08-16-2015, 12:51 | #1 (permalink) |
Registered User Join Date: Dec 2004 Location: largest democratic country
Member: 100376 Status: Offline Sonork: 100.1591842 Thanks Meter: 150 | error repair/flashing nokia x2 rm-1013 Connect phone on selected interface... Core : v2.10 , NXP FlashEngine : v4.9 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : rm1013_2.1.0.12_059V781_001_rawprogram_unsparse_ui .xml Ok, Set : rm1013_2.1.0.12_user_prog_emmc_firehose_8x10.mbn Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Get Phone Initial Info Product : MSM8610 Version : 0.5 Serial : 1EE4D45F [FireHose_Error] : Error while set RAW mode (SBL Erase error)! Try flash again in DEAD mode Flash Error Break flashing! Connect phone on selected interface... Phone found! Nokia X Platform Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... Phone found! Nokia X Platform Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... when i put set in 9008 qualcomm port it gives me error Core : v2.10 , NXP FlashEngine : v4.9 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : rm1013_2.1.0.12_059V781_001_rawprogram_unsparse_ui .xml Ok, Set : rm1013_2.1.0.12_user_prog_emmc_firehose_8x10.mbn Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected [FireHose_Error] : Handshake Error! Can't init FHProtocol settings! Check Battery, Cable Flash Error Break flashing! |
08-16-2015, 13:41 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | It can't switch to RAW - error while erase SBL - possible eMMC fault. It can't init FireHose protocol - even handshake - possible eMMC fault. Suggest first check power, water damage, rehot eMMC. |
04-03-2016, 19:38 | #7 (permalink) |
Cheater -Don't Deal with him- Join Date: Jun 2013 Location: New Zealand
Member: 1965371 Status: Offline Thanks Meter: 441 | Bro power off phone Connect phone goto device manager Uninstall drivers dissconnect phone connect phone and drivers will install automatically try flash... I have solve same prolem so many times with this proceder Atf or best not a problem.. problem is drives attack |
