05-08-2012, 11:37 | #1 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Poland, Wroclaw Age: 50
Member: 67562 Status: Offline Sonork: none Thanks Meter: 89 | Downgrade problem 6700c Phone now is semi dead. What i did wrong? Can not paste full log Code: Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 6700 classic Software ver : V 13.21 12-01-11 RM-470 (c) Nokia IMEI : 352696043985596 DSP Ver : ICPR81_10w09 PPM : V 13.21 12-01-11 RM-470 (c) Nokia C CNT : Content: eplus DE v2 V 13.21 12-01-11 RM-470 (c) Nokia Product SN : KMK701813 Product code : 0587868 Base Prd.code: 0590482 Module code : 0203926 Long Prod.SN : 0 Hardware info======= HWID : 1009 Retu : 34 Tahvo : 00 Batery: 4084 mV CMT BT: 410B-v190 LCDVer: TPO Lock info =========== IMEI : 352696043985596 IMEI spNet : 3A 25 96 06 34 89 55 09 IMEI svNet : 33 25 96 06 34 89 55 49 F9 Conf key : 8000000000000002 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... Reboot.... Connection opened successfully Waiting for communication response... BootRom : Verify Error :( Try again... -> Error answer from BootRom Looks like ASIC not supported, or HW failure Supported : RapuYama, RAP3Gv4, BroadComm, RAPIDO If RAPIDO - use dead mode for read rpl/force local SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\352696043985596_SIM.rpl Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Read Uniq key data started... - > Power Off phone, dissconnect it Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB PUBLIC ID: 1BD00202DF7A0344FBFECB3D128DC89DF898C3F3 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 Fetching data, wait... - > Reinsert cable and battery, press powerOn button again - > For X7, E7 - just waiting, near 1 minute - > When BEST start Search Phone - Press PowerOn if needed Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 1BD00202DF7A0344FBFECB3D128DC89DF898C3F3 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.2.0 Processing RAWLOADER... FLIC : 00400098 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.2.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6 ADL: Close_Session Content: 000300000000060000000600000000 ADL: Reboot Wait, reconneting... rap= 1BD00202DF7A0344FBFECB3D128DC89DF898C3F3 hash= 25B977A055BE9B5DEC0C38A2A279C695 key= 8C7634B02A3D9F4F1A399BC4CF0B6883FD136E43 Key file updated... Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Try Read Camera Configuration to base... Camera HW : ISL2TI020000093E2F30 Camera configuration exist, skip saving... Cam 2 configuration not found Done! Reading Values... Bat. voltage: 4047 mV Currency: 171 mA Temp: 25 C Done! Core : v1.44 , FlashEngine : v1.35 Selected FlashSettings : Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm470__13.10.mcusw PPM : rm470__13.10.ppm_b CNT : rm470__13.10_ISM_018.image_b_pl_chrome Flashing phone now... Check files done... -> Check SW version... FlashFile version : 13.10 Phone version : 13.21 12-01-11 RM-470 (c) Nokia -> Check SW version : Downgrade try Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... -> Downgrade attempt detected -> Downgrade aborted by user -> Break flashing procedure... Operating mode is OK, no need change... Reading PM from field 0 to 400 Field [1] 29 Record(s) Record 0: 114 byte(s) readed - Ok Record 2: 10 byte(s) readed - Ok Record 4: 110 byte(s) readed - Ok Record 6: 10 byte(s) readed - Ok Record 7: 214 byte(s) readed - Ok Record 8: 110 byte(s) readed - Ok Record 13: 10 byte(s) readed - Ok Record 16: 208 byte(s) readed - Ok Record 18: 208 byte(s) readed - Ok Record 20: 208 byte(s) readed - Ok Record 22: 16 byte(s) readed - Ok Record 23: 4 byte(s) readed - Ok Record 24: 84 byte(s) readed - Ok Record 26: 110 byte(s) readed - Ok Record 28: 10 byte(s) readed - Ok Record 29: 10 byte(s) readed - Ok Record 31: 208 byte(s) readed - Ok Record 33: 36 byte(s) readed - Ok Record 34: 376 byte(s) readed - Ok Record 35: 16 byte(s) readed - Ok Record 37: 4 byte(s) readed - Ok Record 39: 36 byte(s) readed - Ok Record 40: 16 byte(s) readed - Ok Record 41: 182 byte(s) readed - Ok Record 42: 4 byte(s) readed - Ok Record 43: 36 byte(s) readed - Ok Record 44: 182 byte(s) readed - Ok Record 45: 182 byte(s) readed - Ok Record 46: 64 byte(s) readed - Ok Field [2] 1 Record(s) Record 0: 2072 byte(s) readed - Ok Field [4] 9 Record(s) Record 1: 800 byte(s) readed - Ok Record 3: 10 byte(s) readed - Ok Record 4: 8 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 9: 5 byte(s) readed - Ok Record 18: 80 byte(s) readed - Ok Record 19: 4 byte(s) readed - Ok Record 28: 2 byte(s) readed - Ok Field [6] 1 Record(s) Record 0: 32 byte(s) readed - Ok Field [8] 12 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 16 byte(s) readed - Ok Record 2: 16 byte(s) readed - Ok Record 3: 128 byte(s) readed - Ok Record 4: 128 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 7: 4 byte(s) readed - Ok Record 8: 8 byte(s) readed - Ok Record 9: 8 byte(s) readed - Ok Record 10: 32 byte(s) readed - Ok Record 11: 4 byte(s) readed - Ok Record 12: 4 byte(s) readed - Ok Field [11] 70 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Record 2: 4 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 5: 6 byte(s) readed - Ok Record 6: 2 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 8: 1 byte(s) readed - Ok Record 9: 1 byte(s) readed - Ok Record 10: 2 byte(s) readed - Ok Record 11: 2 byte(s) readed - Ok Record 12: 2 byte(s) readed - Ok Record 13: 2 byte(s) readed - Ok Record 14: 16 byte(s) readed - Ok Record 15: 32 byte(s) readed - Ok Record 16: 32 byte(s) readed - Ok Record 17: 2 byte(s) readed - Ok Record 18: 2 byte(s) readed - Ok Record 19: 2 byte(s) readed - Ok Record 20: 2 byte(s) readed - Ok Record 21: 2 byte(s) readed - Ok Record 22: 2 byte(s) readed - Ok Record 23: 2 byte(s) readed - Ok Record 24: 2 byte(s) readed - Ok Record 25: 2 byte(s) readed - Ok Record 26: 2 byte(s) readed - Ok Record 27: 2 byte(s) readed - Ok Record 28: 2 byte(s) readed - Ok Record 29: 2 byte(s) readed - Ok Record 30: 2 byte(s) readed - Ok Record 31: 2 byte(s) readed - Ok Record 32: 2 byte(s) readed - Ok Record 33: 2 byte(s) readed - Ok Record 34: 2 byte(s) readed - Ok Record 35: 2 byte(s) readed - Ok Record 36: 2 byte(s) readed - Ok Record 37: 2 byte(s) readed - Ok Record 38: 2 byte(s) readed - Ok Record 39: 2 byte(s) readed - Ok Record 40: 2 byte(s) readed - Ok Record 41: 2 byte(s) readed - Ok Record 42: 2 byte(s) readed - Ok Record 43: 2 byte(s) readed - Ok Record 44: 2 byte(s) readed - Ok Record 45: 2 byte(s) readed - Ok Record 46: 2 byte(s) readed - Ok Record 47: 2 byte(s) readed - Ok Record 48: 2 byte(s) readed - Ok Record 49: 2 byte(s) readed - Ok Record 50: 2 byte(s) readed - Ok Record 51: 2 byte(s) readed - Ok Record 52: 2 byte(s) readed - Ok Record 53: 2 byte(s) readed - Ok Record 54: 2 byte(s) readed - Ok Record 55: 2 byte(s) readed - Ok Record 56: 2 byte(s) readed - Ok Record 57: 2 byte(s) readed - Ok Record 58: 2 byte(s) readed - Ok Record 59: 2 byte(s) readed - Ok Record 60: 2 byte(s) readed - Ok Record 61: 2 byte(s) readed - Ok Record 62: 4 byte(s) readed - Ok Record 63: 4 byte(s) readed - Ok Record 64: 4 byte(s) readed - Ok Record 65: 4 byte(s) readed - Ok Record 66: 16 byte(s) readed - Ok Record 67: 4 byte(s) readed - Ok Record 68: 2 byte(s) readed - Ok Record 69: 242 byte(s) readed - Ok Field [12] 1 Record(s) Record 0: 102 byte(s) readed - Ok Field [13] 167 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 1 byte(s) readed - Ok Record 3: 2 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 5: 1 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 8: 2 byte(s) readed - Ok Record 9: 1 byte(s) readed - Ok Record 10: 1 byte(s) readed - Ok Record 11: 48 byte(s) readed - Ok Record 12: 4 byte(s) readed - Ok Record 13: 1 byte(s) readed - Ok Record 14: 1 byte(s) readed - Ok Record 15: 886 byte(s) readed - Ok Record 16: 2 byte(s) readed - Ok Record 17: 1 byte(s) readed - Ok Record 18: 1 byte(s) readed - Ok Record 19: 8 byte(s) readed - Ok Record 20: 1 byte(s) readed - Ok Record 21: 1 byte(s) readed - Ok Record 22: 1 byte(s) readed - Ok Record 23: 1 byte(s) readed - Ok Record 24: 1 byte(s) readed - Ok Record 25: 2 byte(s) readed - Ok Record 26: 1 byte(s) readed - Ok Record 27: 1 byte(s) readed - Ok Record 28: 1 byte(s) readed - Ok Record 29: 1 byte(s) readed - Ok Record 30: 1 byte(s) readed - Ok Record 31: 1 byte(s) readed - Ok Record 32: 1 byte(s) readed - Ok Record 33: 1 byte(s) readed - Ok Record 34: 1 byte(s) readed - Ok Record 35: 1 byte(s) readed - Ok Record 36: 1 byte(s) readed - Ok Record 37: 4 byte(s) readed - Ok Record 38: 1 byte(s) readed - Ok Record 39: 1 byte(s) readed - Ok Record 40: 1 byte(s) readed - Ok Record 41: 1 byte(s) readed - Ok Record 42: 4 byte(s) readed - Ok Record 43: 4 byte(s) readed - Ok Record 44: 1 byte(s) readed - Ok Record 45: 4 byte(s) readed - Ok Record 46: 4 byte(s) readed - Ok Record 47: 1 byte(s) readed - Ok Record 48: 4 byte(s) readed - Ok Record 49: 1 byte(s) readed - Ok Record 50: 1 byte(s) readed - Ok Record 51: 1 byte(s) readed - Ok Record 52: 2 byte(s) readed - Ok Record 53: 4 byte(s) readed - Ok Record 54: 4 byte(s) readed - Ok Record 55: 1 byte(s) readed - Ok Record 56: 1 byte(s) readed - Ok Record 57: 1 byte(s) readed - Ok Record 58: 2 byte(s) readed - Ok Record 59: 1 byte(s) readed - Ok Record 60: 4 byte(s) readed - Ok Record 61: 4 byte(s) readed - Ok Record 62: 1 byte(s) readed - Ok Record 63: 4 byte(s) readed - Ok Record 64: 4 byte(s) readed - Ok Record 65: 1 byte(s) readed - Ok Record 66: 4 byte(s) readed - Ok Record 67: 4 byte(s) readed - Ok Record 68: 1 byte(s) readed - Ok Record 69: 1 byte(s) readed - Ok Record 70: 1 byte(s) readed - Ok Record 71: 4 byte(s) readed - Ok Record 72: 4 byte(s) readed - Ok Record 73: 1 byte(s) readed - Ok Record 74: 4 byte(s) readed - Ok Record 75: 2 byte(s) readed - Ok Record 76: 2 byte(s) readed - Ok Record 77: 2 byte(s) readed - Ok Record 78: 1 byte(s) readed - Ok Record 79: 1 byte(s) readed - Ok Record 80: 1 byte(s) readed - Ok Record 81: 1 byte(s) readed - Ok Record 82: 1 byte(s) readed - Ok Record 83: 2 byte(s) readed - Ok Record 84: 1 byte(s) readed - Ok Record 85: 4 byte(s) readed - Ok Record 86: 4 byte(s) readed - Ok Record 87: 2 byte(s) readed - Ok Record 88: 1 byte(s) readed - Ok Record 89: 4 byte(s) readed - Ok Record 90: 4 byte(s) readed - Ok Record 91: 2 byte(s) readed - Ok Record 92: 1 byte(s) readed - Ok Record 93: 4 byte(s) readed - Ok Record 94: 4 byte(s) readed - Ok Record 95: 2 byte(s) readed - Ok Record 96: 1 byte(s) readed - Ok Record 97: 4 byte(s) readed - Ok Record 98: 4 byte(s) readed - Ok Record 99: 2 byte(s) readed - Ok Record 100: 4 byte(s) readed - Ok Record 101: 2 byte(s) readed - Ok Record 102: 1 byte(s) readed - Ok Record 103: 4 byte(s) readed - Ok Record 104: 4 byte(s) readed - Ok Record 105: 4 byte(s) readed - Ok Record 106: 4 byte(s) readed - Ok Record 107: 4 byte(s) readed - Ok Record 108: 2 byte(s) readed - Ok Record 109: 4 byte(s) readed - Ok Record 110: 4 byte(s) readed - Ok Record 111: 4 byte(s) readed - Ok Record 112: 2 byte(s) readed - Ok Record 113: 4 byte(s) readed - Ok Record 114: 4 byte(s) readed - Ok Record 115: 1 byte(s) readed - Ok Record 116: 1 byte(s) readed - Ok Record 117: 1 byte(s) readed - Ok Record 118: 4 byte(s) readed - Ok Record 119: 4 byte(s) readed - Ok Record 120: 1 byte(s) readed - Ok Record 121: 1 byte(s) readed - Ok Record 122: 1 byte(s) readed - Ok Record 123: 8 byte(s) readed - Ok Record 124: 1 byte(s) readed - Ok Record 125: 1 