06-11-2015, 15:10 | #1 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Chinese Miracle-2 (Test Version) free Activation for Infinity-Box [BEST] users - You can activate Chinese Miracle-2 (Test Version) Coolsand/Spredtrum/MediaTek for your Main Infinity-Box or Infinity-Box [BEST] or Infinity-Box CDMA-Tool. - Chinese Miracle-2 (Test Version) Activation is FREE - After Activation you can use Chinese Miracle (Test Version) v0.xx - You can activate Chinese Miracle-2 (Release) Coolsand/Spredtrum/MediaTek/Rockchip for your Infinity-Box [BEST] or Infinity-Box CDMA-Tool. - Chinese Miracle-2 (Release) Activation is not free VERY IMPORTANT: - You must use Infinity-Box [BEST] v2.08 or higher after Chinese Miracle-2 (Test Version) Activation ! - If you have DC-Unlocker Activation: use DC-Unlocker Client version 1.00.1190 or higher after Chinese Miracle-2 (Test Version) Activation ! How to Activate Chinese Miracle-2 (Test Version) for Free: 1. Login to your Infinity Online Service (IOS) account (you have it created already) 2. Go to Products menu 3. Select Software activations item 4. Select Activation depends on your Box/Dongle type: - Chinese Miracle-2 (Test Version) software activation for Main Infinity-Box - Chinese Miracle-2 (Test Version) software activation for Infinity-Box [BEST] - Chinese Miracle-2 (Test Version) software activation for Infinity-Box CDMA-Tool 5. Click to Buy button 6. You will see a confirmation and Activation status 7. Run DongleManager software and update your Smart-Card firmware 8. Now you can use new software How to know your Infinity Online Service Login/Password: - Each Infinity-Box User already has a free Infinity Online Service (IOS) Account. Read your Login/Password from your Dongle and you can login into IOS: Infinity-Box - Online Service How to get (Test Version) software: 1. Download (Test Version) software 2. Download and install: InfinityBox_install_CM2xxx_v0.XX.rar How to fix problem with Dongle Firmware update: - http://forum.gsmhosting.com/vbb/f296...lated-1950792/ - If you have FT-SCR2000 Card-Reader you should update your Card-Reader Drivers: Download CardReader_Fetian_FT2K_x32_x64 Drivers and read instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f If you have SPT-Box Activation and it stop to work after Smart-Card update: 1. Go here: SPT-Box software activation for USTPRO2 and Infinity-Box 2. Download Activator from: SPT-Box Support Area 3. Run Activator.exe 4. Enetr your data 5. You will get user.ini file 6. Copy user.ini into folder with SPT software 7. Run SPT.exe - it can not run 8. Run SPT.exe again - it can run and works well More Activations: http://forum.gsmhosting.com/vbb/f296...users-1947911/ http://forum.gsmhosting.com/vbb/f296...users-1983140/ Last edited by YellowBoss; 01-09-2018 at 11:06. Reason: links updated |
The Following 18 Users Say Thank You to InfinitySupport For This Useful Post: |
06-11-2015, 15:52 | #2 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | (BEST)Test Module Active Done :) Thanks Team Activation Logs..... Code: 6/11/2015 7:50:35 PM DongleManager version: 1.56 PC HWID: B6118F72A3Axxxxxx00E8E34 Card-Reader: FT SCR2000 0 Token HWID: 0102xxxxx292 Box/Dongle type: [BEST] Box/Dongle Serial No (S/N): xxxxx Firmware version: 0122.02 "UK edition" status: Off Last launched application: 0000 v.0000 Active modules: - 03: [BEST] v.0122 - 0A: Test Version Online Service Account: http://www.infinity-box.com/service - Username: xxxxxF - Password: xxxxxj Checksum: 87877F Code: Card found: S/N xxxxx Chinese Miracle II [MTK module] v 0.03 Operation : Check / Read Info [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 12 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 8FD9AA58EC0FD622D7734F1E5634939B BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to syed tuqeer For This Useful Post: |
06-11-2015, 16:21 | #3 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Code: ----------Process started: 6/11/2015 8:20:15 PM---------- 6/11/2015 8:20:15 PM DongleManager version: 1.56 PC HWID: 8C7B34BDEDC8CA5F252A158630A461E1 Card-Reader: FT SCR2000 0 Box/Dongle type: [BEST] Locating server... Server address found Connecting to server Server connection successfully established S/N: 63BD8D82, HWID: 01018D8203EF1292, Firmware: 0122.02 Authenticating on server... Authentication stage error: Server reported error:[0007] No more upgrade logs. Dongle is up-to-date and has latest firmware. DO NOT try more ! actvion error |
The Following 3 Users Say Thank You to Tanha0321 For This Useful Post: |
06-11-2015, 16:23 | #4 (permalink) | |
Banned Join Date: Mar 2013 Location: ranipur sindh pakistan
Member: 1905774 Status: Offline Sonork: 100.1646709 Thanks Meter: 972 | Quote:
The Following User Says Thank You to shaikh.mushahid For This Useful Post: |
06-11-2015, 16:29 | #5 (permalink) | |
How to Activate: 1. Login to your Infinity Online Service (IOS) account: Infinity-Box - Online Service 2. Go to "Products" menu 3. Select "Software activations" item 4. Select "Chinese Miracle-2 (Test Version) software activation for Infinity-Box [BEST]" 5. Click to "Buy" button 6. You will see a confirmation and Activation status 7. Follow by given instruction and update your Smart-Card firmware - Smart-Card Update Manual 8. Now you can use new software | |
06-11-2015, 16:29 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | You must read instruction ! How to Activate: 1. Login to your Infinity Online Service (IOS) account: Infinity-Box - Online Service 2. Go to "Products" menu 3. Select "Software activations" item 4. Select "Chinese Miracle-2 (Test Version) software activation for Infinity-Box [BEST]" 5. Click to "Buy" button 6. You will see a confirmation and Activation status 7. Follow by given instruction and update your Smart-Card firmware - Smart-Card Update Manual 8. Now you can use new software |
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
06-11-2015, 16:42 | #7 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
The Following User Says Thank You to pradeep_kus For This Useful Post: |
06-11-2015, 16:43 | #8 (permalink) | |
06-11-2015, 17:00 | #10 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | i acivate software on my best dongle but when update then error comes Code: 0 Info 2015-06-11 15:44:01 0 System Chinese Miracle-2 (Test Version) software activation for Infinity-Box [BEST] 2195xxxx COMPLETED Code: ----------Process started: 6/11/2015 8:59:04 PM---------- 6/11/2015 8:59:04 PM DongleManager version: 1.56 PC HWID: 51BBBC5B009E6A83B710980BFA42060B Card-Reader: FT SCR2000 0 Box/Dongle type: [BEST] Locating server... Server address found Connecting to server Server connection successfully established S/N: 2195xxxx, HWID: 020091851D04xxxx, Firmware: 0118.04 Authenticating on server... Authentication successfull Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Identification check error: Server reported error:[0010] Dongle authentication failed. Retry upgrade. |
The Following User Says Thank You to asad_nomy7 For This Useful Post: |
06-11-2015, 17:19 | #13 (permalink) | |
Download Drivers and read Instruction What is the results ? | |
06-11-2015, 17:21 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | |
