![]() | #1 (permalink) | |
Junior Member ![]() ![]() Join Date: Sep 2007 Location: Egypt
Member: 594809 Status: Offline Thanks Meter: 18 | help me ![]() I followed the steps from this link and file Infinity-Box_OnlineService_2-Step-Verification.pdf Infinity-Box - Online Service I did as the pictures of the steps And came out of the log before Copy Token He then entered login asked Token I do not know the code and I can not access my account without code I spoke with said support Quote:
What should I do ؟؟؟؟ ![]() | |
![]() | #5 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | I just enabled and checked again. All work. When ios ask for token - run Token SW, connect dongle/box, insert token from is, press calculate. Insert result in ios. |
The Following User Says Thank You to Dzirt For This Useful Post: |
![]() | #7 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2009 Location: private
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Could you please explain, what was the problem ? Is it was not clear instruction or anything else ? Let me know what was the problem, we will improve instructions to avoid any problems in future. |
![]() | #8 (permalink) |
Member: 594809 Status: Offline Thanks Meter: 18 | We follow a pdf file 1. Sign in to your Infinity Online Service account with your Username and Password. 2. You will see 2-Step Verification page 3. Download and run Token software 4. Copy “ID” value from page “ID” field to software 5. Click to software “Calculate” button 6. Copy “Token” value from software to page “Token” field 7. Click to “Login” button to finalize process All Steps are 100% correct But the problem is in the PHP Code: Modified with account data The following tracks and put the last line in the file and save it ![]() C:\InfinityBox\BEST\best.ini C:\InfinityBox\BEST\settings.ini Then open Token.exe program And take ID available now from your login and then we put Calculate And press the token Token number will copy to the page will be successfully log Note: The most important information is true Xi in the following files: settings.ini best.ini Even program works Token.exe ![]() |
![]() | #9 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Thanks for info, but actually, Token.exe have no relation with C:\InfinityBox\BEST\best.ini and/or C:\InfinityBox\BEST\settings.ini Token.exe allow you to login to your Web Online Account. C:\InfinityBox\BEST\best.ini and C:\InfinityBox\BEST\settings.ini files used by software when you want to upload SL3 jobs to server. |
