 150a160e
IMEI spNet :
IMEI svNet :
User code : Crypted
Done!
Done!
Old 02-16-2013, 07:14   #8 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Interest, seems this phone is prototype.
No have idea how make something with it without phone on hands
But try after Repair SDD and Repair SL make factory sets 3-5 times. An Set Normal mode via SW.
Old 02-18-2013, 10:57   #9 (permalink)
Member: 1698387
Thanks Meter: 43
Its not working. Maybe its hardware problem.
Thank you
Page generated in 0.19744 seconds with 8 queries
