02-22-2017, 14:01 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: ABouSHaDy Age: 48
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | first full flash nokia 150 rm-1190 Card found: S/N : ******* , v0134 Registered to: aboushady Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 10.02.11 00-00-00 RM-1190 IMEI 1 : 354887080741624 IMEI 2 : 354887080741632 XappVer : 000008CA Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : IM CNT : DUBAI61D.10.02.11.p1 Product SN : F74FCF4AU Product code : 059X969 Base Prd.code: 059X7J5 Module code : 0207092 Hardware info======= HWID : 1100 LCDVer: TPO Lock info =========== IMEI : 354887080741624 IMEI spNet : 3A 45 88 07 08 47 61 42 Conf key : 800000000004000B Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; SimLock status : Ok Security status : Ok Done! Software Info: 10.02.11 00-00-00 RM-1190 IMEI: 354887080741624 PPM version : IM Product code: 059X969 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 12 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 5E8E68EFE2CBCC4F033C1A350C6AB644 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DUBAI61D.10.02.11.p1 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive Mobile Info IMEI : 354887080741624 BBUID : 5E8E68EFE2CBCC4F033C1A350C6AB644 PCCode: 059X969 SimLock Info : STATE : OPENED ( NOT LOCKED ) Dump Saved to : 354887080741624_MTKx.bin RPL Saved to : 354887080741624_MTKx.mtsec Read Done! Connect phone on selected interface... https://mega.nz/#!a5wSwKgb!szs5d6U3X...6T94vPLBJBPmk4 ABOUSHADY |
The Following 5 Users Say Thank You to ABOUSHADY For This Useful Post: |
03-30-2017, 07:19 | #4 (permalink) |
Freak Poster Join Date: Feb 2011 Location: Ujmair Mobiles Hassanabdal Age: 37
Member: 1520256 Status: Offline Sonork: 100.1612582 Thanks Meter: 137 | Nokia 150 RM-1190 User Code Reset Done Nokia 150 RM-1190 User Code Reset Done Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 7 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 29C3A204BF7323ACB8737FA2E7E1B9CF BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
05-09-2017, 16:08 | #5 (permalink) |
Freak Poster Join Date: Oct 2009 Location: Sharjah Age: 32
Member: 1141098 Status: Offline Sonork: 100.1625915 Thanks Meter: 35 | Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1190_ROM_eMP_10.02.11 VIVA : RM-1190_VIVA_eMP_10.02.11 LANG : RM-1190_LANG_PACK_ROM_AE1_eMP_10.02.11_001 CUST : RM-1190_CUSTPACK_ROM_AE1_EURO_FR_eMP_10.02.11_001 JMPT : RM-1190_JUMP_TABLE_AE1_EURO_FR_eMP_10.02.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 214 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 74FD8E8A63CE3C1C9FE44B36C0E03E20 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DUBAI61D.10.02.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Dubai.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000 SecureDecrypt : RM-1190_ROM_eMP_10.02.11 SecureDecrypt : RM-1190_VIVA_eMP_10.02.11 SecureDecrypt : RM-1190_LANG_PACK_ROM_AE1_eMP_10.02.11_001 SecureDecrypt : RM-1190_CUSTPACK_ROM_AE1_EURO_FR_eMP_10.02.11_001 SecureDecrypt : RM-1190_JUMP_TABLE_AE1_EURO_FR_eMP_10.02.11_001 OVRLP : 000069B900000001 PHPID : DUBAI61D.10.02.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1190_ROM_eMP_10.02.11 Write : RM-1190_LANG_PACK_ROM_AE1_eMP_10.02.11_001 Write : RM-1190_CUSTPACK_ROM_AE1_EURO_FR_eMP_10.02.11_001 Write : RM-1190_JUMP_TABLE_AE1_EURO_FR_eMP_10.02.11_001 Write : RM-1190_VIVA_eMP_10.02.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1190_ROM_eMP_10.02.11 [VERIFY] DONE : RM-1190_LANG_PACK_ROM_AE1_eMP_10.02.11_001 [VERIFY] DONE : RM-1190_CUSTPACK_ROM_AE1_EURO_FR_eMP_10.02.11_001 [VERIFY] DONE : RM-1190_JUMP_TABLE_AE1_EURO_FR_eMP_10.02.11_001 [VERIFY] DONE : RM-1190_VIVA_eMP_10.02.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:06 Reboot phone Ok Connect phone on selected interface... Phone On contact service now what is solution ??? |
05-09-2017, 17:24 | #6 (permalink) | |
Member: 1141098 Status: Offline Sonork: 100.1625915 Thanks Meter: 35 | Quote:
08-27-2017, 15:42 | #7 (permalink) |
Junior Member Join Date: Mar 2015 Location: dhaka
Member: 2361389 Status: Offline Thanks Meter: 5 | NOKIA RM-1190 factory reset without flash NOKIA RM-1190 factory reset security code unlock 1 click without flash JUST USE Infinity BEST ............... https://drive.google.com/file/d/0B_C...ew?usp=sharing https://drive.google.com/file/d/0B_C...ew?usp=sharing |
The Following User Says Thank You to gsm sisir For This Useful Post: |
09-11-2017, 08:56 | #8 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2756530 Status: Offline Thanks Meter: 0 | Nokia 150 flashing impossible Hi everybody, i tried to flash my nokia 150 but it doesn´t boot while flashtool is running. it always brings the nokia-start-logo. Is it my phone or am i doing something wrong? Thanks for quick replies. mat |
10-04-2017, 07:47 | #9 (permalink) |
Insane Poster Join Date: Feb 2017
Member: 2689625 Status: Offline Thanks Meter: 21 | --- Insert USB cable now! --- Wait for phone... Phone found! [ 22 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : D0BC6DE00D2899EAE7B7CEFE24794186 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DUBAI61D.10.02.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Dubai.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000 SecureDecrypt : RM-1190_DUBAI_ROM_eMP_11.00.11 SecureDecrypt : RM-1190_DUBAI_VIVA_eMP_11.00.11 SecureDecrypt : RM-1190_DUBAI_LANG_PACK_ROM_EC_eMP_11.00.11 SecureDecrypt : RM-1190_DUBAI_CUSTPACK_ROM_EC_eMP_11.00.11 SecureDecrypt : RM-1190_DUBAI_JUMP_TABLE_EC_eMP_11.00.11 Executing FFS FORMAT now... FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000 DA_RET : DA_IN_PROGRESS 00000BD9 DA_RET : FORMAT_FAILED [ERROR] : [ERROR] : DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 [ERROR] : Error While erase area!!! Flashing failed! |
10-04-2018, 10:20 | #10 (permalink) | |
Freak Poster Join Date: Feb 2015 Location: iran
Member: 2341104 Status: Offline Thanks Meter: 9 | Quote:
in device manager phone detect | |
