01-08-2013, 14:24 | #1 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 708514 Status: Offline Thanks Meter: 36 | E5 after erase cant get local or test mode now phone cant get local or test mode on USB cable. i cant repair SDD................ card found: S/N xxxxxx registered to: xxxxxx Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Checking StartUp data ... ----------------------- SDD Key status : SDData Damaged!!!!! - > Do REPAIR SDD , Local SX4 if needed CMLA Key status : CMLA key Not exist SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! Reading Phone Info.... Connected phone - Nokia E5-00 Software ver : V ICPR82_11w16.3.4 17-08-11 RM-632 (c) Nokia IMEI : 352023041459716 Ape Ver : 081.004 APE Var : 081.004081.004.11.01081.004.216.04 APE ADSP: 256 DSP Ver : ICPR82_11w16 PPM : CNT : Product SN : CMJ331083 Product code : 059H8K7 Base Prd.code: 0590165 Module code : 0204475 Long Prod.SN : 0 Hardware info======= HWID : 1000 Retu : 35 Tahvo : 00 Batery: 4148 mV APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652. APE HW: 256 Lock info =========== IMEI : 352023041459716 IMEI spNet : 3A 25 20 03 14 54 79 01 IMEI svNet : 33 25 20 03 14 54 79 21 F7 Conf key : 8000000000000000 Provider key : 2140300000000000 Country : Spain Operator : Orange Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Damaged!!!!! CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Repair SD procedure started... Phone Imei: 352023041459716 Key file exists, no need to read... Check phone mode... Phone in RfInactive mode Seting Test mode... wait... Test mode set Writing Super Dongle Key... Ok! Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Checking StartUp data ... ----------------------- SDD Key status : SDData Damaged!!!!! - > Do REPAIR SDD , Local SX4 if needed CMLA Key status : CMLA key Not exist SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! how can fix this problem ?? plz help........ |
01-08-2013, 14:36 | #2 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Roof of the world
Member: 209722 Status: Offline Thanks Meter: 818 | Quote:
01-08-2013, 14:46 | #3 (permalink) |
Member: 708514 Status: Offline Thanks Meter: 36 | cant write ENO file............ card found: S/N xxxxxxxx registered to: xxxxxxx Connect phone on selected interface... Core : v1.59 , BB5XG FlashEngine : v3.8 Selected FlashSettings : Manual FlashFile verify disabled Files Set for Flashing : MCU : E5_ENO_WK2012_v034.fpx_cry Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 11200115199903447A83E013BC956006FAC8DAE1 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C ADL: phone is in flash mode ===Flashing [MCU]=== Erase : Processing E5_ENO_WK2012_v034.fpx_cry Checking flash content , please wait... Checking flash done Error: Erase/Write : Bad image file Connect phone on selected interface... Elapsed: 00:00:08 Connect phone on selected interface... |
01-09-2013, 12:07 | #8 (permalink) |
Member: 708514 Status: Offline Thanks Meter: 36 | Bad CNT file of version rm632_101.003............... plz check this. card found: S/N xxxxxx registered to: xxxxxxx Connect phone on selected interface... Core : v1.59 , BB5XG FlashEngine : v3.8 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Bad file : rm632_101.003_U005.000_prd.uda.fpsx Bad Flash files detected, will break procedure Core : v1.59 , BB5XG FlashEngine : v3.8 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Bad file : rm632_101.003_U009.000_prd.uda.fpsx Bad Flash files detected, will break procedure |
01-10-2013, 06:35 | #10 (permalink) | |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | Quote:
Better Download other flash file, select same product code and try again... | |
01-10-2013, 06:38 | #11 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | If it Say bad - that mean file is damaged and can harm phone. I will check eno's list today. |
The Following User Says Thank You to Dzirt For This Useful Post: |
01-11-2013, 15:56 | #14 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Sorry, at now moment away from home pc. Will be only tomorrow on evening. Also - you can try flash my old eno, which you was already try with ver 1.56 , this eno is ugly, but will work. |
01-15-2013, 09:23 | #15 (permalink) |
Junior Member Join Date: Jul 2009 Location: Nigeria
Member: 1066070 Status: Offline Sonork: nokia Thanks Meter: 0 | Reading Phone Info.... Connected phone - Nokia 201 Software ver : V 11.90 25-10-12 RM-799 (c) Nokia IMEI : 353276056263576 PPM : V 11.90 25-10-12 RM-799 (c) Nokia SP CNT : Content: sp_059K664 V 11.90 25-10-12 RM-799 (c) Nokia Product SN : 4DA0055BI Product code : 059K4B8 Base Prd.code: 059J2K2 Module code : 0205022 Long Prod.SN : 0 Hardware info======= HWID : 2205 Batery: 4064 mV CMT BT: 19e2-47026 LCDVer: TPO Lock info =========== IMEI : 353276056263576 IMEI spNet : 3A 35 72 06 65 62 53 07 IMEI svNet : 33 35 72 06 65 62 53 17 F3 Sl Conf : 001-01-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : BFAD92D24653DE83 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; CRT308 Backup Created INFINEON : SuperDongle not exist (It is Ok) CMLA Key status : Ok SimLock status : Ok Security status : Damaged!!!!! PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Processing XG213 Security repair Security status : DAMAGED Breaked by user Backup Certificates now... Backup CRT308 data... CRT308 Backup Created Check communication with phone.... Communication verify done... Preparing... SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok CMLA Key read ... Ok Reboot.... Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd : Custom 2nd boot Ok, 01 2nd ready, AA Sending Algo ALG : Custom Algo sent Ok BL : Quantum_Bootloader_10.46_M1S1 Boot done! Reading CCC Reading HWC Reading NPC IMEI : 353276056263576 PCcode : 059K4B8 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : F:\Program Files\BEST\Backup\Cert\353276056263576_XG213.rpl Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Checking StartUp data ... ----------------------- INFINEON : SuperDongle not exist (It is Ok) CMLA Key status : CMLA key is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! Help me |