byte(s) readed - Ok Record 126: 1 byte(s) readed - Ok Record 127: 1 byte(s) readed - Ok Record 128: 1 byte(s) readed - Ok Record 129: 4 byte(s) readed - Ok Record 130: 4 byte(s) readed - Ok Record 131: 1 byte(s) readed - Ok Record 132: 1 byte(s) readed - Ok Record 133: 2 byte(s) readed - Ok Record 134: 1 byte(s) readed - Ok Record 135: 2 byte(s) readed - Ok Record 136: 1 byte(s) readed - Ok Record 137: 1 byte(s) readed - Ok Record 138: 4 byte(s) readed - Ok Record 139: 4 byte(s) readed - Ok Record 140: 1 byte(s) readed - Ok Record 141: 1 byte(s) readed - Ok Record 142: 1 byte(s) readed - Ok Record 143: 1 byte(s) readed - Ok Record 144: 4 byte(s) readed - Ok Record 145: 8 byte(s) readed - Ok Record 146: 4 byte(s) readed - Ok Record 147: 4 byte(s) readed - Ok Record 148: 1 byte(s) readed - Ok Record 149: 1 byte(s) readed - Ok Record 150: 1 byte(s) readed - Ok Record 151: 1 byte(s) readed - Ok Record 152: 1 byte(s) readed - Ok Record 153: 1 byte(s) readed - Ok Record 154: 1 byte(s) readed - Ok Record 155: 1 byte(s) readed - Ok Record 156: 1 byte(s) readed - Ok Record 157: 1 byte(s) readed - Ok Record 158: 1 byte(s) readed - Ok Record 159: 2 byte(s) readed - Ok Record 160: 2 byte(s) readed - Ok Record 161: 1 byte(s) readed - Ok Record 162: 1 byte(s) readed - Ok Record 163: 1 byte(s) readed - Ok Record 164: 1 byte(s) readed - Ok Record 165: 1 byte(s) readed - Ok Record 166: 1 byte(s) readed - Ok Field [26] 2 Record(s) Record 0: 16 byte(s) readed - Ok Record 1: 68 byte(s) readed - Ok Field [31] 1 Record(s) Record 4: 14 byte(s) readed - Ok Field [42] 27 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Record 17: 40 byte(s) readed - Ok Record 18: 40 byte(s) readed - Ok Record 19: 40 byte(s) readed - Ok Record 20: 40 byte(s) readed - Ok Record 21: 40 byte(s) readed - Ok Record 22: 40 byte(s) readed - Ok Record 23: 40 byte(s) readed - Ok Record 24: 40 byte(s) readed - Ok Record 25: 40 byte(s) readed - Ok Record 26: 40 byte(s) readed - Ok Field [44] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [50] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [54] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 2: 24 byte(s) readed - Ok Field [88] 1 Record(s) Record 0: 36 byte(s) readed - Ok Field [96] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 20 byte(s) readed - Ok Field [107] 7 Record(s) Record 0: 21 byte(s) readed - Ok Record 1: 89 byte(s) readed - Ok Record 2: 69 byte(s) readed - Ok Record 3: 70 byte(s) readed - Ok Record 24: 88 byte(s) readed - Ok Record 25: 136 byte(s) readed - Ok Record 26: 12 byte(s) readed - Ok Field [116] 17 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [117] 11 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 3 byte(s) readed - Ok Record 2: 6 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 9 byte(s) readed - Ok Record 5: 10 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 8: 44 byte(s) readed - Ok Record 13: 3 byte(s) readed - Ok Record 14: 3 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [120] 4 Record(s) Record 0: 944 byte(s) readed - Ok Record 1: 160 byte(s) readed - Ok Record 2: 130 byte(s) readed - Ok Record 3: 112 byte(s) readed - Ok Field [153] 6 Record(s) Record 0: 68 byte(s) readed - Ok Record 1: 68 byte(s) readed - Ok Record 2: 68 byte(s) readed - Ok Record 3: 68 byte(s) readed - Ok Record 4: 68 byte(s) readed - Ok Record 5: 68 byte(s) readed - Ok Field [163] 1 Record(s) Record 0: 8 byte(s) readed - Ok Field [193] 4 Record(s) Record 2: 8 byte(s) readed - Ok Record 3: 32 byte(s) readed - Ok Record 4: 32 byte(s) readed - Ok Record 9: 64 byte(s) readed - Ok Field [217] 1 Record(s) Record 0: 32 byte(s) readed - Ok Field [218] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [232] 3 Record(s) Record 0: 20 byte(s) readed - Ok Record 2: 1 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Field [238] 1 Record(s) Record 1: 1 byte(s) readed - Ok Field [239] 3 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 3176 byte(s) readed - Ok Record 2: 3176 byte(s) readed - Ok Field [250] 4 Record(s) Record 1: 2416 byte(s) readed - Ok Record 2: 128 byte(s) readed - Ok Record 3: 804 byte(s) readed - Ok Record 4: 40 byte(s) readed - Ok Field [291] 1 Record(s) Record 0: 92 byte(s) readed - Ok Field [301] 17 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [308] 9 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 8192 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 5: 10 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 8: 1 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Field [309] 8 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 12 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 12 byte(s) readed - Ok Record 5: 12 byte(s) readed - Ok Record 7: 12 byte(s) readed - Ok Record 17: 12 byte(s) readed - Ok Field [319] 8 Record(s) Record 0: 148 byte(s) readed - Ok Record 1: 148 byte(s) readed - Ok Record 2: 148 byte(s) readed - Ok Record 3: 148 byte(s) readed - Ok Record 4: 148 byte(s) readed - Ok Record 5: 148 byte(s) readed - Ok Record 6: 148 byte(s) readed - Ok Record 7: 148 byte(s) readed - Ok Field [320] 39 Record(s) Record 0: 148 byte(s) readed - Ok Record 1: 148 byte(s) readed - Ok Record 2: 148 byte(s) readed - Ok Record 3: 148 byte(s) readed - Ok Record 4: 148 byte(s) readed - Ok Record 5: 148 byte(s) readed - Ok Record 6: 148 byte(s) readed - Ok Record 7: 148 byte(s) readed - Ok Record 8: 148 byte(s) readed - Ok Record 9: 148 byte(s) readed - Ok Record 10: 148 byte(s) readed - Ok Record 11: 148 byte(s) readed - Ok Record 12: 148 byte(s) readed - Ok Record 13: 148 byte(s) readed - Ok Record 14: 148 byte(s) readed - Ok Record 15: 148 byte(s) readed - Ok Record 16: 148 byte(s) readed - Ok Record 17: 148 byte(s) readed - Ok Record 18: 148 byte(s) readed - Ok Record 19: 148 byte(s) readed - Ok Record 20: 148 byte(s) readed - Ok Record 21: 148 byte(s) readed - Ok Record 22: 148 byte(s) readed - Ok Record 23: 148 byte(s) readed - Ok Record 24: 148 byte(s) readed - Ok Record 25: 148 byte(s) readed - Ok Record 26: 148 byte(s) readed - Ok Record 27: 148 byte(s) readed - Ok Record 28: 148 byte(s) readed - Ok Record 29: 148 byte(s) readed - Ok Record 30: 148 byte(s) readed - Ok Record 31: 148 byte(s) readed - Ok Record 32: 148 byte(s) readed - Ok Record 33: 148 byte(s) readed - Ok Record 34: 148 byte(s) readed - Ok Record 35: 148 byte(s) readed - Ok Record 36: 148 byte(s) readed - Ok Record 37: 148 byte(s) readed - Ok Record 38: 148 byte(s) readed - Ok Field [322] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [329] 1 Record(s) Record 0: 8392 byte(s) readed - Ok Field [334] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [339] 2 Record(s) Record 0: 511 byte(s) readed - Ok Record 1: 511 byte(s) readed - Ok Field [341] 3 Record(s) Record 0: 1 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 4392 byte(s) readed - Ok Field [354] 1 Record(s) Record 0: 3 byte(s) readed - Ok Field [355] 1 Record(s) Record 0: 11514 byte(s) readed - Ok Field [356] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 8 byte(s) readed - Ok Field [362] 2 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 120 byte(s) readed - Ok Field [364] 27 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Record 17: 40 byte(s) readed - Ok Record 18: 40 byte(s) readed - Ok Record 19: 40 byte(s) readed - Ok Record 20: 40 byte(s) readed - Ok Record 21: 40 byte(s) readed - Ok Record 22: 40 byte(s) readed - Ok Record 23: 40 byte(s) readed - Ok Record 24: 40 byte(s) readed - Ok Record 25: 40 byte(s) readed - Ok Record 26: 40 byte(s) readed - Ok Field [365] 17 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [369] 1 