Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2006
Member: 218667 Status: Offline Thanks: 28
| Dead C7-00 before flash rm-675 First version I downgrade and a dead phone result Delete the certificate but without saving simlock.Result simlock incorrect imei 1234 I bought the rpl but when you delete the certificates (including ape) no connect local mode ,test mode , or connect to USB. Start, Nokia appears black background (firmware 111) blinks and restarts. .El fbus cable C7-00 need to disarm the c7? Thanks in advance |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2009 Location: Russia , Syberia Age: 23
Member: 1157320 Status: Offline Sonork: 100.1616907 Thanks: 4,100
| Hello. Erase flash. Write firmware. Phone should work. Write RPL, make rest repair operations. |
| | #6 (permalink) |
| Moderator ![]() Join Date: Dec 2006 Location: Pakistan " Karachi " and Dubai
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks: 208
| Hello If not Hardware , Sure its 100% connect on USB Open BEST Go in Repair Tab Tick Skip backup check Press Erase phone , now Connect Usb cable thwn attach battery if not Connect try more Time will be Connect and erase phone |
| | #7 (permalink) |
| No work Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- -> Phone not found.. ![]() Looks like HW failure / Cable / Battery problem Supported : RapuYama, RAP3Gv4, BroadComm, RAPIDO User break FULL Erase User ACCEPTED FULL ERASE Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- -> Phone not found.. ![]() Looks like HW failure / Cable / Battery problem Supported : RapuYama, RAP3Gv4, BroadComm, RAPIDO |
| | #8 (permalink) |
| Sure, cos you looks like, not understand - need reinsert battery (charge it before in another phone) and insert cable in phone. |
| | #10 (permalink) |
| Hello Use Fully charge Battery , and USB direct attach in PC IF not HELP ,sure its hardware now digg in hardware |
| | #11 (permalink) |
| Not work .I buy fbus cable but not work with UFS Done! Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! SuperDongle Key found! CMLA key found! WMDRM key found! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000030000022600010007600C192102031104 CMT EM0 ID : 00001040 CMT EM1 ID : 00001030 CMT PUB ID : 2840010BE4A80344E210BAE9D8C96B31EC780F2A CMT MODE ID : 00 CMT R_HASH : 916F75217F32081248B15C38DFC8E81B CMT ROM ID : E693EF0DAC22615B UFSx doesn't support New Protocol ![]() - > Use USB cable for this phone ;D Boot failed! ![]() If phone RAPUYAMA, RAP3Gv4, RAPIDO or BroadComm - Use USB cable ![]() Done! Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! SuperDongle Key found! CMLA key found! WMDRM key found! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000030000022600010007600C192102031104 CMT EM0 ID : 00001040 CMT EM1 ID : 00001030 CMT PUB ID : 2840010BE4A80344E210BAE9D8C96B31EC780F2A CMT MODE ID : 00 CMT R_HASH : 916F75217F32081248B15C38DFC8E81B CMT ROM ID : E693EF0DAC22615B UFSx doesn't support New Protocol ![]() - > Use USB cable for this phone ;D Boot failed! ![]() If phone RAPUYAMA, RAP3Gv4, RAPIDO or BroadComm - Use USB cable ![]() Done! Not work with usb,not work with fbus .Rehot ic flash work for local or test mode ?ŋ Thanks |
| | #13 (permalink) |
| Hello its very difficult to understand a, If phone not able connect with USB then , how u Repair phone with SW ? U able repair when phone will connect on USB and u perform operations if its not able connect sure problem in Ur phone ,battery, cable or PC Now plzz think about it and proceed work |
| | #14 (permalink) |
| Yes but phone is working before erase flash believe or not.Now without ape is imposible to conect usb.Not battery ,not cable , not computer.I open and connect fbus cable but ufsx not work with this. |
| | #15 (permalink) |
| Phone can't dead after erase. Remove battery Insert back Insert usb cable if PC not react to it by connect device sound - meat something wrong. Check battery, cable, port. Suppose it is battery. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| FLASH BOX WANTED!!!!!! | J | Wanted Products | 9 | 07-14-2012 20:42 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
| Nokia Flash Content. | Phantom | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 05-01-2000 23:28 |
| need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 08-16-1999 12:20 |
| 5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 07-07-1999 12:27 |
