11-12-2013, 06:07 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: syria Age: 46
Member: 257716 Status: Offline Sonork: 1650684 Thanks Meter: 57 | help best with nokia 301 rm-839 |
The Following User Says Thank You to harold6x For This Useful Post: |
11-12-2013, 07:48 | #2 (permalink) | |
Junior Member Join Date: Nov 2008 Location: Russia, Plesetsk Cosmodrome
Member: 898692 Status: Offline Thanks Meter: 5 | Quote:
11-12-2013, 10:11 | #4 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | They work well. Insert cable in powered off phone, PC will search drivers. Repeat 3-5 rimes. Should find, or install by hands when new device appear in list. Driver to install - winUsb. |
The Following User Says Thank You to Dzirt For This Useful Post: |
11-13-2013, 01:10 | #5 (permalink) |
Member: 257716 Status: Offline Sonork: 1650684 Thanks Meter: 57 | itry for 100 not done but here is log for normal mode card found: S/N 50A6:0118 registered to: [email protected] Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 301 Dual SIM Software ver : V 02.33 17-05-13 RM-839 (c) Nokia IMEI 1 : 357885051028549 IMEI 2 : 357885051028556 XappVer : 000006D1 PPM : V 02.33 17-05-13 RM-839 (c) Nokia M1 CNT : Content: m1_059R208 V 02.33 17-05-13 RM-839 (c) Nokia Product SN : BF72CF7BI Product code : 059R208 Base Prd.code: 059P5R3 Module code : 0205266 Long Prod.SN : 0 Hardware info======= HWID : 2000 Retu : PMU_MAXIM8939B Batery: 3852 mV CMT BT: 19e2-4702G12 LCDVer: TPO Lock info =========== IMEI : 357885051028549 IMEI spNet : 3A 75 88 05 15 20 58 04 IMEI svNet : 33 75 88 05 15 20 58 04 F6 Sl Conf : 001-01-00000000000 Sl Prof : 800000000004000-B Sl Aux : 000B0000 Hw Sig : B77AB9C5E2147C1E Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; CRT308 Backup Created CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL30 (20 digit) phone detected... User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] |
11-13-2013, 09:53 | #9 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | First - need install drivers. Power off phone, connect to PC. Check in device manager, install drivers manually from - Select manually - choose from list Nokia USB Device - Nokia USB connectivity. Same way with pic in DOCS/MTK/ folder. |