Record(s) Record 0: 40 byte(s) readed - Ok Saved as C:\InfinityBox\BEST\Backup\6700\RM-470 Nokia 6700 classic_352696043985596_0_400.pm Done! Elapsed: 00:00:04 Code: Operating mode is OK, no need change... Reading Product Profile sets... 0 - 127 1 - 1 4 - 0 7 - 1 9 - 0 34 - 0 35 - 0 41 - 1 48 - 1 56 - 0 58 - 0 61 - 0 65 - 0 66 - 0 69 - 1 70 - 1 71 - 1 73 - 2 78 - 0 79 - 1 100 - 1 130 - 5 131 - 7 135 - 0 138 - 0 139 - 1 141 - 1 143 - 1 145 - 0 146 - 0 147 - 0 156 - 0 157 - 1 158 - 1 164 - 1 165 - 0 166 - 0 168 - 0 177 - 0 183 - 0 184 - 2 185 - 0 192 - 0 193 - 0 202 - 3 205 - 0 206 - 0 211 - 0 212 - 0 214 - 0 217 - 0 219 - 1 220 - 0 228 - 0 SETS 1 Readed 54 element(s) Saved as C:\InfinityBox\BEST\Backup\6700\RM-470 Nokia 6700 classic_352696043985596.pp Done! Elapsed: 00:00:00 Reading LifeTimer data... LifeTime is: 235700 seconds Phone works: 65 Hours; 28 minutes; 20 seconds Done Reading Product code... Product code : 0587868 Done! Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok User ACCEPTED FULL ERASE Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 1BD00202DF7A0344FBFECB3D128DC89DF898C3F3 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.2.0 Processing RAWLOADER... FLIC : 00400098 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.2.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6 Reading NPC certificate... IMEI : 352696043985596 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\352696043985596_CRT.rpl ADL: Preparing for erase... Full Erase started... Asic : CMT , Sub : NAND Erase Area 0x00000000-0x0FFFFFFF Erasing Ok , [0F] Erase done , time : 00:00:04 ADL: Erase done ADL: Close_Session Content: 000205000000000000FFFF00000000 ADL: Reboot Phone disconected! Connect phone on selected interface... Core : v1.44 , FlashEngine : v1.35 Selected FlashSettings : Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm470__13.10.mcusw PPM : rm470__13.10.ppm_b CNT : rm470__13.10_ISM_018.image_b_pl_chrome Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 1BD00202DF7A0344FBFECB3D128DC89DF898C3F3 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.2.0 Processing RAWLOADER... FLIC : 00400098 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.2.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : blank (Erased or HW failure) ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... - > No any CRT data (MCU damaged/CERT erased), skip saving ===Flashing [MCU]=== Erase : Processing rm470__13.10.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:05 Write : Processing rm470__13.10.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 218 blocks TIME : Write time : 00:00:09 MCU Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ===Flashing [PPM]=== Erase : Processing rm470__13.10.ppm_b Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm470__13.10.ppm_b Total writen 47 blocks TIME : Write time : 00:00:02 PPM Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ===Flashing [CNT]=== Erase : Processing rm470__13.10_ISM_018.image_b_pl_chrome Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:07 Write : Processing rm470__13.10_ISM_018.image_b_pl_chrome Total writen 205 blocks TIME : Write time : 00:00:09 CNT Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ADL: Close_Session Content: 000300000000060000000600000000 ADL: Reboot Flashing done! Total flash time : 00:00:34 Reboot phone now... Will Write CCC/HWC keys now... No any file selected, break operation Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 1BD00202DF7A0344FBFECB3D128DC89DF898C3F3 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.2.0 Processing RAWLOADER... FLIC : 00400098 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.2.