08-20-2015, 03:22 | #1 (permalink) |
Insane Poster Join Date: Mar 2008
Member: 730856 Status: Offline Thanks Meter: 4 | Help, cant connect BEST? Micro USB charging cable(same with that for android mobile) was used to connect Nokia 215 and PC, however, always got the message below. Connect phone on selected interface... Connect phone on selected interface... What kind of USB cable should be used? how to connect using USB? Thanks. |
The Following User Says Thank You to sysboy For This Useful Post: |
08-20-2015, 08:14 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Install "Nokia Serial Driver" for FlashMode operations. Install WinUSB driver from support ( in Asha_WP8x_MTK package ) for Service(normal) mode operations. |
08-20-2015, 09:57 | #3 (permalink) | |
Member: 730856 Status: Offline Thanks Meter: 4 | Quote:
Connect phone and try again... Connect phone on selected interface... I have also installed Lumia Software Recovery Tool. The phone can be found and install the latest software to the phone. | |
04-26-2017, 11:34 | #8 (permalink) | |
Freak Poster Join Date: Jul 2014 Location: bangladesh
Member: 2227733 Status: Offline Thanks Meter: 69 | Quote:
Setup this driver Link Drivers_MTK_USB_Serial_Port_x86 Drivers_MTK_USB_Serial_Port_x64 100% tested --- Insert USB cable now! --- Wait for phone... Phone found! [ 63 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : F69FC41102A003FD2F3B6685FB8C5FB0 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : JET.10.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Jet.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 SecureDecrypt : RM-1110_ROM_eMP_10.01.11 SecureDecrypt : RM-1110_VIVA_eMP_10.01.11 SecureDecrypt : RM-1110_LANG_PACK_ROM_IC_eMP_10.01.11_002 SecureDecrypt : RM-1110_CUSTPACK_ROM_IC_MEA_EG_eMP_10.01.11_002 SecureDecrypt : RM-1110_JUMP_TABLE_IC_MEA_EG_eMP_10.01.11_002 OVRLP : 000069B900000001 PHPID : JET.10.01.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1110_ROM_eMP_10.01.11 Write : RM-1110_LANG_PACK_ROM_IC_eMP_10.01.11_002 Write : RM-1110_CUSTPACK_ROM_IC_MEA_EG_eMP_10.01.11_002 Write : RM-1110_JUMP_TABLE_IC_MEA_EG_eMP_10.01.11_002 Write : RM-1110_VIVA_eMP_10.01.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1110_ROM_eMP_10.01.11 [VERIFY] DONE : RM-1110_LANG_PACK_ROM_IC_eMP_10.01.11_002 [VERIFY] DONE : RM-1110_CUSTPACK_ROM_IC_MEA_EG_eMP_10.01.11_002 [VERIFY] DONE : RM-1110_JUMP_TABLE_IC_MEA_EG_eMP_10.01.11_002 [VERIFY] DONE : RM-1110_VIVA_eMP_10.01.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:02:58 Reboot phone Ok Connect phone on selected interface... | |
