06-12-2015, 08:36 | #47 (permalink) |
No Life Poster Join Date: May 2013 Location: TkinterPy,Hex Cal,Ext2,Ext4,
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Donod d805+ chines phone Read info,Read user code,Rebuiled imei done. Note.Rda cpu inside the phone. info. Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4009 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1700 FL_CNM : GigaDevice , GD25Q64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Set : 8809 , 00800000 Use : 8809_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Elapsed: 00:00:04 Done Reconnect Power/Cable! Read user lock. Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4009 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1700 FL_CNM : GigaDevice , GD25Q64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Set : 8809 , 00800000 Use : 8809_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read UDA now , wait ... Read done, sorting EXTData Following items found : Item : VDS0 Item : NVRAM Required data found, extracting code UserCode : 1234 Elapsed: 00:01:42 Done Reconnect Power/Cable! Rebuiled imei. Operation : Factory Area Rebuild [Repair IMEI] Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4009 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1700 FL_CNM : GigaDevice , GD25Q64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Set : 8809 , 00800000 Use : 8809_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Factory Sector ... Read Ok , verify Detected 2 Sim Slot(s) Current Phone IMEI : IMEI1 : 35xxxxxxxxxxx0 IMEI2 : 35xxxxxxxxxxx1 New Phone IMEI : IMEI1 : 35xxxxxxxxxxxx-5 IMEI2 : 35xxxxxxxxxxxx-4 Build Factory Sector Write Factory Sector CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Verify Factory Sector Sector Verifyed! IMEI Write Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to ij_cell For This Useful Post: |
06-12-2015, 09:39 | #53 (permalink) |
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | change your Browser.some time Chrome not work nicely.use mozila or something else.check may be your browser activated ADB BLOCK.disable first restart browser.post result |
06-12-2015, 09:49 | #54 (permalink) | |
Explain what are you doing step-by-step ! upd: uf... it looks like you never read any text. you must start to do that now ! look at text marked in red color. you must update your password and set password recovery e-mail before you go to products. | |
06-12-2015, 09:53 | #55 (permalink) |
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | AG whutz zappa china phone dead phone alive by flashing. Note.this phone is have Mtk mt6260 spu inside. Write flash. Load File File_Info : ZECHIN60A_11B_PCB01_gprs_MT6260_S00.AG_S236_V01.bi n FileVersion : AG_S236_V01 Load File Ok Operation : Flash [ v0.03 ] ======= Flash Files set for flashing : [ MCU ] : ag whutz zappa.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 191 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : DB72E035626DAD27792152298BD2116B BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00000000 , 0x00000000 Erase region , wait ... Write data , wait ... Write : ag whutz zappa.bin Done! Elapsed: 00:02:02 Reconnect Power/Cable! |
The Following User Says Thank You to ij_cell For This Useful Post: |
06-12-2015, 10:01 | #56 (permalink) | |
No Life Poster Join Date: Jan 2011 Location: Erth Age: 40
Member: 1497980 Status: Offline Thanks Meter: 1,266 | Quote:
bro i m using mozila fire fox chrome browser | |
06-12-2015, 10:14 | #57 (permalink) | |
Any results now, my Smart Friend ? | |
06-12-2015, 16:42 | #59 (permalink) |
Major Poster Join Date: Apr 2012
Member: 1751046 Status: Offline Thanks Meter: 13 | Info Code: Chinese Miracle II [MTK module] v 0.03 Operation : Check / Read Info [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 50 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 6327B1C1094468D18251567A8C912E66 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 0000 0000 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x002FE000 , 0x00002000 Done! Elapsed: 00:00:09 Reconnect Power/Cable! Code: Operation : Reset UserCode [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 50 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 6327B1C1094468D18251567A8C912E66 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x002FE000 , 0x00002000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:08 Reconnect Power/Cable! Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x002FE000 , 0x00002000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Read Flash [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Device boot not done Check Drivers Try again Boot Error! Elapsed: 00:00:40 Reconnect Power/Cable! Code: Operation : Read Flash [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 50 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 6327B1C1094468D18251567A8C912E66 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x002FE000 , 0x00002000 Read Flash now Read Ok , 3145728 bytes read Check and collect compile info File_Info : FARSIGHTED60M_11B_PCB01_gsm_MT6260_S00.V1516_00-V10A-IND-V06.bin FileVersion : V1516_00-V10a-IND-V06 Saved to : C:\InfinityBox\CM2MTK\Read_out\FARSIGHTED60M_11B_PCB01_gsm_MT6260_S00.V1516_00-V10A-IND-V06.bin Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to gsm-lab2 For This Useful Post: |