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Seek file for this phone.... ----------------------------- - > RPL file found for this phone! - > NPC Found in : 352696043985596_CRT.rpl Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) ----------------------------- Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : blank (Erased or HW failure) ADL: Preparing for write certificates... ADL: Writing Flash certs done! :) ADL: Close_Session Content: 00060E4E5043000000000000000000 ADL: Reboot -> No any Flex keys selected or found, skip flex part Connect phone on selected interface... Done! Connect phone on selected interface... Will Write RPL keys now... Check RPL file... SimLock Data found! SimLock key found! WMDRM key found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 1BD00202DF7A0344FBFECB3D128DC89DF898C3F3 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.2.0 Processing RAWLOADER... FLIC : 00400098 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.2.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : blank (Erased or HW failure) ADL: Preparing for write certificates... ADL: Writing Flash certs done! :) ADL: Close_Session Content: 000300000000060000000600000000 ADL: Reboot Wait, reconneting... Phone not found... :( CertWrite failed : phone was not bootup Connection/SW/HW problem, try bootup manually If phone bootup Ok - write only flex keys Phone disconected! Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 1BD00202DF7A0344FBFECB3D128DC89DF898C3F3 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.2.0 Processing RAWLOADER... FLIC : 00400098 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.2.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : blank (Erased or HW failure) ADL: Preparing for write certificates... ADL: Writing Flash certs done! :) ADL: Close_Session Content: 00060E4E5043000000000000000000 ADL: Reboot -> No any Flex keys selected, skip flex part Done! Phone disconected! Connect phone on selected interface... - > AfterFlash Failed! :( Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Elapsed: 00:01:01 Connect phone on selected interface... Will Write RPL keys now... Check RPL file... SimLock Data found! SimLock key found! WMDRM key found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 1BD00202DF7A0344FBFECB3D128DC89DF898C3F3 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.2.0 Processing RAWLOADER... FLIC : 00400098 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.2.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : blank (Erased or HW failure) ADL: Preparing for write certificates... ADL: Writing Flash certs done! :) ADL: Close_Session Content: 000300000000060000000600000000 ADL: Reboot Wait, reconneting... Failed init Test mode... :( Phone disconected! Connect phone on selected interface... Will Write CCC/HWC keys now... Using : 352696043985596_CRT.rpl CCC Data found! HWC Data found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 1BD00202DF7A0344FBFECB3D128DC89DF898C3F3 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.2.0 Processing RAWLOADER... FLIC : 00400098 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.2.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : blank (Erased or HW failure) ADL: Preparing for write certificates... ADL: Writing Flash certs done! :) ADL: Close_Session Content: 00060E434343000000000000000000 ADL: Reboot All done, disconneting... Done! Elapsed: 00:00:33 Connect phone on selected interface... Will Write CCC/HWC keys now... Using : 352696043985596_SIM.rpl - > File damaged, break operation Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 1BD00202DF7A0344FBFECB3D128DC89DF898C3F3 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.2.0 Processing RAWLOADER... FLIC : 00400098 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.2.