12-12-2019, 18:38 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,802 | first in world nokia 130 TA-1017 v30.00.11 arabic french english portugese firmware nokia 130 TA-1017 059Z0X8 v30.00.11 language arabic french english portugese firmware Code: Infinity-Box BEST Nokia [HMD] Module [NK2] v1.19 Reconnect Power/Cable! Operation : Read FirmWare [ v1.19 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM386) MODE : NOKIA USB SERIAL PORT : 386 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 0D8BD34FEBE5F5AABBC9C58F55D20B10 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : KESA61A.30.00.11.p1 BOOT : SWR : 30.00.11 BOOT : BDDS : 20 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : KESA61A.30.00.11.p1 FLASH : 00EF : 0060 : 0017 : 0000 CODE : 0x00580000 Reading Flash ... TDSN : TA-1017 PRDC : 059Z0X8 PPM : IC LANG : [1] : Arabic (Saudi Arabia) [2] : Portuguese (Portugal) [3] : French (France) [4] : English (United Kingdom) BUILD : TA-1017_ROM_eMP_30.00.11 BUILD : TA-1017_LANG_PACK_ROM_IC_eMP_30.00.11_001 BUILD : TA-1017_CUSTPACK_ROM_IC_eMP_30.00.11_001 BUILD : TA-1017_JUMP_TABLE_IC_eMP_30.00.11_001 BUILD : TA-1017_VIVA_eMP_30.00.11 Make VPL definition Save Path : D:\BST\infinty\TA-1017\ Save Name : TA-1017_059Z0X8_30.00.11.vpl Build Finished! Done! Elapsed: 00:05:25 Reconnect Power/Cable! ****************************/file/b0vuf...ugese.rar/file if post helpful press thanks button |
The Following 11 Users Say Thank You to profkefah For This Useful Post: |
12-15-2019, 12:43 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
11-28-2020, 08:28 | #6 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | flashing ok but same Contact service Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Open VPLfile : TA-1017_059Z0X8_30.00.11.vpl Description : TA-1017 IC DeviceType : TA-1017 ProductCode : 059Z0X8 SoftwareVer : 30.00.11 PPM LangPack : [1] : Arabic (Saudi Arabia) [2] : Portuguese (Portugal) [3] : French (France) [4] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : True Setting : LangPack Only : True 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM8) MODE : NOKIA USB SERIAL PORT : 8 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : E3A3AA746D75774F38FFA3E282E646AF BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : KESA61A.30.00.11.p1 BOOT : SWR : 30.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : KESA61A.30.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0060 : 0017 : 0000 NOR: [WINBOND] W25Q64DW NOR: TSIZE : 0x00800000 [ 8.00 MB ] PSIZE : 0x00800000 [ 8.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 30.00.11 [TA-1017] DEV SoftwareVersion : 30.00.11 SWInfo compare result : SAME Load FlashSet : LANG : TA-1017_LANG_PACK_ROM_IC_eMP_30.00.11_001 CUST : TA-1017_CUSTPACK_ROM_IC_eMP_30.00.11_001 JUMP : TA-1017_JUMP_TABLE_IC_eMP_30.00.11_001 Prepare FlashSet : DCR : TA-1017_LANG_PACK_ROM_IC_eMP_30.00.11_001 DCR : TA-1017_CUSTPACK_ROM_IC_eMP_30.00.11_001 DCR : TA-1017_JUMP_TABLE_IC_eMP_30.00.11_001 Prepare Target SDS : OK : 0x007F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1017_LANG_PACK_ROM_IC_eMP_30.00.11_001 Write : TA-1017_CUSTPACK_ROM_IC_eMP_30.00.11_001 Write : TA-1017_JUMP_TABLE_IC_eMP_30.00.11_001 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1017_LANG_PACK_ROM_IC_eMP_30.00.11_001 Verify : TA-1017_CUSTPACK_ROM_IC_eMP_30.00.11_001 Verify : TA-1017_JUMP_TABLE_IC_eMP_30.00.11_001 Done! Elapsed: 00:00:44 Reconnect Power/Cable! |
