07-11-2016, 21:30 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | Can't use navifirm Card found: S/N : xxxxxxxx , v0122 Registered to: dragosgsm Connect phone on selected interface... Wrong data! Check if your PC is correct! Wrong data! Check if your PC is correct! |
07-11-2016, 22:00 | #3 (permalink) | |
2. set correct time at your PC | |
08-12-2016, 14:08 | #4 (permalink) |
Junior Member Join Date: Dec 2007 Location: Bangladesh Age: 39
Member: 656861 Status: Offline Sonork: 123123 Thanks Meter: 15 | Same Problem v 2.23 letest. pc time n date is ok. Card found: S/N : xxxxxx , v0122 Registered to: sktctg Connect phone on selected interface... Wrong data! Check if your PC is correct! Wrong data! Check if your PC is correct! |
08-26-2016, 12:42 | #6 (permalink) |
Freak Poster Join Date: May 2006 Location: Italy
Member: 283098 Status: Offline Thanks Meter: 7 | I have the same problem, selecting ENO files , do not I see the Download button . by entering the code Product ENO files correspondent says : SSChannel : Create SC SSChannel : Failed to get info! ...... |