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : blank (Erased or HW failure) ADL: Preparing for write certificates... ADL: Writing Flash certs done! :) ADL: Close_Session Content: 00060E4E5043000000000000000000 ADL: Reboot -> No any Flex keys selected, skip flex part Done! Phone disconected! Connect phone on selected interface... Will Write RPL keys now... Check RPL file... SimLock Data found! SimLock key found! WMDRM key found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 1BD00202DF7A0344FBFECB3D128DC89DF898C3F3 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.2.0 Processing RAWLOADER... FLIC : 00400098 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.2.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : blank (Erased or HW failure) ADL: Preparing for write certificates... ADL: Writing Flash certs done! :) ADL: Close_Session Content: 000300000000060000000600000000 ADL: Reboot Wait, reconneting... Phone not found... :( CertWrite failed : phone was not bootup Connection/SW/HW problem, try bootup manually If phone bootup Ok - write only flex keys Phone disconected! Connect phone on selected interface... Will Write CCC/HWC keys now... No any file selected, break operation Connect phone on selected interface... Will Write CCC/HWC keys now... No any file selected, break operation Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 1BD00202DF7A0344FBFECB3D128DC89DF898C3F3 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.2.0 Processing RAWLOADER... FLIC : 00400098 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.2.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : blank (Erased or HW failure) ADL: Preparing for write certificates... ADL: Writing Flash certs done! :) ADL: Close_Session Content: 00060E4E5043000000000000000000 ADL: Reboot -> No any Flex keys selected, skip flex part Done! Phone disconected! Connect phone on selected interface... Last edited by roberts; 05-08-2012 at 11:42. |
05-08-2012, 12:37 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Hello I not Seen any Erase Logs Now , Erase Phone Flash With Downgrade Frimware Write NPC and Simlock Data and Write PM with Local Sx4 u readed as PM backup |
The Following User Says Thank You to Mohsin-* For This Useful Post: |
05-08-2012, 19:31 | #9 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Correct 6700 downgrade : Backup Erase Flash 13.21 (MATTER!!!!!) , not power on phone Flash any version, which needed Repair, restore backups, e.t.c |
The Following User Says Thank You to Dzirt For This Useful Post: |
05-09-2012, 09:54 | #10 (permalink) |
Member: 67562 Status: Offline Sonork: none Thanks Meter: 89 | First time was hard but it work now...BIG thanks... Write PP, Repair SDD, Write RPL (all possible), restore HWC/CCC and Upload TUNE Can not write back full PM couse >error write 308< but phone seems to work. |
05-09-2012, 10:05 | #11 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | It is ok, phone is write-protected. And it only one such phone, which required such procedure ( erase, flash upper, flash lower version, repair ) |
07-21-2015, 15:31 | #13 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello, yes. USB is enough. http://forum.gsmhosting.com/vbb/8392341-post9.html |
07-24-2015, 16:21 | #14 (permalink) |
No Life Poster Join Date: Nov 2002 Location: slovakia Age: 46
Member: 17761 Status: Offline Thanks Meter: 91 | absolutly doesnt work after erase and flash 13.21, phone was autostart and then BEST doesnt allow Flash 13.10 without flashing 13.21, only 13.10, phone doesnt start and cant make repair. Solved flashing only ppm a cnt 13.10 via cyclone. phone working and have desired language |
07-24-2015, 17:02 | #15 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Seems as you not hear about "DG prevent check" option and not check messages in logs, which show hints about how proceed that in forced mode. |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
