06-10-2012, 05:51 | #32 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | Awesome work. Code: card found: S/N 0021:0118 registered to: Subrata Connect phone on selected interface... UFS S/N 70083 boot - Ok Connect phone on selected interface... Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok No answer from phone... :( - > 1. Check cable/connection, try again - > 2. Maybe HW fault or bad cable Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000030000022600010007400C192103032108 CMT EM0 ID : 00001040 CMT EM1 ID : 00001030 CMT PUB ID : 38680000FFFB7C4060E22AFC9E31053FB3EC51D1 CMT MODE ID : 00 CMT R_HASH : 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROM ID : 2CAC45E23BC33C8B UFSx doesn't support New Protocol :( - > Use USB cable for this phone ;D Phone found! Series 60 Device detected! read info... - Ok Read and Check phone data... SDD Key status : SDData is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! :( - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL3 phone detected , SP_CODE_LEN : 15 Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000030000022600010007400C192103032108 CMT EM0 ID : 00001040 CMT EM1 ID : 00001030 CMT PUB ID : 38680000FFFB7C4060E22AFC9E31053FB3EC51D1 CMT MODE ID : 00 CMT R_HASH : 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROM ID : 2CAC45E23BC33C8B UFSx doesn't support New Protocol :( - > Use USB cable for this phone ;D Init Service mode... Wait... Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Core : v1.45 , FlashEngine : v1.40 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm774_ENOAPE_wk2012_0037.fpx_cry Check FlashFiles, Please, wait... Bad file : rm774_ENOAPE_wk2012_0037.fpx_cry Bad Flash files detected, will break procedure :( Core : v1.45 , FlashEngine : v1.40 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm774_ENOAPE_wk2012_0037.fpx_cry Check FlashFiles, Please, wait... Bad file : rm774_ENOAPE_wk2012_0037.fpx_cry Bad Flash files detected, will break procedure :( Phone disconected! Connect phone on selected interface... Connect phone on selected interface... Core : v1.45 , FlashEngine : v1.40 Selected FlashSettings : Manual FlashFile verify disabled Files Set for Flashing : MCU : rm774_ENOAPE_wk2012_0037.fpx_cry Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 38680000FFFB7C4060E22AFC9E31053FB3EC51D1 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.11.0 Processing RAWLOADER... FLIC : 00600020 Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.11.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : FEB3BB7481D3E5D0EAC907335A4402A071493D53 ADL: phone is in flash mode ===Flashing [MCU]=== Erase : Processing rm774_ENOAPE_wk2012_0037.fpx_cry Checking flash content , please wait... Checking flash done Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm774_ENOAPE_wk2012_0037.fpx_cry Total writen 380 blocks TIME : Write time : 00:00:06 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:07 Reboot phone now... Afterflash not selected, skip Done! Elapsed: 00:00:17 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Will Write RPL keys now... Check RPL file... CCC Data found! (CMT) HWC Data found! (CMT) -> Skip Flash keys Part, for Flash Part use Dead Mode or Fbus Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Will Write RPL keys now... Check RPL file... CCC Data found! (CMT) HWC Data found! (CMT) -> Skip Flash keys Part, for Flash Part use Dead Mode or Fbus Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Repair SD procedure started... Phone Imei: 358272045202275 - > Power Off phone, dissconnect it and connect Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB PUBLIC ID: 38680000FFFB7C4060E22AFC9E31053FB3EC51D1 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 Fetching data, wait... - > Reinsert cable and battery, press powerOn button again - > For X7, E7 - just waiting, near 1 minute - > When BEST start Search Phone - Press PowerOn if needed Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 38680000FFFB7C4060E22AFC9E31053FB3EC51D1 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.11.0 Processing RAWLOADER... FLIC : 00600020 Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.11.