Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks: 93
| hi mates did a downgrade on this one (this was needed). Tried to restore imei from the rpl backup but cannot manage to restore the imei back. any help appreciated thanks |
| | #3 (permalink) |
| did follow the exact steps in the thread.. BB5 Downgrade, ERASE, REPAIR, e.t.c) How-To problem is when arriving at the 4th step. Phone is not getting in test mode. thanks |
| | #5 (permalink) |
| these are the logs however they are not in a specific order as i tried several times in various ways. Client took it back however if he might get it back. Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Repair SL procedure started... Phone Imei: 12345610654321? Key file exists, no need to read... Check phone mode... Phone in RfInactive mode Seting Test mode... wait... Test mode set Writing SimLock Data... Ok! Writing SimLock Key... Ok! Done! Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Repair SD procedure started... - > IMEI Validation : IMEI Damaged!!!! - > SDD Info will be wrong! - > RESTORE NPC FIRST Phone Imei: 12345610654321? Key file exists, no need to read... Check phone mode... Phone in RfInactive mode Seting Test mode... wait... Test mode set Writing Super Dongle Key... Ok! Done! Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Local SX4 procedure started... - > IMEI Validation : IMEI Damaged!!!! - > SECURITY Info will be wrong! - > RESTORE NPC FIRST Phone Imei: 12345610654321? Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > Try Check "Custom Keys" checkbox and repeat - > If SDD original - "Use Server Sx4" Local SX4 procedure started... - > IMEI Validation : IMEI Damaged!!!! - > SECURITY Info will be wrong! - > RESTORE NPC FIRST Phone Imei: 12345610654321? Use custom key... Step 1... Step 2... SX4 Auth fail... - > Try Check "Custom Keys" checkbox and repeat - > If SDD original - "Use Server Sx4" - > IMEI Validation : IMEI Damaged!!!! - > SECURITY Info will be wrong! - > RESTORE NPC FIRST Processing Server SX4 Auth Checking SDD key... Check SD : Key Damaged!!! SX4 Auth error ![]() Local SX4 procedure started... - > IMEI Validation : IMEI Damaged!!!! - > SECURITY Info will be wrong! - > RESTORE NPC FIRST Phone Imei: 12345610654321? Use custom key... Step 1... Step 2... SX4 Auth fail... - > Try Check "Custom Keys" checkbox and repeat - > If SDD original - "Use Server Sx4" Using : RM-632.pp Check phone mode... Phone in RfInactive mode Seting Test mode... wait... Test mode set Write 46 element(s)... Writen : 46 elements Done! Elapsed: 00:00:22 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Uploading RF/Battery tune to phone... Using : RM-632.pm Check phone mode... Phone in RfInactive mode Seting Local mode... wait... Local mode set Field 1 Record 0 write - Ok Record 2 write - Ok Record 4 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 13 write - Ok Record 16 write - Ok Record 18 write - Ok Record 20 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 26 write - Ok Record 28 write - Ok Record 29 write - Ok Record 31 write - Ok Record 33 write - Ok Record 34 write - Ok Record 35 write - Ok Record 37 write - Ok Record 39 write - Ok Record 40 write - Ok Record 41 write - Ok Record 42 write - Ok Record 43 write - Ok Record 44 write - Ok Record 45 write - Ok Field 309 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 7 write - Ok Record 17 write - Ok Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED ![]() - > Try different PM files or "Restore CCC/HWC" option Done! Elapsed: 00:00:21 Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Checking StartUp data ... ----------------------- IMEI Validation : IMEI Damaged!!!! - > SIMLOCK , SECURITY Info can be wrong! - > Need restore NPC backup or RPL SDD Key status : SDData Damaged!!!!! ![]() - > Do REPAIR SDD , Local SX4 if needed SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL phone detected Done! - > IMEI Validation : IMEI Damaged!!!! - > SECURITY Info will be wrong! - > RESTORE NPC FIRST Processing Server SX4 Auth Checking SDD key... Check SD : Key Damaged!!! SX4 Auth error ![]() - > IMEI Validation : IMEI Damaged!!!! - > SECURITY Info will be wrong! - > RESTORE NPC FIRST Processing Server SX4 Auth Checking SDD key... Check SD : Key Damaged!!! SX4 Auth error ![]() Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! SuperDongle Key found! CMLA key found! WMDRM key found! -> Skip Flash keys Part, for Flash Part use Dead Mode or Fbus Check phone mode... Phone in RfInactive mode Seting Test mode... wait... Test mode set Failed init Test mode... ![]() Phone disconected! Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! SuperDongle Key found! CMLA key found! WMDRM key found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 06900106B5DA0344D0F8EE14F8DD285E9BADC66F ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.34.0 Processing RAWLOADER... FLIC : 00500020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.34.0 Processing PASUBTOC ... Processing ALG ... Boot Done! ![]() TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C ADL: Preparing for write certificates... Erase NPC... Ok Writing NPC... Ok Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! ![]() ADL: Close_Session Content: 0003000000000C0000000C00000000 ADL: Reboot Wait, reconneting... Phone not found... ![]() CertWrite failed : phone was not bootup Connection/SW/HW problem, try bootup manually If phone bootup Ok - write only flex keys Phone disconected! |
| | #6 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2009 Location: Russia , Syberia Age: 23
Member: 1157320 Status: Online Sonork: 100.1616907 Thanks: 4,098
| Hm, too much not needed things i see. First - erase phone. Second - flash it ( with eno ) Third - Check phone startup - Fourth - Write back rpl If here start problems - put here your rpl for check. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 07-31-2012 20:09 |
| Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 8 | 04-06-2012 16:22 |
| 6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 5 | 11-21-2011 00:44 |
| Working IMEI changed phone? | Barjo | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 10-08-1999 14:22 |
| Imei | Arnis | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 09-15-1999 02:38 |
