02-06-2017, 19:23 | #1 (permalink) |
Freak Poster Join Date: Apr 2009
Member: 1019191 Status: Offline Thanks Meter: 12 | Connection faled: Socket Error # 10060 Connection timed out. firewall disable but also failed http://forum.gsmhosting.com/vbb/f641...060-a-2020476/ ALL ABOOVE SOLUTIONS FAILED Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok SD Authentification : not done Local SX4 Card Not Found, wil use Server Started Connecting to SX4 server... Connected SX4 enter .. SDAuth Ok! SX4 Disconnected SX4 Done! Done! WP8 Unlock Started Connecting to server... Connection faled: Socket Error # 10060 Connection timed out. Disconnected Error! Check previous error message for more info! Phone disconected! Connect phone on selected interface... |
02-09-2017, 16:42 | #4 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Offline Thanks Meter: 226 | SX4 server not work For hours. Or else you have this problem ? WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connection faled: Socket Error # 10060 Connection timed out. SX4 Disconnected SX4 Failed, will retry Auth again ... Started Connecting to SX4 server... Connection faled: Socket Error # 10060 Connection timed out. SX4 Disconnected SDAuth not done! Try make SX4 after 1-2 minute and make "Unlock" again! Error! Check previous error message for more info! |
02-11-2017, 15:52 | #7 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
- Close [BEST] software - Download latest Configurator software - http://www.infinity-box.com/support/...onfigurator.7z - Start Configurator to update config - Start BEST again | |
06-01-2019, 12:38 | #8 (permalink) |
Freak Poster Join Date: Aug 2013 Location: in ur mind
Member: 2014880 Status: Offline Sonork: 100.1673441 Thanks Meter: 26 | am still getting erro unlocking nokia 625. is best server down? Card found: S/N : DCAE755C , v0134 Registered to: julius Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok WP8 Unlock Started Connecting to server... Connection faled: Socket Error # 10060 Connection timed out. Disconnected Error! Check previous error message for more info! SD Authentification : not done Local SX4 Card Not Found, wil use Server Started Connecting to SX4 server... Connection faled: Socket Error # 10060 Connection timed out. SX4 Disconnected Error while operation, check previous message for more info |
06-11-2019, 10:15 | #10 (permalink) |
Product Supporter Join Date: Mar 2005 Age: 44
Member: 128745 Status: Offline Thanks Meter: 16,936 | Lumia unlock service is no more working. You can use your credits for hundreds of products on Infinity Online services |
The Following 2 Users Say Thank You to Infinity-Box For This Useful Post: |
07-30-2019, 11:42 | #11 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2045602 Status: Offline Sonork: [email protected] Thanks Meter: 0 | XGold unlock flow started Connecting to server... Connection faled: Socket Error # 10060 Connection timed out. Disconnected |
