01-12-2015, 16:51 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | flash RM-971 with RM-970 firmware ??? can someone confirm if this would or wouldn't kill the phone? if the band doesnt change after this, I know I should try some hardware mod, but I want to start at the firmware. |
01-12-2015, 20:27 | #3 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Awesome, will download latest version and will try, is there any issue with these mtk phones if there is a downgrade attempt? does it requires any special procedure to downgrade? like rapido, rapu, etc? @DZirt, I have been waiting for your reply regarding the RDA phone I asked you, I uploaded the full flash to mtk(@)infinity-box.com, I cant upload directly to sharing sites, if possible provide me with your email address via PM and I will send it directly to you. |
01-12-2015, 20:53 | #4 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | No, there is no any problem. Just flash need and that is all. Just tick "RPL backup" once , just to have backup Backup - can send on sprevive(at)gmail.com . |
01-13-2015, 19:02 | #6 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Here Log Code: Core : v2.01 , MTKx FlashEngine : v6.8 Verify files ... MAUI : RM-970_ROM_eMP_20.14.11 VIVA : RM-970_VIVA_eMP_20.14.11 LANG : RM-970_LANG_PACK_ROM_UA_eMP_20.14.11_001 CUST : RM-970_CUSTPACK_ROM_UA_LATAM_LTA_eMP_20.14.11_001 JMPT : RM-970_JUMP_TABLE_UA_LATAM_LTA_eMP_20.14.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 104 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : CCED35DC767BEF279EE447DF953C7EFF BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Rivendell.14.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 SecureDecrypt : RM-970_ROM_eMP_20.14.11 SecureDecrypt : RM-970_VIVA_eMP_20.14.11 SecureDecrypt : RM-970_LANG_PACK_ROM_UA_eMP_20.14.11_001 SecureDecrypt : RM-970_CUSTPACK_ROM_UA_LATAM_LTA_eMP_20.14.11_001 SecureDecrypt : RM-970_JUMP_TABLE_UA_LATAM_LTA_eMP_20.14.11_001 OVRLP : 000069B900000001 PHPID : Rivendell.14.00.11.p1 === Backup Enabled Reading RPL backup... Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive :) Mobile Info : IMEI : 351708064456125 BBUID : CCED35DC767BEF279EE447DF953C7EFF SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 351708064456125_MTK.mtsec === Backup OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x00040000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-970_ROM_eMP_20.14.11 Write : RM-970_LANG_PACK_ROM_UA_eMP_20.14.11_001 Write : RM-970_CUSTPACK_ROM_UA_LATAM_LTA_eMP_20.14.11_001 Write : RM-970_JUMP_TABLE_UA_LATAM_LTA_eMP_20.14.11_001 Write : RM-970_VIVA_eMP_20.14.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-970_ROM_eMP_20.14.11 [VERIFY] DONE : RM-970_LANG_PACK_ROM_UA_eMP_20.14.11_001 [VERIFY] DONE : RM-970_CUSTPACK_ROM_UA_LATAM_LTA_eMP_20.14.11_001 [VERIFY] DONE : RM-970_JUMP_TABLE_UA_LATAM_LTA_eMP_20.14.11_001 [VERIFY] DONE : RM-970_VIVA_eMP_20.14.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:02:30 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds |
01-13-2015, 19:15 | #7 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Restored RPL Security but still get Contact Service Code: Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 104 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : CCED35DC767BEF279EE447DF953C7EFF BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Rivendell.20.14.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 Boot Ok Get settings... SDS OFF : 0x00FF4000 SDS LEN : 0x0000C000 [INFO] : Plain RPL [RPL VERIFY] : Code 0x10 : MOBILE_ID match with MOBILE_ID info in RPL! Write : 351708064456125_MTK.mtsec Encrypt Done, Now Re-connect power/cable! Wait for phone... Phone found! [ 104 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : CCED35DC767BEF279EE447DF953C7EFF BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Rivendell.20.14.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 Boot Ok Get settings... Write : 351708064456125_MTK_enc.mtsec Security restored All done! Connect phone on selected interface... |
01-13-2015, 19:24 | #8 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. Flash back original FW. It will be Ok. Seems as cross-flashing work well only between Single/Dual sim models. Like 108/108DS , 225/225DS and similar. |
01-13-2015, 20:44 | #9 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | there is nokia 220 RM969, 970 and 971, I will try: - go back to rm971 - flash to rm 969 if (dies) then backto(rm970) else (tnankz @dzirt) ... |
01-15-2015, 00:11 | #10 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Well, I flashed with rm969, and it just power on to NOKIA logo and power down or reboot. I flashed back to rm 971 and gave it back to customer |
