03-01-2013, 13:01 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: MX-KEY is the BEST NOKIA TOOL
Member: 46042 Status: Offline Sonork: 100.1575650 Thanks Meter: 93 | e71 simlock damaged Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! WMDRM key found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 131000156FA30052A077277D07CF376D011E581A ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.5 Use URAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : 52570A2086C79E6965175815B5388535CDD5C6F7 ADL: Preparing for write certificates... ADL: Writing Flash certs done! CFL: Close_Session Content: 000300000000000000000000000000 CFL: Reboot Wait, reconneting... Writing SimLock Data... Error Writing SimLock Key... Ok! Product Code Update : 0570193 SDD Key status : SD Data is Ok SimLock status : SimLock Damaged!!!!! Security status : Security is Ok Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok can someone help its sl2 |
03-01-2013, 20:12 | #3 (permalink) |
Member: 46042 Status: Offline Sonork: 100.1575650 Thanks Meter: 93 | registered to: Kays Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 131000156FA30052A077277D07CF376D011E581A ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.5 Use URAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : 52570A2086C79E6965175815B5388535CDD5C6F7 CFL : Reading NPC IMEI : 354856040271980 CFL : Reading CCC CFL : Reading HWC NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\354856040271980_CR T.rpl Trying read spr block , wait ... Get phone data... Get flash data... SPR Read Ok! Spr saved to : 354856040271980.rapido_spr CFL: Close_Session Content: 000300000000000000000000000000 CFL: Reboot Processing SimLock extraction.... Checking readed data, wait few seconds ID_INFO : ICPR71_09w47.8/05-08-10/RM-346 #1st block Ok [SLT] - > Initial check failed, SimLock seems dead Elapsed: 00:11:18 Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Repair SL procedure started... Phone Imei: 354856040271980 - > Power Off phone, dissconnect it and connect Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB PUBLIC ID: 131000156FA30052A077277D07CF376D011E581A ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 Fetching data, wait... - > Reinsert cable and battery, press powerOn button again - > For X7, E7 - just waiting, near 1 minute - > When BEST start Search Phone - Press PowerOn if needed Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 131000156FA30052A077277D07CF376D011E581A ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.5 Use URAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : 52570A2086C79E6965175815B5388535CDD5C6F7 CFL: Close_Session Content: 000300000000000000000000000000 CFL: Reboot Wait, reconneting... rap= 131000156FA30052A077277D07CF376D011E581A hash= 479C6DDE3942E12C429C1D6ADED80371 key= 036696792D3550E31FC703BCC58EF47D4D82668A Key file updated... Operating mode is OK, no need change... Writing SimLock Data... Error Repair fail...! ( SL3 phone? ) |
12-29-2013, 07:51 | #8 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | First - try make Restore SL. If it can be done - erase and check. Also, if SL not sucess - possible also open phone and check BSI line and main voltages on power, cpu, check short on i2c and e.t.c. |