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : FEB3BB7481D3E5D0EAC907335A4402A071493D53 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Wait, reconneting... rap= 38680000FFFB7C4060E22AFC9E31053FB3EC51D1 hash= 3AB5DB70B45D23F1ADEEBB5734160706 key= 7020174603D148CD07E7009D42C8F3FC54135704 Key file updated... Accepted SdRepReq (on alive SD) by user Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Writing Super Dongle Key... Ok! Done! Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358272045202275 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" enabled, try again now - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358272045202275 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-774.pm Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED :( - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:01 Upload done Will Write CCC/HWC keys now... Using : RM-774.rpl CCC Data found! HWC Data found! Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 38680000FFFB7C4060E22AFC9E31053FB3EC51D1 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.11.0 Processing RAWLOADER... FLIC : 00600020 Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.11.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : FEB3BB7481D3E5D0EAC907335A4402A071493D53 ADL: Preparing for write certificates... Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! :) ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot All done, disconneting... Done! Elapsed: 00:00:23 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358272045202275 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-774.pm Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => OK Done! Elapsed: 00:00:00 Upload done Reading Phone Info.... Connected phone - Nokia 701 Software ver : V 79u_sr2_12w09_4 29-03-12 RM-774 (c) Nokia IMEI : 358272045202275 Ape Ver : 112.010.1404 APE Var : 112.010.1404112.010.1404.04.01112.010.1404.C00.01 APE ADSP: 256 DSP Ver : 104_12w09 APE Test: 0.037 PPM : CNT : Product SN : M1L610763 Product code : 059H226 Base Prd.code: 059G8T9 Long Prod.SN : 0 Hardware info======= HWID : 2100 Retu : 40 Tahvo : 00 Batery: 3932 mV APE BT: HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. APE HW: 256 Lock info =========== IMEI : 358272045202275 IMEI spNet : 3A 85 72 02 54 02 22 07 IMEI svNet : 33 85 72 02 54 02 22 17 F8 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to .:SUBRATA:. For This Useful Post: |
06-10-2012, 14:12 | #33 (permalink) |
No Life Poster Join Date: Nov 2009 Location: BaNgLaDeSh Age: 41
Member: 1150957 Status: Offline Thanks Meter: 60 | See this post i have same problem with nokia e6 phone http://forum.gsmhosting.com/vbb/f609...n-not-1481512/ |
11-25-2012, 19:15 | #37 (permalink) |
Freak Poster Join Date: Jul 2006 Location: ONLY WITH YOU Age: 39
Member: 314847 Status: Offline Thanks Meter: 102 | Connect phone on selected interface... Core : v1.57 , FlashEngine : v3.5 Selected FlashSettings : FlashFile verify disabled Files Set for Flashing : MCU : rm774_ENOAPE_wk2012_0037.fpx_cry Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 90500000FFFB7C40DC3E2D2FC8F045D33CFCE28D ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : FEB3BB7481D3E5D0EAC907335A4402A071493D53 ADL: phone is in flash mode ===Flashing [MCU]=== Erase : Processing rm774_ENOAPE_wk2012_0037.fpx_cry Checking flash content , please wait... Checking flash done Error: Erase/Write : Bad image file Connect phone on selected interface... Elapsed: 00:00:22 Connect phone on selected interface... |
08-12-2014, 08:02 | #42 (permalink) |
Junior Member Join Date: Nov 2012 Location: WASHIM
Member: 1843427 Status: Offline Thanks Meter: 0 | Imei problem I have today nokia 701 1)fully ears 2)full flash then 3)write rpl then mobile show start up fail contect retailer PLZZZZZZZZZZZZZZZZZZZZ HELPPPP MEEEEE |
08-13-2014, 07:50 | #45 (permalink) |
Freak Poster Join Date: Jun 2013 Location: south Africa
Member: 1960717 Status: Offline Sonork: 100.1638403 Thanks Meter: 34 | Ok, i will make it tomorrow, need find phone for test. in soltion >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>>>>>>>>>>>>>>>>>>>>>> |
